Integral of cos³(x)/(x⁶+1)
  • Level: Graduate
  • Thread starter Thread starter joao_pimentel
    Hard
12 replies · 3K views
joao_pimentel
Hi guys
I'm wondering how shall I solve this primitive/integral
[tex]\int\frac{\cos^3 x}{x^6+1}dx[/tex]
I really don't know how to start... which substitution shall I take or if I shall solve it by parts...
Any hints or tips will be very appreciated
Thanks in advance
I don't know if I need an explicit expression, I just need to find how shall I start...
I've tried all trigonometric substitutions and nothing :(
I'm lost
Hey joao_pimentel.
Have you looked at different tables of integrals? Chances are you will find a table out there somewhere that gives a form that is exact or 'close' to the form you are working with.
One strategy I have for you is to reduce the trig terms to something that is at least linear. You might have to do a few integrations by parts by differentiating the trig terms and then using trig conversions to put them in the appropriate form.
The denominator of the term looks like a (1 + x^2) which is used in many tables, although if its in combination with a trig term then that could still make it complicated.
Also having looked at the solution, maybe another suggestion is to consider a transformation to an expontential form (in the form of using expressions of e^(whatever)) so for example cos(x) = 1/2(e^(ix) - e^(ix)).
Split the integral in two, in writting cos(x)^3 in terms of cos(x) and cos(3x)
Split both integrals in six, in writting 1/((x^6)+1) in terms of a sum of six terms c/(x-r) where each r is on the form r=(-1)^(1/6) , i.e. the six complex roots of unit.
Then, the antiderivatives of each cos(x)/(x-r) and cos(3x)/(x-r) can be formally expressed in terms of the special functions Ci(z) and Si(z) where z is a complex linear function of x.
That is the factorization of x6-1, not x6+1. The latter factorization is a bit uglier.
First factor [itex]x^6+1[/itex] as [itex](x^2+1)(x^4-x^2+1)[/itex]. The latter term in turn has the factorization [itex](x^2-1+\sqrt[3]{-1})(x^2-\sqrt[3]{-1})[/itex], so
[tex]x^6+1 = (x^2+1)(x^2-1+\sqrt[3]{-1})(x^2-\sqrt[3]{-1})[/tex]
I'll leave the last ugly bit as an exercise for the OP.
Thanks a lot guys... it was a big help...
I shall write cos(x)^3 in terms of a sum of cos(x) and cos(3x) as JJacquelin said and then fatorize x^6+1 as D H said... Then I shall use Ci(z) e Si(z) functions for each term..
I'll try it :)
Thanks a lot again
João
Guys
I know that [tex]cos^3(x)=\frac{1}{4}\left(cos(3x)+3cos(x)\right)[/tex]
Then
[tex]\begin{aligned}<br /> \int &\frac{\cos^3 x} {(x^2+1) (x^2-1+\sqrt[3]{-1}) (x^2-\sqrt[3]{-1})} dx \\<br /> & =\frac{1}{4}<br /> \int \frac{\cos{3x}} {(x^2+1) (x^2-1+\sqrt[3]{-1}) (x^2-\sqrt[3]{-1})} dx +<br /> \frac{3}{4}<br /> \int \frac {\cos{x}} {(x^2+1)(x^2-1+\sqrt[3]{-1} )(x^2-\sqrt[3]{-1})} dx<br /> \end{aligned}[/tex]
Then I need to factorize [tex]\frac{1}{(x^2+1)(x^2-1+\sqrt[3]{-1})(x^2-\sqrt[3]{-1})}[/tex] in partial fractions
[tex] \frac{1} {(x^2+1) (x^2-1+\sqrt[3]{-1})(x^2-\sqrt[3]{-1})} =<br /> \frac{Ax+B}{x^2+1} + \frac{Cx+D}{(x^2-1+\sqrt[3]{-1})}<br /> +\frac{Ex+F}{x^2-\sqrt[3]{-1})}[/tex]
Then I get each fraction [tex]\cos(a x)\frac{\alpha x + \beta}{x^2+\lambda}[/tex]
How do I use such Ci(z) functions... Actually I confess I'm not aware of such Ci(z) and Si(z) functions... would it be Hyperbolic function?
Thank you a lot
I think that it not a good idea to process with partial fractons which denominators are second degree polynomials. This will lead to complicated integrals, not easy to expess in terms of Ci and Si functions.
I maintain what I already said in my previous post [ Y, 01:19 PM] :
1/((x^6)+1) is much easier to write as the sum of six terms on the form c/(x-r) where each c is a different complex number easy to find and where the six different r are the roots of (r^6)+1=0, i.e. six complex number easy to find.
Here's what you said yesterday:
That's incorrect. Using those (x-r) as the factors, where each r is one of the six sixth roots of unit, is the factorization of x^6-1=0, not x^6+1=0.
Obviously :
r = exp(i(2n+1)pi/6)
I think that it isn't the key point of the question.
