Interpreting photon correlations from independent sources
178 replies · 18K views · last reply
msumm21 said:
I understand this, but I don't agree it's plays a role in an argument towards retro causality.
Sorry, but you're wrong.
msumm21 said:
This is just like the temperature example I gave in post #15.
No, it isn't. In your temperature example, the correlations will never violate the Bell inequalities. In the QM example, they will.
msumm21 said:
Equation 2 was the state of the system before measurement/swap of P23.
Ah, sorry, I misread your post. You are correct that that is the state before the swap.
Then the question is, what is the state after the swap, if the swap takes place? It's not Equation (2).
msumm21 said:
My point is, all these things we can find in the BSM data, we can also find in the SSM data. The only difference is that, with the BSM data, we can pick out the subsets using the P23 result.
No, you can't when it's apples to apples. The data is selected from 2&3 results being VV or HH. You get completely different results when the swap switch is on.
msumm21 said:
1. I understand this, but I don't agree it's plays a role in an argument towards retro causality.
2. This is just like the temperature example I gave in post #15. Temperatures were very likely different in the 4 different seasons (different statistics), but that doesn't mean that revealing the season to me changed the weather.
1.The argument is not about retrocausality. It is simply a possibility.
2. And yet again, you have the analogy wrong. We're only discussing "winter" statistics when the switch is on versus the switch is off. It has nothing to do with "revealing the season".
thomsj4 said:
1. So the key point is that BSM doesn't create the perfect correlations between ##P1## and ##P4##, it reveals them.
2. The potential for these correlations is encoded in the initial entangled state ##\lvert \Psi \rangle_{1234}##.
3. The choice to perform the BSM (represented by ##\Pi_{23}^\mathrm{BSM}##) and the distinguishability of ##P2## and ##P3## determine which subset of the ensemble of ##P1## and ##P4## measurements will exhibit these perfect correlations.
4. Only after classical communication of the BSM result does the corresponding subensemble of ##P1## and ##P4## show perfect correlations.
5. The correlations were always present, it just required the proper measurement to make the correlations between ##P1## and ##P4## apparent.
Welcome to the discussion! :smile:
1. This concept is directly contradicted by co-author Zeilinger in an earlier paper. "We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4."
And it is also directly contradicted by standard theoretical grounds. When no swap is performed (and from the Ma paper):
"When Victor performed the separable-state measurement on photons 2 and 3, we find that entanglement between photons 1&2 and between photons 3&4 remained. These entanglements vanished when Victor performed the Bell-state measurement on photons 2 and 3. This is consistent with the entanglement monogamy relation."
In other words: Entanglement between 1&2 and 3&4 remains after a separable measure (no swap), and because of Monogamy of Entanglement 1&4 cannot be entangled if 1&2 are entangled - and vice versa.
2. It should be obvious that when there is no swap, there is no relationship whatsoever between the pairs 1&2 and 3&4 other than they start in the same |Φ> state. Your presentation of the |Ψ1234> is misleading: because for anything you say to be true, there would also need to be correlations with every entangled pair ever created in the same |Φ> state. There is no such relationship between different pairs in the same |Φ> state unless a swap is executed, in which case the 1&2 / 3&4 entanglement ceases. It's one or the other.
3. Not sure if you meant to say "indistinguishability" rather than "distinguishability". Regardless, we are selecting 4 fold coincidences for swap and no-swap using the same consistent criteria for the 2&3 results: VV or HH outcomes. That is the only "subset" under consideration, and it's not a subset so much as a fair selection criteria. We are selecting those data points only, and recording whether there is also 1&4 correlation or not. Perfectly normal for any scientific experiment.
4. This is a meaningless point. All scientific studies of correlations require the data to be brought together using classical communication. Or are you saying something changes when the data is brought together at a central point?
5. There is correlation when swap execution is chosen, no correlation when it is not. If there was always correlation waiting to become "apparent", then there should be no difference in the results for swap versus no-swap. But there is.
This is a different point. You could also argue temperature is not the same thing as polarization of course.
I think you already agreed above that the aggregate of all BSM results is the same as the aggregate of all SSM results. Do you still believe that? If so, then you must agree that any subset with particular statistics (including Bell violations) in one set is also in the other set, right?
