Integer triangle with integer heights
16 replies · 2K views · last reply
mathics
Prove that if the lengths of the sides of a triangle and the heights drawn to all sides are integers, then these integers are all multiples.
Pythagorean theorem
I tried to figure it out by proof by contradiction. I assumed wlog that one side is a prime number, which gave a contradiction, and I also found that such a triangle should be isosceles. Then I assumed wlog that one of the heights is a prime number and I also got a contradiction. Therefore, all sides and heights are whole numbers, which are also multiples.
Is my idea for proofing okay? Is there a better way for proofing this?
mathics said:
Yes. If the triangle has integer sides and integer heights (the heights also must multiples not primes), then I believe the area should also be integer, if I'm not wrong.
Can you state precisely what you are tryuing to prove?
I'm trying to prove that if the lengths of the sides of a triangle and the heights drawn to all sides are integers, then these integers are all multiples.
What does "heights drawn to all sides" mean? Perhaps you could post an image?
Like so.
Triangle ABC with altitudes CF, AD and BE meeting at point g; sides a (BC), b (CA) and c (AB) labelled, with right-angle marks at D, E and F and angle labels alpha, beta and gamma equal to 90 degrees.
It seems you could try using the formula that uses the Cross-Product, using coordinates centered at the origin. But, like I think Oro was suggesting, funding a Pythagorean triple with sides a,b both odd, though I think there aren't such pairs/triplets.
The converse is not true however. There are Heronian triangles whose heights are not (all) integers. Examples include some well known Pythagorean triples.
Thank you for correcting me.
PeroK said:
So, you want to prove that ##a, b, c, g, i, k## have some relationship?
Yes, I want to prove if sides a, b, c are integers and heigths k, i, j are also integers, then theese integers are all multiples.
I believe I have to use triangle area formula and Pythagorean theorem, then compare the sides and heights of the triangle.
I would start by selecting one side and proof by contradiction. (E.g I choose side "a" wlog, and say, it has a prime length, and then i would get a contradiction, so the first statement must be true.)
However, I'm not sure how to format it nicely.
You mean they are all multiples of some common integer?
Well, all sides can be different, it is just that they have to they must have an integer value and they must be multiple numbers. (For example like 6 is integer number and is also a multiple number.)
If you mean not prime, then composite is the correct term.
Thank you.
