MHB Proving the Dimension Bound for Intermediate Field Extensions
  • Thread starter Thread starter mathmari
    Field
The discussion focuses on proving the dimension bound for intermediate field extensions, specifically showing that there exists a basis of the composite field \(L_1L_2\) over \(L_1\) consisting of elements from \(L_2\). It is established that while \(L_1L_2\) can be expressed as \(L_1(b_1, b_2, \ldots, b_m)\), the elements \(b_i\) are not necessarily independent over \(L_1\). By applying the Basis Reduction Theorem, it is confirmed that a basis can be extracted from \(b_i\), leading to the conclusion that the dimension \([L_1L_2:L_1]\) is less than or equal to \([L_2:F]\). This ultimately supports the inequality \([L_1L_2:F] \leq [L_1:F] \cdot [L_2:F]\). The discussion effectively clarifies the relationship between the dimensions of the field extensions involved.
mathmari
MHB
Hey! :o
Let $K$ be a finite extension of $F$ and let $L_1, L_2$ be intermediate extensions.
  1. Show that there is a basis of $L_1L_2$ over $L_1$ that consists of elements of $L_2$.
  2. Prove that $[L_1L_2:F]\leq [L_1:F]\cdot [L_2:F]$.
I have done the following:
  1. Let $[L_1:F]=n$, $[L_2:F]=m$.
    Let $a_1, a_2, \ldots , a_n$ be a basis for $L_1$ over $F$ and let $b_1, b_2, \ldots , b_m$ be a basis for $L_2$ over $F$.
    $L_1L_2$ is the smallest field that contains $L_1$ and $L_2$.
    So, we have that $$L_1L_2=F(a_1, a_2, \ldots , a_n, b_1, b_2, \ldots , b_m)=L_1(b_1, b_2, \ldots , b_m)$$
    Does this mean that $b_1, b_2, \ldots , b_m$ is a basis for $L_1L_2$ over $L_1$ that consists of elements of $L_2$ ? (Wondering)
  2. We have that $F\subseteq L_1\subseteq L_1L_2$ so we get that $[L_1L_2:F]=[L_1L_2:L_1][L_1:F]$.
    We have that $[L_1L_2:L_1]=[L_1(b_1, b_2, \ldots , b_m):L_1]$. We have to show that this is smaller or equal to $[L_2:F]$, right?
    How could we show that? (Wondering)
mathmari said:
Hey! :o
Hi mathmari,
It is true that $L_1L_2=L_1(b_1,\dots,b_m)$, but the $b_i$ are not necessarily independent over $L1$; we only know that they are independent over $F$.
In a vector space, any spanning set contains a basis. By removing redundant elements, you can extract form the $b_i$ a basis of $L_1L_2$ over $L_1$. This shows that $[L_1L_2:L_1]\le m$, and the result follows.
Since $L_1L_2=L_1(b_1, b_2, \ldots , b_m)$ it follows that $L_2$ spans $L_1L_2$ as a vector space over $L_1$. From the Basis Reduction Theorem we get that we can remove some elements of $L_2$ to obtain a basis of $L_1L_2$ over $L_1$.
Have I understood that correctly? (Wondering)
We have that $[L_1L_2:L_1]$= dimension of $L_1L_2$ as a $L_1$-vector space = $\dim_{L_1}(L_1L_2)$ = number of elements of the basis of $L_1L_2$ over $L_1$.
Since the basis consists of some elements of $L_2$, we get that $[L_1L_2:L_1]\leq $ dimension of $L_2$. Is this correct?
Is this same as to say that $[L_1L_2:L_1]\leq $ dimension of $L_2$ as a $F$-vector space?
(Wondering)
Hi mathmari
All that is correct. For the second part, we could be a little more precise and modify the second paragraph as:
Since the basis consists of some elements of the basis of $L_2$ over $F$, we get that $[L_1L_2:L_1]\leq$ dimension of $L_2$ over $F$.
Ah ok! Thank you so much! (Smile)
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 25 ·
