Integrating Factor and Unintegratable Term
The discussion centers on solving the ordinary differential equation (ODE) y' = (1+x^2)y + x^3 with the initial condition y(0)=0. The integrating factor is calculated as e^(-x^3/3 - x), but the integral involving e^(-x/3 - x) and x^3 is not solvable using standard methods. The professor suggests that the solution exists in terms of an integral, which can be evaluated numerically to find y(1). This highlights the importance of understanding implicit solutions in ODEs when faced with initial conditions.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with integrating factors in ODEs
  • Knowledge of numerical integration techniques
  • Basic calculus, particularly integration methods
  • Research numerical integration methods for evaluating definite integrals
  • Study the method of Frobenius for solving ODEs
  • Explore implicit solutions in differential equations
  • Learn about power series methods for ODEs
Students and educators in mathematics, particularly those studying differential equations, as well as anyone interested in advanced integration techniques and numerical methods.
Sierevello
I was given the following ODE to solve and it seemed simple enough. However, after you have used the integrating factor the integral is not integratable.
y' = (1+x^2)y +x^3, y(0)=0
Find y(1) if y(x) is the solution to the above ODE.
So I put it in the proper form of:
y' + (-1-x^2)y = x^3
INT FACTOR = e^(INTEGRAL(-1-x^2) dx) = e^(-x^3/3 - x) so:
y = e^(x/3 + x) * (INTEGRAL e^(-x/3 - x) * x^3 dx + C)
This "(INTEGRAL e^(-x/3 - x)" is not integratable by any means I know of. So I e-mailed the Professor and this is what he told me to do.
"I gave this problem so you would have experience with something that doesn't have an explicit solution. The solution is in terms of an integral. You can even make it a definite integral with the upper limit variable. Choose the lower limit so the initial condition works out. Since your calculator can do numerical integration, you can then evaluate y(1)."
I am clueless on what he is talking about. I have looked in all of the DE texts I have and all say that it is fine to leave it in the form that it is in. However, none of those examples cover what to do when there are initial conditions present and you run into this problem.
Can anyone help me with this?
Thanks, Steve
How are you getting this step:
INT FACTOR = e^(INTEGRAL(-1-x^2) dx) = e^(-x/3 - x) so:
Using the integrating factor is given by the form:
dy/dx + A(x)y = B(x)
INT Factor = e^(A(x) dx)
so A(x) = (-1-x^2)
INt Factor is given by: e^(INTEGRAL (-1-x^2 dx)
INT Factor = e^(-x^3/3 - x)
Does that make sense?
Yes but e^(-x^3/3 - x) is different from e^(-x/3 - x) that you originally wrote. I guess I was hinting that you forgot the "^3" Does that make sense?
Fixed. Thanks.
Any idea how to the ODE?
Thanks, Steve
I wouldn't use integrating factor, probably method of Frobenius / power series method is what I'd jump to.
We haven't learned that yet. Any ideas as to what the Professor said?
Thanks for your help.
-Steve
