Interesting Telescoping Series - Calc 2
The discussion centers on evaluating the telescoping series \(\sum_{k=1}^{\infty}\frac{k-1}{2^{k+1}}\). The user, Dane, initially attempted a partial fraction decomposition of the term \(\frac{k-1}{2^{2k+1}}\) but faced difficulties. The correct approach involves rewriting the series and recognizing that it can be expressed as a combination of simpler series, ultimately leading to the conclusion that the series converges to a well-known result through geometric series evaluation.
  • Understanding of telescoping series
  • Familiarity with geometric series convergence
  • Knowledge of partial fraction decomposition
  • Basic algebraic manipulation skills
  • Study the properties of telescoping series in calculus
  • Learn about geometric series and their convergence criteria
  • Explore advanced techniques in partial fraction decomposition
  • Practice evaluating series using algebraic manipulation
Students and educators in calculus, particularly those studying series convergence and evaluation techniques, as well as anyone interested in advanced mathematical problem-solving strategies.
danerape
Interesting Telescoping Series -- Calc 2
My problem with this series arose when I attempted a partial fractions decompisition of the following, (k-1)/(2^(2k+1). I attempted to factor the denominator with 2(2^k) which is right, but where do I go from there? It does not help much to multiply A*(2^k).
My decomposition was {a*2^k+2b}/2(2^k), where did I go wrong?
Thanks,
Dane
Why try partial fractions? I doubt that it is even applicable for this.
Does your sum start at zero or does it start at 1 ?
Problem attached...
It is a telescoping series from shaums outline
Thanks a lot
So, the problem is to evaluate the series:
\displaystyle \sum_{k=1}^{\infty}\frac{k-1}{2^{k+1}}​
(There's a typo in your Original Post or in your attached file.)
Note that \displaystyle \sum_{k=1}^{\infty}\frac{k-1}{2^{k+1}}\ =\ \sum_{k=1}^{\infty}\frac{k}{2^{k+1}}\ -\ \sum_{k=1}^{\infty}\frac{1}{2^{k+1}} Added in Edit: I doubt that this helps.
The k = 1 term is zero.
\displaystyle \sum_{k=1}^{\infty}\frac{k-1}{2^{k+1}}=0+\sum_{k=2}^{\infty}\frac{k-1}{2^{k+1}}
Let k = j+1. Rewrite the sum on the right in terms of j.
\displaystyle \sum_{k=2}^{\infty}\frac{k-1}{2^{k+1}}=\sum_{j=1}^{\infty}\frac{j}{2^{j+2}}
\displaystyle =\frac{1}{2}\sum_{j=1}^{\infty}\frac{j-1+1}{2^{j+1}}
\displaystyle =\frac{1}{2}\left(\sum_{j=1}^{\infty}\frac{j-1}{2^{j+1}}+\sum_{j=1}^{\infty}\frac{1}{2^{j+1}} \right)
The first sum in the last line is the same as the beginning series. -- It's just written with j rather than k.
Do some algebra to find that \displaystyle \sum_{k=1}^{\infty}\frac{k-1}{2^{k+1}}=0+\sum_{j=1}^{\infty}\frac{1}{2^{j+1}}
The sum with j is a geometric series. It converges to a well known result, but can also be evaluated as a telescoping series in a manner similar to what was done above.
