Integrate (1+Z)/(2-2Z): Step-by-Step Guide
  • Thread starter Thread starter franky2727
    Integration
The discussion revolves around the integration of the function (1+Z)/(2-2Z), exploring various methods and approaches to solve the integral.
  • Mixed
  • Participants discuss different methods for integration, including polynomial long division, u-substitution, and separating the fraction. Questions arise about the effectiveness of these methods and the complexity involved in each approach.
Several participants have offered different strategies for tackling the integral, with some suggesting simpler forms of the expression. There is an ongoing exploration of various interpretations and methods without a clear consensus on the best approach.
Some participants express confusion regarding the methods and substitutions, indicating a need for clarification on the steps involved in the integration process.
franky2727
how do i integrate (1+Z)/(2-2Z)
What have you tried so far?
[tex]\int\frac{1+Z}{2- 2Z}dZ= \frac{1}{2}\int\frac{1+Z}{1- Z}dZ[/tex]
Does that help?
and
[tex]\frac{1+ Z}{1- Z}= -1- ?[/tex]
Try a u substitution. What's the obvious one?
substitute 2-2Z for u? but then I've still got something over something else and still don't get what method to use :S
As HallsOfIvy pointed out, you can just use polynomial long division to decompose the fraction into something more integrable.
If u=2-2Z then Z=(2-u)/2. Substitute that into 1+Z. Now it's all u's.
Dick said it all. You need to write Z in terms of u, then you need to find dz/du by differentiating that. You substitute everything in and integrate.
But you will still have to divide the fraction. Seems simpler just to reduce the original fraction.
If you factor out the 2, sub u = 1-z and z = 1-u, all the work has been done for you. Just separate the fraction and integrate.
And, one more time, why not just "separate the fraction" (by which I assume you mean "divide") without the substitution?
If you substitute [itex]u=2-2z[/itex], and you simplify it, you will end up with this at one point:
[itex]-\frac12 \int \left( \frac{2}{u} - \frac12 \right) \ \mathrm{d}u \implies \frac14 \int 1 \ \mathrm{d}u - \int \frac{1}{u} \ \mathrm{d}u[/itex]
Integrate this and remember to substitute [itex]u=2-2z[/itex] in the end to get the final answer.
[tex]u = z-1[/tex]
[tex]du = dz[/tex]
[tex]z = u + 1[/tex]
[tex]\frac{1}{2} \int \frac{1+z}{1-z}dz =\frac{1}{-2} \int \frac{1+z}{z-1}dz =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{dz}{z-1} + \int \frac{z}{z-1}dz \right) =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{u + 1}{u} du \right) =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{du}{u} + \int du \right) =[/tex]
Continue from this point.
And if you use the fact that [tex]\frac{1+z}{2-2z}= -\frac{1}{2}\left(1+ \frac{1}{1-z}\right)[/tex] you have
[tex]\int \frac{1+z}{2- 2z}dz= -\frac{1}{2}\int (1+ \frac{1}{z-1}dz= -\frac{1}{2}(z+ ln|z-1|)+ C[/tex]
That seems simpler to me.
Your method is indeed much simpler. =)
I don't think it's MUCH simpler. It's six of one and half a dozen of the other. Neither one is all that complicated. If you ask me. And you don't have to.
That's false though... Just check z=0 the left side gives 1/2, but the right side gives -(1/2)(2)=-1...
At this point I'm wondering who cares. franky2727 hasn't checked in since the initial post. I guess this thread is just getting a lot of attention because nothing else is going on.
Typo: I meant
[tex]-\frac{1}{2}\left(1+ \frac{2}{z-1}\right)[/tex]
  • · Replies 26 ·