Yes, but again you're post selecting a subset with a particular P23 result and ignoring VH/HV. If you could determine BEFORE the experiment that the result would be VV or HH then I'd agree with you. The point is that you can't, there are 4 different resulting states for each measurement type (in the Ma case I think they'd discarded half of those for technical reasons, so perhaps you're looking at something that was filtered to remove that 50% of the data). The aggregate of all BSM result includes all 4 Bell states and looks completely random AND the aggregate of all SSM results looks completely random. Only when you pick out subsets based on the BSM/SSM results do you see differences.
This is not contradictory. Please here me out. Zeilinger is testing entanglement within the subsets we've discussed, where there's a specific entangled state, e.g. phi- (a quarter of the aggregate data). Each P14 in this subset is certainly in this entangled state and no one is questioning that as far as I can tell. Everyone agrees this subset can show Bell violations, ....
What I think thomsj4 is saying is the same as what I'm trying to say: the aggregate of all the data is NOT in that entangled state. Furthermore, the aggregate of all the data is not even different swap/no swap (including all 4 measurement results in both cases).
Sounds like everyone agrees on this. The disagreement is apparently in the BSM case, the fact that aggregate of all results also shows no relationship either (only the post-selected subsets pick out correlations associated with specific Bell states).
I need to move on to other things, but I'd urge doubters to do the math thomsj4 showed or read carefully Ma or better yet Peres on "delayed choice entanglement swapping" -- might be clearer in the Peres paper.
  • Sad
No, it's not. Correlations that violate the Bell inequalities is an essential part of why we need QM to explain the entanglement swapping results--classical models won't work. The same is not true of temperature, so your analogy with temperature is fatally flawed.
No, that's not what I have agreed to. What I have agreed to is a much more limited claim.
No. That fact that the statistics of the particular subsets that are picked out by the four possible combinations of 2&3 results are not the same in the two cases is exactly the point of the much more limited claim I made. Are you reading my posts? Because it sure doesn't seem like it.
Yes, it is. I have already explained why this claim is wrong: particular subsets show Bell state correlations in one case (swap made) but not in the other case (no swap made). That also means that in the swap case, Bell inequality violating correlations are present that are not present in the no swap case.
I strongly suggest that you stop posting until you have read and considered the above enough to either agree with it (and therefore withdraw the claims you have made to the contrary in this thread), or take the time to find a reference that explains why it is wrong (which you won't be able to because it isn't). If you continue to make the claims you have been making, and continue to ignore the rebuttals you have received, you are likely to receive a warning.
thomsj4 said:
Distinguishability, however, destroys these perfect correlations
These two statements of yours contradict each other.
Yes, I believe the 5th equation in their thomsj4's post implies what you arr saying about aggregates.
I have some additional thoughts on entanglement swapping, I think.
Entanglement swapping is like a special case of quantum teleportation, no? i.e:
https://scholar.google.co.uk/scholar?cluster=201348324163392972&hl=en&as_sdt=0,5&as_vis=1
"Quantum physics predicts [1] that once particles 1 and 2 are projected into |ψ−>12, particle 3 is instantaneously projected into the initial state of particle 1."
And then the authors give the explanation next:
"The reason for this is as follows. Because we observe particles 1 and 2 in the state |ψ−>12 we know that whatever the state of particle 1 is, particle 2 must be in the opposite state, that is, in the state orthogonal to the state of particle 1. But we had initially prepared particle 2 and 3 in the state |ψ−>23, which means that particle 2 is also orthogonal to particle 3. This is only possible if particle 3 is in the same state as particle 1 was initially."
It appears to me this is entirely epistemic in the sense that all that is happening is that the conjunction lf the Bell state measurement and previous entangled state is allowing you to make an inference about the state of particle 3 through particle 1. The entanglement is a regular entanglement only possible due to an initial local interaction it seems; the Bell state measurement is also surely locally mediated. As entanglement swapping is just a special case of quantum teleportation, it seems to me we don't prima facie need any additional kind of non-locality beyond the regular kind which is entirely responsible for the quantum teleportation.
Entanglement swapping is nothing more than a juxtaposition or melding of two instances of this basic quantum teleportation scenario. Quantum teleportation scenario with particles 1, 2 and 3 is combined with another quantum teleportation scenario with particles a, b, c to make an entanglemet swapping scenario of particles c, 1=b, 2=a, 3 which then corresponds to the pairs that have been conventionally referred to in the forum as 1&2 (c, 1 = b) and 3&4 (2 = a, 3).
