Infinite Series (Integral Test)
6 replies · 2K views · last reply
Fernando Rios
Use the integral test to find whether the following series converge or diverge.
∑n=3∞(1/(n^2-4))
I got the following expression:
-(1/4)ln((n+2)/(n-2))
When I substitute "∞" in the expression I found it undefined. However, the book says the series converges. What am I doing wrong?
And how do you do such a thing ?
Do you know of a way to rewrite $$\sum_{n=3}^\infty\ {1\over n^2-4}\ ?$$ (hint: write down a few terms ...)
[edit] Oops o:) ! Thanks Math !
Fernando Rios said:
Homework Statement: Use the integral test to find whether the following series converge or diverge.
Homework Equations: ∑n=3∞(1/(n^2-4))
When you "substitute ##\infty##" in ##-1/4 \ln((n+2)/(n-2))## you get ##\ln(1) = 0##.
The integral test is probably the easiest way to deduce convergence here (or using results about hyperharmonic series).
Thank you for your answer. Isn't ∞/∞ indeterminate?
How so ? If you rewrite $$ {n+2\over n-2} = {1 + {2\over n} \over 1 - {2\over n} }$$ then you see that this goes to 1 if ##n\uparrow\infty## .
Yes, "[itex]\frac{\infty}{\infty}[/itex]" is "indeterminate- but, do you understand what "indeterminate" means? It does not necessarily mean that there is no value. It simply means that the value is not determined directly by that form but might have a value calculated in some other form. That is what BvU did.
