What is the condition for destructive interference in thin films?
Destructive interference in thin films occurs when the path length difference between reflected light beams results in a phase shift. The correct condition for destructive interference is given by 2T = (m + 1/2)λ_n, where λ_n is the wavelength in the film and m is an integer. A phase reversal occurs when light reflects off a medium with a higher refractive index, affecting the relative phase of the beams. The discussion highlights the importance of considering both path length differences and phase reversals in determining interference conditions. Understanding these principles is essential for solving problems related to thin film interference.
premed
Light of wavelength \lambda strikes a pane of glass of thickness T and refractice index n, as shown in figure(I attached a diagram I made). Part of the beam is reflected off the upper surface of the glass, and part is transmitted and then reflected off the lower surface of the glass. Destructive interference between these two beams will occur if :
a) T = \lambda / 2
b) 2T = \lambda / 2
c) T = \lambda / 2n
d) 2T = \lambda / 2n
2T= m\lambda
According to this equation, destructive interference occurs when 2T = \lambda /2. Right? Since \lambda = \lambda _{0} / n, then 2T= \lambda / 2n right? The correct answer is C though. I got answer D. What am i doing wrong. Thanks
Hi premed,
In section 3 you have remarked that destructive interference occurs when 2 T = \lambda/2. How did you find this? In your relevant equations section, you had already stated that the conditions for destructive interference was given by 2 T = m \lambda.
In that equation, m is an integer (with appropriate restrictions) and \lambda is the wavelength in the film; I don't think you can get 2 T = \lambda/2 from that unless m=1/2 which is not allowed.
Sorry. I'll clarify. The book gives the equation for constructice interfence as 2T=m\lambda where m is an integer. For destructice interference 2T = (m+1/2)\lambda . that's why i put in 2T = \lambda /2. The m in this case doesn't matter as long as 2T is not an integral multiple of \lambda because it is destructive interference. I set m = 0 so that's how I got 2T = \lambda /2. Does that make sense?
Hi premed,
With thin film interference you have two things you have to keep track of: the effects of the path length difference of the two light rays, and the effects of reflection on the phase of the light rays.
When a light ray reflects off a material with a higher index of refraction, it experiences a phase reversal. Whether 2T = m\lambda_n (where \lambda_n is the wavelength in the film) is the constructive or destructive condition depends on how many phase reversals there are in the problem (0, 1 or 2).
So how many phase reversals occur? What does that by itself do to the relative phase of the light rays? Once you have that information, then the condition
<br /> 2 T = m \lambda_n<br />
will leave their relative phase (from the reflection effects) unchanged, and
<br /> 2 T = (m+\frac{1}{2}) \lambda_n<br />
moves them out of phase an additional 180 degrees.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 35 ·
