Integrate the following equations using U-Substitution
  • Thread starter Thread starter Xetman
    Integrate
The integral of √(x²(x+3)) from -3 to 0 was attempted using u-substitution, with u=x+3 and changing the bounds accordingly. The calculation led to an incorrect result of -4.15, while the expected answer is positive 4.15. The confusion arose from not accounting for the fact that √(x²) equals -x for negative x values. Acknowledging this correction clarified the mistake, confirming that the integral's value should indeed be positive. The discussion highlights the importance of correctly applying the properties of square roots in integrals.
Xetman
Integrate √(x2(x+3)) from -3 to 0.
∫√(x2(x+3)) dx
-32. The attempt at a solution
Here is what I did:
√(x2(x+3))
= x√(x+3)
Let u=x+3, du=dx, x=u-3
Insert the bounds and change the bounds to: 0 to 3.
x√(x+3)=
(u-3)√(u)
= u3/2-3u1/2
Thus we have:
∫(u3/2-3u1/2) du
Finally:
(2u5/2)/5-(2u3/2) from 0 to 3.
Thus I get: -4.15.
However the correct answer is positive 4.15.
I know the answer should be positive but what I don't understand is why I'm getting a negative answer. Please help.
Thanks in advance.
∫√(x2(x+3)) dx
-3
Here is what I did:
√(x2(x+3))
= x√(x+3)
x√(x+3)=
(u-3)√(u)
= u3/2-3u1/2
Thus we have:
∫(u3/2-3u1/2) du
Finally:
Thus I get: -4.15.
Thanks in advance.
Be careful.
\displaystyle \sqrt{x^2} = |x|
In fact, for x<0, \displaystyle\ \sqrt{x^2} = -x\ .
∫√(x2(x+3)) dx
-3
Here is what I did:
√(x2(x+3))
= x√(x+3)
x√(x+3)=
(u-3)√(u)
= u3/2-3u1/2
Thus we have:
∫(u3/2-3u1/2) du
Finally:
Thus I get: -4.15.
Thanks in advance.
It's positive because if x is negative then sqrt(x^2)=(-x). Right?
Oh yeah. Silly mistake XD thanks.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
