Why is 51 considered the first uninteresting number?
The interesting number paradox humorously explores the classification of natural numbers as "interesting" or "dull." The paradox arises when attempting to define a "smallest uninteresting number," which leads to a contradiction, as this number becomes interesting by virtue of being the smallest uninteresting number. The discussion emphasizes that to resolve the paradox, a clear definition of "interesting" is essential. Without a well-defined criterion, any number can be classified as interesting based on its unique properties, leading to the conclusion that all natural numbers are interesting. The conversation also touches on the logical errors in self-referential definitions and highlights the need for rigorous mathematical definitions to avoid contradictions, referencing similar paradoxes like Berry's paradox. Ultimately, the thread concludes that without precise definitions, such paradoxes will persist, and it cites David Wells' work for examples of uninteresting numbers.
Avichal
The interesting number paradox is a semi-humorous paradox which arises from the attempt to classify natural numbers as "interesting" or "dull". The paradox states that all natural numbers are interesting. The "proof" is by contradiction: if there exists a non-empty set of uninteresting numbers, there would be a smallest uninteresting number – but the smallest uninteresting number is itself interesting because it is the smallest uninteresting number, producing a contradiction.
I don't want to talk about interesting being a subjective quality but the main paradox.
Since the first dull number is interesting, we classify it as interesting. But then the second dull number becomes the first dull number. So it is also interesting.
But if we look again, we have two new members to the interesting category both of which are interesting due to being the first dull number. But two numbers can't be first, right? So what is going on? I want a better understanding of this paradox.
Thank You!
There's no a paradox at all! First of all we have to define what numbers would be "interesting". Then we may define that the rest of numbers are "dull".
But if we define that first "dull" number is "interesting" then we have to say that a set of "dull" numbers is empty.
Have you noticed the difference?
You are effectively classifying any number as "interesting" if it has some property no other number has. But that immediately makes all numbers "interesting" because every natural number is 'unique'.
Hmm, I don't clearly understand this. I want to get a better understanding.
When we classify the first dull number as interesting, the second dull number becomes the first dull number. Hence we must classify it also as an interesting number. But here is the problem I don't understand - we just classified two numbers as interesting because both were 'first' which is not possible!
Due to lack of mathematics here I am moving this to GD.
This does, however, have a useful logical error at its heart. The point is that "interesting" must be given a clear definition, in order to use it logically. So, you can decide whether a number is interesting or not.
To begin with let's assume that "being the smallest uninteresting number" is not one of the criteria.
So, you define some criteria to define interesting and find that, say, 1-13 are interesting and 14 fails the test and is dull.
Now, however, you add the criterion of being the lowest uninteresting number to the definition of interesting. But, this is now a new criterion to the definition of interesting that wasn't there at the start.
So, now you decide to add the criterion at the start. So, you say something like a number is interesting if:
1. It is prime
2. ...
3. It's the lowest uninteresting number
But this last criterion is not well-defined, as it requires a conclusion to be made (whether a number is interesting or not) before the definition is complete. This is the self-referential logical error with the process. You can't have a criterion that depends on the conclusion using that criterion.
hmmm... The Mathematical Holy Grail...
Finding the number, that is not, unique:
https://www.youtube.com/watch?v=VsOCUFFn4Ug​
This is actually quite interesting from mathematics point of view.
Of course, you could say that this proves there are no "dull" numbers, so every number is interesting. But we actually need to go a bit deeper.
There are a lot of "pseudo"-mathematical proves like this which yield contradictions. My favorite one is Berry's paradox. Take the least number x which cannot be defined by less than 1000 letters. But we have just defined x with less than 1000 letters, so there's a paradox.
What's the problem? Well, mathematically, we have not yet given a definition of what "defined" is, or what "interesting" is. Because we use vague terms like this, there are apparent contradictions. The resolution math takes is that everything must be defined rigorously in the form of well-formed formulas. In this instance, Berry's paradox, or the interesting number paradox do not show up.
Thanks R136, and with that answer, thread closed.
David Wells' "The Penguin Dictionary of Curious and Interesting Numbers" lists 51 as the first uninteresting number. The first number not specifically listed is 58.
  • · Replies 43 ·
  • · Replies 20 ·
  • · Replies 24 ·
