Inner Product vs. Dot Product Confusion in Quantum Physics?
The discussion revolves around the confusion between inner products and dot products in the context of quantum physics, particularly regarding their definitions and the treatment of complex numbers. Participants explore theoretical aspects and definitions as presented in various educational materials.
  • One participant notes a discrepancy between the definitions of inner and dot products as presented in Wikipedia and an MIT PDF, specifically regarding which term's complex conjugate is used.
  • Another participant acknowledges that there are multiple definitions of inner products, referencing a specific equation from the MIT materials.
  • Concerns are raised about the implications of defining mathematical concepts, questioning whether definitions can be arbitrary.
  • It is mentioned that inner products must satisfy certain properties, such as linearity and non-negativity, which justifies the use of complex conjugates in the definitions.
  • A participant suggests that while it is customary to take the complex conjugate of the right-hand term, it is not strictly required.
Participants express uncertainty and differing views regarding the definitions and properties of inner products and dot products, indicating that no consensus has been reached on the matter.
Participants highlight the importance of definitions and properties in mathematical contexts, but the discussion remains open-ended regarding specific applications and interpretations.
lawlieto
I started learning quantum, and I got a bit confused about inner and dot products.
I've attached 2 screenshots; 1 from Wikipedia and 1 from an MIT pdf I found online.
Wikipedia says that a.Dot(b) when they're complex would be the sum of aibi where b is the complex conjugate.
The PDF from MIT (https://ocw.mit.edu/courses/physics...all-2013/lecture-notes/MIT8_05F13_Chap_04.pdf) page 2 says that the inner product is taken <a|b>, then when doing a1b1+a2b3+... the complex conjugate of a is taken. I thought this would be the same thing as taking the dot product with complex numbers (like what I mentioned above in the 2nd paragraph). But in the dot product, the complex conjugate of b is taken, whereas here the complex conjugate of a is taken.
Could someone demystify this for me please?
Thanks
In the MIT materials they are defining an inner product as they show in equation 1.4. There are many ways that an inner product can be defined, including the one you show from the Wikipedia article.
Thanks for your reply, so it's just a matter of how you define it? But then you could define anything to be anything?
No, it has to satisfy some properties like linearity in its arguments. Another requirement is usually, that ##\langle a,a \rangle \geq 0##. In the case of complex components, this is the reason for the conjugate in either of the arguments. Whether you choose the first or second doesn't matter, just don't confuse them.
Although not required, it is customary to take the complex conjugate of the right hand term.
  • · Replies 43 ·
