Inital acceleration to free-fall
The discussion centers on a physics problem involving a model rocket that accelerates at 12 m/s² until reaching a height of 26 m, after which it enters free fall. The maximum height attained by the rocket is calculated to be 100 m, with a final speed of -33.7 m/s just before impact. The total duration of the flight is determined to be approximately 5.98 seconds. The solution involves applying the equations of motion, specifically focusing on the transition from powered ascent to free fall.
  • Understanding of kinematics and the equations of motion.
  • Knowledge of initial acceleration and its impact on vertical motion.
  • Familiarity with free fall concepts and gravitational acceleration (9.81 m/s²).
  • Ability to apply the quadratic formula in physics problems.
  • Review the three equations of motion for vertical motion analysis.
  • Study the concept of free fall and its equations.
  • Learn how to apply the quadratic formula in kinematic problems.
  • Explore the effects of initial velocity on projectile motion.
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples of real-world applications of these concepts.
nakita22
A model rocket blasts off and moves upward with an acceleration of 12 m/s^2 until it reaches a height of 26 m, at which point the engine shuts off and it continues its flight in free fall. A)what is the maximum height attained by the rocket? B) What is the speed of the rocket just before it hits the ground? C) What is the total duration of the rocket's flight?
In the Example that is somewhat like this question in the book is using the equation:
Xf= Xi + Vi(t) - 0.5(g)t^2 = 0,
but this makes absolutely no sense since the intial acceleration is given as 12 m/s^2
I have attemped this question and several others in different ways and I just can not find a equation that I can manipulate so it fits into a free fall situation. Do I just assume the 12 m/s^2 for the first 26 m and then from there incorporate the acceleration of gravity 9.81 m/s^2 is it coming straight back down or is it forming a parabola? It is just way too confusing, and 4 hours at this problem is just way too much. Any help or suggestions would be greatly appreciated!
consider this as a vertical motion problem
All the relevant equations are the 3 equations of motion.
first you know rocket starts with a given accel and also the initial velocity is 0. Find final velocity at 26m height by one of the 3 equations of motion. From then on it's just freefall.
But remember that since the rocket has certain velocity it goes up for some time and then comes down. so include that time in the whole motion.
Thank you for the help I am not sure if I did it right, but here it goes:
I first solved for v= 25 m/s
Then I used the quadratic formula to find the time of the flight = 5.98 sec
Certain velocity = 4.41 m/s and added to 25m/s so I could solve for max height.
Then I solved for max height = 100m
Lastly I solved for the speed of the rocket before it hit the ground = -33.7 (- indicating direction.
* Like I said I think I did it wrong so, any corrections are appreciated
I believe you are wrong. the mistake begins from time of flight. Try stickin to the equations of motion and you will find it much easier. :smile:
