Interpolating Points with Continuous Modular Functions?
  • Topic:
  • Thread starter Thread starter SatyaDas
    Continuous Function
5 replies · 2K views · last reply
SatyaDas
Define a continuous function $$F(x;n)$$ that interpolates points (x, x mod n) for a given integer n and all integer x. For example $$F(x;2)=\frac{1}{2}-\frac{1}{2}\cos\left(\pi x\right)$$ interpolates all points (x, x mod 2) when x is an integer. Similarly $$F(x;3)$$ should interpolate points (0,0), (1,1), (2,2), (3,0), (4,1), and so on and so forth.
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-0.307498196717283,"ymin":-1.0867151664943222,"xmax":8.25153781299237,"ymax":3.6140340364698735},"xAxisMinorSubdivisions":1,"yAxisMinorSubdivisions":1},"randomSeed":"e7520ae08f59a65224c632735e784ac7","expressions":{"list":[{"type":"expression","id":"1","color":"#c74440","latex":"\\frac{1}{2}-\\frac{1}{2}\\cos\\left(\\pi x\\right)"},{"id":"6","type":"table","columns":[{"values":["0","1","2","3","4","5","6","7","8","9","10"],"hidden":true,"id":"4","color":"#6042a6","latex":"x"},{"values":["0","1","0","1","0","1","0","1","0","1","0"],"id":"5","color":"#000000","latex":"y"}]}]}}[/DESMOS]
Mathematics news on Phys.org
As a first shot, here's $F(x;3) = 1 - \cos\left(\frac{2\pi x}3\right) - \frac1{\sqrt3}\sin\left(\frac{2\pi x}3\right)$:
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-2.8493548505939787,"ymin":-4.648035822948437,"xmax":12.843943840753106,"ymax":8.544113758660483}},"randomSeed":"fa42535881c2cad8cca69bf627c0af41","expressions":{"list":[{"id":"6","type":"table","columns":[{"values":["0","1","2","3","4","5","6","7","8","9","10","11"],"hidden":true,"id":"4","color":"#6042a6","latex":"x_1"},{"values":["0","1","2","0","1","2","0","1","2","0","1","2"],"id":"5","color":"#000000","latex":"y_1"}]},{"type":"expression","id":"1","color":"#c74440","latex":"1\\ -\\ \\cos\\left(\\frac{2\\pi x}{3}\\right)\\ -\\ \\frac{1}{\\sqrt{3}}\\sin\\left(\\frac{2\\pi x}{3}\\right)"}]}}[/DESMOS]
Nice attempt. Below is my output for F(x;3).
Of course, if you only require $F(x;n)$ to be continuous then you can use a sawtooth function consisting of straight line segments from $(kn,0)$ to $(kn+n-1,n-1)$ and from $(kn+n-1,n-1)$ to $((k+1)n,0)$ (for all $k\in\Bbb{Z}$). But I am assuming that you want $F(x;n)$ to be a smooth function. So it presumably needs to be a trigonometric function.
For $n=4$ I'm getting $F(x;4) = \frac32 - \cos\bigl(\frac{\pi x}2\bigr) - \sin\bigl(\frac{\pi x}2\bigr) - \frac12\cos(\pi x)$. I don't yet see what the general formula should be, but it seems that the constant term in $F(x;n)$ must be $\frac{n-1}2$.
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-2.8126723934116136,"ymin":-7.943888407281889,"xmax":17.187327606588386,"ymax":8.868573830351757}},"randomSeed":"20aff6dd18a698f6934d1e00080549f9","expressions":{"list":[{"type":"expression","id":"1","color":"#c74440","latex":"\\frac{3}{2\\ }\\ -\\ \\cos\\left(\\frac{\\pi x}{2}\\right)\\ -\\ \\sin\\left(\\frac{\\pi x}{2}\\right)\\ -\\ \\frac{1}{2}\\cos\\left(\\pi x\\right)"}]}}[/DESMOS]
Indeed, I meant smooth function and your finding of constant term matches with mine. So, high five. Below is my output for F(x;4). I guess it will help to get the idea that there is a pattern.
Here is my solution.
Since $F(x;n)$ is periodic with period $n$, we can assume that the function can be expressed as
F(x;n)=\sum_{i=0}^{n-1}\left(a_i\cos\left(\frac{2\pi i x}{n}\right)+b_i\sin\left(\frac{2\pi i x}{n}\right)\right).
There are total of $2n$ unknowns.
We get $n$ equations by using the fact
F(j;n)=j\text{ for all }j\in Z\text{ and }0\le j\le n-1.
We need $n$ more equations so that we can find all the unknowns. For that purpose we can impose more restrictions on the properties of the function $F(x;n)$. If we assume $F'(x;n)=0$ for all $x\in Z$ then we get $n$ more equations. So, now we have a system of $2n$ equations with $2n$ unknowns. If we solve them we get:
a_0=\frac{n-1}{2},\\
a_i=-\frac{n-i}{n} \text{ for all } 0<i<n,\\
b_0=0,\text{ and}\\
b_i=-\frac{n-i}{n}\cot\left(\frac{i\pi}{n}\right)\text{ for all } 0<i<n.
If we simplify things we get
F\left(x;n\right)=\frac{n-1}{2}-\sum_{i=1}^{n-1}\left(1-\frac{i}{n}\right)\csc\left(\pi\frac{i}{n}\right)\sin\left(\pi\frac{i}{n}\left(2x+1\right)\right).
This graph can be visualized interactively at desmos:
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-9.482047024807466,"ymin":-2.5350658426248973,"xmax":21.090566527405265,"ymax":14.255865825972153}},"randomSeed":"612b9f843d4d8a7b35fc02d3415719d3","expressions":{"list":[{"type":"expression","id":"1","color":"#c74440","latex":"F\\left(x,n\\right)=\\frac{n-1}{2}-\\sum_{i=1}^{n-1}\\left(1-\\frac{i}{n}\\right)\\csc\\left(\\pi\\frac{i}{n}\\right)\\sin\\left(\\pi\\frac{i}{n}\\left(2x+1\\right)\\right)"},{"type":"expression","id":"2","color":"#2d70b3","latex":"F\\left(x,N\\right)"},{"type":"expression","id":"3","color":"#388c46","latex":"N=5","hidden":true,"slider":{"hardMin":true,"hardMax":true,"min":"0","max":"100","step":"1"}}]}}[/DESMOS]