If you add a particle 4 to the previous described quantum teleportation with particles 1, 2, 3 mentioned in the quotes earlier (4 will be entangled to 2) - and then follow the reasoning of the quotes - it seems now that particle 1 is telling you about the states of both particle 3 and particle 4 (in conventional terminology of the forum this is then particle 2 telling you about both 1 and 4). We can also equally view this from the perspective of quantum teleportation scenario with particles a, b, c but adding particle d; particle a is now telling you things about particles c and d (conventional terminology this would be particle 3 telling you about particles 1 and 4).
Obviously, particles 1=b and 2=a (or 2&3 conventionally) are subject to a BSM and so are non-separable. In conventional terminology, we then just have this Bell state telling you information about 3 and 4. Surely then, conditioning on the Bell state, particle 3 is telling you directly about particle 4 and vice versa. Obviously, to do this does still require the coupling of 2&3. Its then an interesting coincidence that Mjelva (2024) suggests maximal Bell violations for 1 & 4 can be derived under this kind of consideration without 1 & 4 being explicitly projected onto a non-separable state (section 4), the basis of their claim that post-selection may be sufficient for entanglement-swapping phenomena - albeit this is a philosopher publishing in a philosophy journal:
https://scholar.google.co.uk/scholar?cluster=10636160464314492908&hl=en&as_sdt=0,5&as_vis=1
So ot doesn't seem to me that we need anything additional to the regular entanglement of 1&2 and regular entanglement of 3&4 to explain why the Bell state measurement results in the non-separability of 1&4, which is then only for a 1/4 subset of the original state. Combining all the subsets then results in a mixed / separable state with no correlations, consistent with the initial state. Based on the implications of the earlier two quotes in this post, entanglement swapping is epistemic, extending from the epistemic nature of quantum teleportation (at least this seems a tenable interpretation of quantum teleportation to me, once you take into account the contextuality / non-locality of regular entanglement). We are just learning about correlations in particles 1&4 that are unveiled in this particular network of systems when you condition on the non-separable Bell state measurement that couples 2 & 3 together in different subsets of the initial state.
https://arxiv.org/abs/quant-ph/0201134
iste said:
I suggest you read the post more carefully.
I agree with the relationship between entanglement (swapping) and quantum teleportation protocols, but I did not know that there is a bad relationship between non-locality and quantum teleportation protocols, in this paper I see the opposite. (Possibly what you say is true, I'm going to read your post more carefully, thank you)
I'm not saying there is no entanglement in 1&4, I am suggesting that you don't need anything to explain entanglement in 1&4 beyond the entanglements in 1&2, 3&4 and the Bell state of 2&3. From this view, entanglement in 1&4 is an emergent feature of those mechanisms without requiring some kind of additional element to cause the entanglement at 1&4 beyond the local interactions that caused non-separability for each of 1&2, 2&3, 3&4. The consequence is 2&3 is giving you information about both 1 and 4. So given 2&3, 1 is always telling you about 4 and vice versa, which might then be the resultant 1&4 entanglement.
iste said:
1. Entanglement swapping is like a special case of quantum teleportation, no? i.e: ...
2. the Bell state measurement is also surely locally mediated...
1. This is a wild goose chase. The subject has been laid out concisely, we're discussiong entanglement swapping from independent sources. Yes, you can say that quantum teleportation is a related form of entanglement swapping, and vice versa. But absolutely nothing is different operationally between the two. All of the same nonlocality is present, and there is no causal ordering requirement.
Suppose you teleport the unknown state of photon 2 to distant previously uncorrelated photon 4. You still have the problem how to explain the perfect correlation with photon 1 on a mutually unbiased basis to photons 2 & 3. In order words: the very act of teleportation is automatically nonlocal!
2. "Locally mediated" is a meaningless term here. The BSM overlap of photons 2&3 in the beamsplitter would naturally always be "local", otherwise they don't overlap (by definition). But the BSM itself is not local in any fashion to the observation of either photon 1 or photon 4.
Its not a problem because I never disagreed with that in the first place. 2 & 3 are entangled, and 1 was entangled to 2.
Well all I mean by locally mediated is that the BSM is a local interaction in the same way that the 1&2 and 3&4 entanglements were mediated by an initial local interaction.
iste said:
1. Its not a problem because I never disagreed with that in the first place. 2 & 3 are entangled, and 1 was entangled to 2.
2. Well all I mean by locally mediated is that the BSM is a local interaction in the same way that the 1&2 and 3&4 entanglements were mediated by an initial local interaction.
