Integrating with the TI-83 Calculator for Volume Approximation?
The discussion revolves around using a TI-83 calculator to approximate the volume of a solid formed by revolving the area between the curves of y = sin x and y = 0 over the interval [0, π] about the y-axis. The original poster seeks assistance in setting up the integration process on the calculator.
  • Exploratory, Mathematical reasoning
  • Participants discuss setting up the integral for volume approximation, specifically using the formula π ∫[0 to π] sin² x dx. Questions arise regarding the transition from sin x to sin² x, with explanations related to the formula for volume involving the area of a circle.
Participants are actively sharing methods for using the TI-83 calculator, including specific steps for accessing the integral function. There is a mix of clarifications and attempts to understand the reasoning behind the setup, with no explicit consensus reached on the best approach yet.
Some participants express uncertainty about the steps involved in using the calculator, indicating a need for clearer guidance on the integration process and the underlying mathematical concepts.
frumdogg
Use the integration capabilities of a graphing utility to approximate the approximate the
volume of the solid formed by revolving the region bounded by the graphs of y = sin x and y 0 in the interval [0, [tex]\pi[/tex]] about the y-axis. Round your answer to three decimal places.
Yikes! Help!
Can anyone help me set this up on a TI-83?
First thing you need to do is setup the integral.
[tex]\pi \int_{0}^{\pi}{sin^2 x} dx[/tex]
The integral gives you the area under the curve. So all you have to do is graph
[tex]{\pi}sin^2 x[/tex]
Then on the graph screen go to the list with intersection/zero options and you should see an integral symbol. Select that then enter the limits 0 then pi
Ok, probably a silly question now, but how did you get from sinx to sin^2x?
Because it's pi*r^2
radius = r = the function your given.
I knew that.. long day.
Because volume = Area * length and area in this case is pi*r^2
Another way to do it on the calculator is to go to MATH and scroll down to option 9 which reads fnInt(. Select it then enter the function in, make sure you do it carefully, then press the comma button, X, and then the bounds of integration.
So according to how Feldoh set it up you would press MATH, 9, pi, sin, x, ), X^2, comma, X, comma, 0, comma, pi, )
