Integral: ∫(exp(6x))/(exp(12x)+25)dx Solution
4 replies · 3K views · last reply
suprabay
answer: -arctan[5/exp(6*x)]/30
honestly, don't know where to start. i was looking at another forum and tried to set u=exp(x) du=exp(x) and dx=du/u. plugging that in i got u^6/(u^12+25)*du/u. not sure where to go from there or if that is even the way to go.
Hi supraboy, Welcome to PF!:smile:
Try the substitution [tex]u=e^{6x}[/tex] instead :wink:
Try setting u = e6x. Then du = 6e6x and e12x = u2.
ok, setting u=e^6x du=6e^6x, then dx=du/6u?
then, it would be int(u/u^2+25)du
using the formula int(a^2+u^2) = (1/a)arctan(u/a) + C
i get, (1/5)arctan(e^6x/5)dx or (1/30)arctan(e^6x/5) + C
this is incorrect though because the answer is negative and it should be arctan(5/e^6x) instead of arctan(e^6x/5).
any ideas?
You made a mistake with the substitution. Write your integral like this:
[tex]\int \frac{(e^{6x} dx)}{(e^{6x})^2 + 25}[/tex]
If [tex]u = e^{6x}[/tex], then [tex]e^{6x} dx = \frac{1}{6} du[/tex]. Try working from there.
