Integrating a theta function/2d probability density function
The problem involves a two-dimensional circular region of radius a containing a gas of particles with uniform density, all moving at the same speed but in random directions. The challenge is to analyze the probability density function of the gas cloud after the chamber wall is removed, specifically focusing on the integration of a theta function within the context of the given probability density expression.
  • Participants discuss rearranging the theta function to express it in terms of Cartesian coordinates and question the implications of the limits of integration for the probability density function.
  • Some participants express confusion about integrating the theta function and its implications on the probability density, particularly regarding the normalization condition.
  • There are inquiries about the appropriate limits for the integrals and whether certain regions can be omitted from consideration.
  • Participants explore the relationship between the variables and the integration order, raising questions about the treatment of constants during integration.
The discussion is ongoing, with participants providing insights and suggestions for approaching the integration of the theta function. Some guidance has been offered regarding the normalization of the probability density, but there is still uncertainty about the integration process and the implications of the theta function on the overall density calculation.
Participants are navigating the complexities of a multi-variable integral involving a theta function, with specific attention to the behavior of the probability density as the gas expands. There are mentions of potential constraints based on the geometry of the problem and the behavior of the gas over time.
Thimble
A two-dimensional circular region of radius a has a gas of particles with uniform
density all traveling at the same speed but with random directions. The wall of the
chamber is suddenly taken away and the probability density of the gas cloud subsequently
satisfies
$$ \rho(r,\theta;t)=\frac{1}{\pi a^2}\int_0^{2\pi} \frac{d\phi}{2\pi} \Theta[a^2-r^2-(vt)^2+2rvtcos(\theta-\phi)]$$
where (r, θ) are the polar-coordinates of the point at issue, t is the time, v is the velocity
of the gas,Φ is the random orientation and Θ[x] vanishes if x is negative and is unity
if x is positive. Employing the equations below show that for each Φ and t the region mapped out by Θ is a circle and hence that the density is normalised.
$$x=rcos(\theta)$$
$$y=rsin(\theta)$$
$$d_x=vtcos(\phi)$$
$$d_y=vtsin(\phi)$$
Firstly I rearranged the theta expression to get
$$\Theta[a^2-(x-d_x)^2-(y-d_y)^2]$$ which I think satisfies the first part of the question with each Φ and t mapping out a circle with radius a and centre (dx,dy)
Now for the second part I'm thinking that I've got to show that the following statement is true
$$\int_{\phi=0}^{2\pi} \int_{r=r_{min}}^{r_{max}} \rho(r,\theta;t)rdrd\theta =1$$
where rmaxand rmin
are the maximum and minimum radii of the region the gas is in at that time which I think is a circle for a>vt and a doughnut shape for a<vt by thinking of the entire region as a series of circles of the same radius with centers moving away from the origin at the same speed in every possible direction.
The stumbling block I'm having is trying to integrate this theta function. My attempt at it was just treating the theta function as one as for all Φ there are points where the expression inside the theta is greater than zero and thus Θ=1, but this gives a constant probability density which doesn't make sense to me as the area over which the gas is in is expanding so the probability density must surely decrease. I've never come across this type of function before and all the examples I've seen on the internet for them all seem to be in one variable rather than 4 (r,θ,t and Φ)so could anyone point me towards any guidance on how to integrate these types of functions? Thanks in advance for any help.
EDIT: Changed upper limit in the first integral to 2π.
$$\int_{\phi=0}^{2\pi} \int_{r=r_{min}}^{r_{max}} \rho(r,\theta;t)rdrd\theta =1$$where rmaxand rmin are the maximum and minimum radii of the region the gas is in at that time which I think is a circle for a>vt and a doughnut shape for a<vt by thinking of the entire region as a series of circles of the same radius with centers moving away from the origin at the same speed in every possible direction.
I think you mean ##\theta=0## on the lower limit, right? Use 0 and ##\infty## for the limits of the integral over ##r##. For a fixed ##\phi## and ##t##, the ##\Theta## function will only be equal to 1 when ##r## and ##\theta## correspond to a point inside the circle of radius ##a##, so you can write down what the result of the double integral should be. Then you still have the integral over ##\phi## to take care of.
Yes I should have θ=0 on the bottom limit. I don't see why we use 0 and ∞ as the limits for r, surely the integral at r=∞ is 0 and after a certain time the integral at r=0 will be 0 as well (As Θ will be zero at these values)? Also I'm still struggling to figure out how to obtain what ρ(r,θ;t) is to be able to do the double integral.
Generally, to show a probability density is normalized, you integrate over all space and show the result is equal to 1. You can certainly change the limits to omit the regions where the integrand vanishes, but why bother? It doesn't change the result and is an unnecessary complication.
You've been given ##\rho##. What's there to obtain?
I've been given ρ in terms of that integral of Θ that I'm not sure how to calculate. Without having the actual value for ρ rather than in terms of that definite integral I'm not sure how to show that the integral of ρ is equal to 1, unless I'm missing something obvious.
Keep ##\rho## in terms of the integral of ##\Theta##, plug it into the double integral, and then change the order of integration so you integrate over ##\phi## last.
Ah, that makes sense. Just two more quick questions if you don't mind. As r would be treated as a constant in an integral with respect to Φ can i just take it inside the integral as follows to get
$$\int_{\theta=0}^{2\pi}\ \int_{r=0}^\infty \int_{\phi=0}^{2\pi} \frac{r \Theta[a^2-r^2-(vt)^2+2rvtcos(\theta-\phi)]}{2\pi^2a^2} d\phi dr d\theta$$
I'd then obviously take out the constants to make it look neater. Then am i able to just shift around the order that the integrals are performed in with no further changes? I've seen some places saying I can and some that I can't. Sorry for having so many questions and thanks for your help so far.
  • · Replies 19 ·
  • · Replies 19 ·
