Integrating for area under a curve.
9 replies · 3K views · last reply
Darth Frodo
So, as you can see in the attached pictures, I needed to find the common area bound by the 2 curves.
Is the method I have outlined correct because according to the marking scheme it just says
[itex]\int g(x)[/itex] - [itex]\int f(x)[/itex] (The limits are the same, -3/2 to 1)
The way I see it, this does not account for the little bit below the x axis. Am I wrong because I always thought with these area questions you had to the 2 sides of an axis separately.
  • Handwritten sketch, rotated, of two parabolas opening to the right with the common region between them shaded green; red curve labelled y = f(x) and blue curve labelled y = g(x), with marks at 1 and 1/2 on the vertical axis.
  • Handwritten working titled 'To find trapped area' (rotated): integral from -3/2 to 1 of g(x) dx minus integral from -1 to 1 of f(x) dx, plus integral from -1 to 0 of f(x) dx.
Hi Darth Frodo. The marking scheme is correct because using that method will find the signed area between f(x) and g(x) regardless of whether it is above or below y=0. You can think of a normal integration as being ∫g(x)dx-∫0dx, this will find the area bound by 0 and g(x), obviously ∫0dx is just 0. For this case we replace 0 with f(x) because we want the area between f(x) and g(x) not 0 and g(x).
Ok so I found another problem with area above and below the axis,
Is this correct. The graph will trap the area between the limits regardless of the side of the axis its on right?
  • Hand-drawn sketch of an upward parabola crossing the x-axis at 1 and 4, with the region between x = 1 and x = 5 shaded in blue diagonal lines, and the label y = beside it.
  • Handwritten red equation y = x^2 - 2x - 8 on lined paper, with a partial graph and axis labels 4 and 5 visible in the upper right and a calculator at the bottom right.
  • Handwritten calculus working, rotated sideways: the integral from 1 to 5 of x^2 - 2x - 8 dx, its antiderivative x^3/3 - x^2 - 8x evaluated at the limits, and the arithmetic leading to -44/3.
for integral g(x) dx, dx is width of elementary strip and g(x) is its y coordinate or height above x axis. Integrating this will give you only area b/w g(x) and x axis.
Doing same for f(x)dx first integral, we can divide it into 3 parts, -1.5 to -1, -1 to 0, 0 to 1
The -1.5 to -1 and 0 to 1 parts wil remove extra area that was calculated by g(x) integral ( the area which we didnt need)
Now for -1 to 0 part, f(x) is negative, so integral will solve out to be negative. But you have a - outside too. So this wil result in positive area after all. Also, this is the area of f(x) and x-axis below x axis.
Now third integral is also this is the area of f(x) and x-axis below x axis.
But this time it will be negative, as there is + outside integration.
So this will remove the required area that was added by second integral. So by removing third integral, you will get correct answer.
But the second problem I did, with the single curve, was that correct? Because that was actually an example in the book and it said to split it up into 2 areas. But when I tried it with the limits 1 to 5 it was wrong...
I'm totally confused now.
So does that mean that ∫ f(x) between -1.5 and 1 captures the area shown in the pic below?
  • Handwritten sketch of y = f(x), a parabola-like curve with a vertical axis and horizontal axis, with green shaded regions between the curve and the x-axis from x = -3/2 to x = +1, dashed vertical lines marking those bounds, and a dip below the axis between them.
Handwritten sketch of a curve labelled y = f(x) on axes, with the x-axis marked -3/2 on the left and +1 on the right. Green shaded regions lie above the x-axis at the far left and right and below it in the middle dip.
No. That integral will give the area of the green region that's above the x-axis minus the area of the green region that's below the x-axis.
Ok cool, thank you all for your help! This has been a little ill-defined in my head until now! Thanks to everyone!
It's always ∫(top curve)-(bottom curve) for this sort of problem. Just when the y=0 axis is the top/bottom, that integral disappears. This is what I meant by signed area. If you do ∫f(x)dx-∫g(x)dx where g is above f, then this will give you a negative area.
Yes it will give the area above x-axis as positive and below one as negative. This is because for limit -1 to 0, f(x) is negative
EDIT: Just like sammys said ... :-P
