Integral of this simple function
  • Thread starter Thread starter iScience
    Function Integral
6 replies · 3K views
iScience
im trying to find...
∫te^(5t)dt
i did integration by parts..
u=e^5t
dv=tdt
∫te^(5t)dt={e^(5t)}(t)-5∫(t){e^(5t)}dt
collected the integral terms on one side to get..
6∫te^(5t)dt={e^(5t)}(t)
∫te^(5t)dt= {e^(5t)}(t)/6
but wolfram alpha says otherwise. they don't give out the steps freely anymore. please help
Use ILATE for integration by parts:
Inverse trig
Logarithmic
Algebraic
Trig
Exponential
Whichever function is higher on the list gets to be u, and dv is whichever function is lower. You have a t, which is algebraic, and you have an exp(5t), which is exponential. Try that.
∫te^(5t)dt
u=e^5t
dv=tdt
With u = e^(5t) and dv = t dt, you will get
∫ t e^(5t) dt = (1/2)t^2 e^(5t) - (5/2) ∫ t^2 e^(5t) dt,
so you have just made it worse! You have the wrong u and dv.
Define the function
[tex]f(t,x)=\int \mathrm{d} t \exp(t x)=\frac{1}{x} \exp(t x).[/tex]
Then you have
[tex]\partial_x f(t,x)=\int \mathrm{d} t \exp(t x)=-\frac{1}{x^2} \exp(t x)+\frac{t}{x} \exp(t x).[/tex]
Setting [itex]x=5[/itex] you find
[tex]\int \mathrm{d} t \exp(5t)=\exp(5t) \left [\frac{t}{5}-\frac{1}{25} \right].[/tex]
vanhees71 said:
Define the function
Then you have
There is a bit of faulty notation here. After partially differentiating f with respect to t, you should have an additional t factor inside the integral, which is what I think you wanted, as your solution seems to be using that. I believe you have forgot to type it..?
Ackbeet said:
Inverse trig
Logarithmic
Algebraic
Trig
Exponential
Whichever function is higher on the list gets to be u, and dv is whichever function is lower..
I never memorised this list - I just look at what could possibly be u and dv and then decide what would ultimately simplify the integral. As Ray said, by choosing dv = t dt, all you do is introduce greater powers of t whereas choosing u = t, when you differentiate it, you simply get 1 and hence is more likely to simply the integral. I think (i may be wrong) this is how that ILATE list was created - after some experience, it was put together as an easy way to decide on u and dv which would lead to a simpler integral.
Sure, that's a typo :-(. Correctly it should read
[tex]\partial_x f(t,x)=\int \mathrm{d} t \; t \exp(t x)=\ldots[/tex]
