Integer solutions for equations
  • Context: High School
  • Thread starter Thread starter 69911e
    Integer
The discussion revolves around finding integer solutions for equations involving positive integers, specifically focusing on the equation 30x + 19 = 7y + 1 = a. Participants explore methods to derive a universal formula for a specific constant C5 in a generalized equation involving positive integers.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant seeks to understand how to find integer solutions when parameters are limited to positive integers, providing a specific example and asking for a formula for C5.
  • Another participant references the Chinese remainder theorem as a basis for the existence of solutions and suggests that the equation can be interpreted in modular arithmetic.
  • A participant mentions that coefficients C1 and C3 are co-prime, which may affect the approach to finding solutions.
  • There is mention of an algorithm to find solutions, though it is noted that it may not yield a straightforward closed formula.
  • One participant expresses optimism about the algorithm's complexity, suggesting it may be manageable if limited to two equations.
Participants do not reach a consensus on the existence of a closed formula for C5, and multiple approaches and interpretations are presented without resolution.
Participants acknowledge the need for co-primality of coefficients and the limitations of the algorithm discussed, indicating that the complexity may vary based on the number of equations involved.
69911e
I am trying to understand how to find solutions for a problem when parameters are limited to positive integers.
Example:
30x+19= 7y+1 =a ; where x,y,a are positive integers
Wolframalpha outputs:
a = 210 n + 169, x = 7 n + 5, y = 30 n + 24, n element Z(integers)
30*7= 210 (obviously)
How do I calculate 169? I can do it by hand, but am likely missing something obvious generating a universal equation.
I am trying to find a formula to solve for C5 below:
(C1 * X) +C2 = (C3*Y) + C4 = (C1*C3*n) +C5 ; where C1,C2,C3,C4 are constants and X,Y,n are the set of positive integers. Looking for a formula for smallest integer solution C5
Any suggestions?
Mathematics news on Phys.org
The existence is a result of the Chinese remainder theorem, and with the formulas there you can also construct the smallest solution.
##30x+19=a## can be interpreted as ##a=19 \pmod{30}##.
MFB: Thanks for the link.
I forgot to specify, coefficients (C1&C3) of x and y are also defined as co-prime.
This is a small part of a (non-school) prime number related summer project I am working on with my 13&16 year old and we trying no to get bogged down on this equation. If it does not a have a formula solution for C5 (above), we may need to move onto a different path.
There is an algorithm to find it. It is not directly a nice closed formula.
MFB: It seems not too complex of an algorithm if limited to 2 equations. We may be able to use it and define the bounds needed.
Thanks
  • · Replies 21 ·
  • · Replies 16 ·
31K
