Insulator/Conductor Question with picture
  • Thread starter Thread starter swooshfactory
The discussion centers on the behavior of electric field lines in relation to insulators and conductors, specifically in a lab context. It is established that electric field lines are always perpendicular to conductors, preventing any transverse component of the electric field. The equipotential lines, represented by red dots, are confirmed to be circular around a conductor, while the interaction with insulators complicates the field's behavior. The participant clarified that the red dots along the gray haze line represent points of equal electric potential, indicating a clear understanding of the concepts involved.
  • Understanding of electric field theory
  • Familiarity with equipotential lines and their properties
  • Knowledge of conductors and insulators in electrostatics
  • Basic skills in interpreting lab data and diagrams
  • Study the principles of electric fields and equipotential surfaces in electrostatics
  • Learn about the behavior of electric fields around different geometries of conductors
  • Explore the effects of insulators on electric field distribution
  • Investigate practical applications of electric field concepts in laboratory settings
Students in physics, particularly those studying electromagnetism, educators teaching electric field concepts, and anyone involved in laboratory experiments related to electrostatics.
swooshfactory
http://i215.photobucket.com/albums/cc95/warrenm_2007/elec.jpg
Here is the problem: The red dots represent points of equal electric potential and the gray haze is the projected equipotential line. I am unsure about what happens to the electric field lines as they encounter the insulator and around the large conductor in the middle. If anyone could explain to me what is happening there, I would appreciate it.
I guess I would think that the insulator stops the electric field and that it does not transmit to the other side. It would I believe stop the electric field and given that there is no source for an electric field on the other side, I don't see why it would continue.
Around the large conductor in the middle, I would think that the electric field lines are feeding into the conductor unless they can go up the middle or around it to continue to the other side.
Also: does the insulator affect the field at all? The one point I have on the surface of the insulator looks a little fishy.
Thanks in advance for any help or advice.
Your diagram looks a little confusing. Is this the result of lab work, a drawing you made to better understand things, or is it something else? Are all of the red dots supposed to have the same potential, or just those along the same gray hazy line?
Electric field lines are always perpendicular to conductors. This is because if the electric field was running sideways along the surface, this would move charges, and a split second later when those charges have reached their destination and everything was in equilibrium there would no longer be a sideways (transverse) component to the E-field. For an insulator, things are more complicated. Now, equipotential lines should be perpendicular to the E-field lines, so if we have a circular conductor the equipotential lines close to the conductor should be circular. Of course, if this is lab work it may not be that precise.
i guess it seemed more clear to me. all the red dots in a grey haze line were equipotential. it was for lab work, i replicated my data with paint. i already got the report turned in, so i don't still need help. thanks for replying though.