1. No, 1 and 2 and 3 are never entangled.
2. No, the BSM remotely switches 1&2 distant entanglement to distant 1&4 entangled. If there is no swap, that does not happen. Quite denying the obvious. Please seek an explanation that follows your preferred interpretation and explains this demonstrated behavior.
I never said this.
Didn't say anything that contradicts the basic description of entanglement swapping; maybe read the posts more carefully.
This is uncalled for. @DrChinese is making a valid point: the BSM interaction can only be viewed as "local" if we only look at photons 2 & 3, and ignore the fact that whatever happens or doesn't happen at the BSM also affects photons 1 & 4, which are not locally present at the BSM. In other words, the quantum system involved is all four photons, and that system is inherently not local--it is composed of spatially separated subsystems that are entangled. Waving your hands and saying "well, the interactions are all just local" does not address this point.
This is contradicted by the article: https://arxiv.org/pdf/quant-ph/0201134 (see page 3). If there is no BSM result, Victor can't demonstrate any correlation. If there are BSM measurements, but the results are thrown away and not given to Victor, he can't demonstrate any correlation.
If Alice observes any of the other Bell-states for photons 1 and 2, photons 0 and 3 will also be perfectly entangled correspondingly. We stress that photons 0 and 3 will be perfectly entangled for any result of the BSA, and therefore, it is not necessary to apply a unitary operation to the teleported photon 3 as in the standard teleportation protocol. But it is certainly necessary for Alice to communicate to Victor her Bell-state measurement result. This will enable him to sort Bob’s data into four subsets, each one representing the results for one of the four maximally entangled Bell-states
This is irrelevant. In any other area of science, nobody would throw away relevant data from an experiment and then claim that some effect wasn't present because the data didn't show it. Nor is @DrChinese claiming that the presence of entanglement between photons 1 & 4 can somehow be detected without knowing the photon 2 & 3 measurement results.
In fact, he is doing something worse; he is making the extraordinary claim, utterly unsupported by the cited experiments, that simply doing the 2 & 3 measurements changes the 1 & 4 results. In any other area of science, you don't get to claim that an effect is present without experimental evidence showing it. In every entanglement-swapping experiment, the 2 & 3 results must be transmitted to a third party and used to filter the 1 & 4 data before any correlation can be demonstrated. This is well-understood and entirely uncontroversial. There is no need to resort to wildly speculative fantastical explanations about an experiment at 2 & 3 remotely changing the 1 & 4 results without evidence.
Woops, I actually misread this; but, this phenomenon is what the post was addressing. You're teleporting from 2 to 4; you're teleporting from 1 to 3; ergo, there is a definite relationship between 2&3 and 1, and a definite relationship between 2&3 and 4. So you can infer there should be a definite relationship between 1 and 4. Different bases doesn't matter. We are dealing with three different entanglements connected to each other, in the kind of manner described in the second quote of post #43, with correlations in different bases. The measurements have to respect the correlations in these bases that define the entanglements - if you have states that are entangled with correlations in these bases, actual nor measurements counterfactual measurements are not going to be inconsistent with those states.
The experimental evidence certainly shows that choosing to do a swap or not do a swap at 2&3 affects the 1&4 measurement results: the subsets of 1&4 results corresponding to the four possible combinations of 2&3 results (HH, HV, VH, VV) show the predicted Bell state correlations if the experimenter chooses to do a swap; they show no correlations if the experimenter chooses not to do a swap. So the experimental evidence is that something is going on when a swap takes place at 2&3 that affects 1&4.
How can we say the subset "HH" when no swap occurs is the same subset as "HH" when a swap occurs? In other words, if the experimenter does no swap and measures both 2&3 photon polarizations to be "H", how can they say "If I had done a swap instead, the polarization of these photons would still have been "H"?
I'm not saying any such thing. I am just describing a straightforward procedure for running an experiment and analyzing the data. The math of QM makes a definite prediction for what will be found when that is done, and actual experiments match the prediction.
It is true that the math of QM does not make any claim about why the prediction is what it is, or why experiments match the prediction. If you are saying that some particular interpretation of QM makes the question you are asking relevant, what is that interpretation? What reference can you give for it?
Obviously you can't. So what? In any other area of science, nobody would bother asking such a question. The fact that such counterfactual "matching" cannot be done is not limited to QM.
Then, since the subsets are different, we can't say the BSM induces Bell-inequality-violationing correlations in any particular subset. We can only say the BSM lets the experimenter identify the appropriate subsets.
