Is 0.999... equal to 1?
  • Level: Undergrad
  • Thread starter Thread starter ram2048
290 replies · 32K views · last reply
uart said:
Hehe 1/3 = .333r(1/3), it just gets funnier. You mean 1/3 of 1/infinity there don't you RAM.
no. i mean Remainder 1 divided by 3
this expanded notation is part of the last calculated digit in a non-terminating series created by a rational fraction.
it is simply a way to create the true rational decimal value
it's detailed in the link... kinda (still prettifying the page)
you should care because the traditional way of viewing it leads to inaccuracies. such that something cut infinitely results in nothing.
it's fine by me if you want to embrace something that produces the wrong results due to fallacious logic.
go ahead
ram2048, I've been thinking about this and you've almost convinced me.
However there is just one little flaw that I see that you may be able to patch up. You are of the belief that [itex]\infty + 1 \neq \infty[/itex] Which means you must have some default value for infinity, for example: [itex]\infty_d[/itex] such that:
[tex]0.\overline{0}1 = \frac{1}{\infty_d}[/tex]
Am I correct so far? If so how do you define this [itex]\infty_d[/itex] and furthermore for this to hold true you must have a way of defining all other infinities right? Otherwise your system would just fall apart.
If you can show me this way of mathematically creating relationships of all infinites with one natural infinity and describe their mathematical relationship to real numbers then I will believe you :smile:
i'm not certain that [tex]0.\overline{0}1 = \frac{1}{\infty_d}[/tex] they are infinitessimals (someone used that words somewhere I'm just going to assume it's a real word) but the way they are defined and created are quite different, thus i don't think you can create and equality between them. let me consider.
cute but i doubt your sincerity :D
in any case, let's assume a default infinity to begin with. if all rational transforms upon that infinity result in a net positive gain then the resulting infinity is greater than the original and we will use a different notation for the new infinity [tex]\infty_e[/tex]. likewise were the transforms to result in negative "gain" then the resulting infinity would be less than the original infinity. let's use [tex]\infty_c[/tex]
we can accurately say [tex]\infty_c < \infty_d < \infty_e[/tex].
<crosses fingers for tex coding>
You have not defined the original infinity so how can you say that? Nor have you defined a relationship, for example would:
[tex]\infty_d - \infty_c = a[/tex]
Where a is some finite number and according to your system it would be a specific finite value, what would it be? Even if it is not a finite value according to your system it would be a specific infinite number, what would it be? I am of course assuming a > 0 under the system you have stated.
So I wonder would:
[tex]\frac{1}{{\infty_d}^{\infty_c}} = 0.\overline{0}n ?[/tex]
Where n is some finite digit? Or would this actually be 0?
Furthermore your notation is flawed, you are only going to have a finite amount of infinites where as I can think of an infinite number of ways to increase the value of a number. That's all the questions I can write down at the moment as I have to go, have at least another few dozen questions to see how your system works.
You ought to at least understand that hyper-real, or infinitesimal numbers, are not real numbers and so attempting tp cite them in defence of your ramblings of ignorance about the real numbers won't win you any arguments.
CHAPTER 3
Proof #1
In this proof they call upon a previously existing summation theorem that assumes to be correct and then proceed to apply the variables to come out with the conclusion. NO ONE can accurately sum any series to infinity to begin with. This entire proof stems from that fallacy.
Would you care to explain what you mean? Do recall that the DEFINITION of the sum of an infinite series is:
[tex] \sum_{i=0}^{\infty} a_i = \lim_{m \rightarrow \infty} \sum_{i=0}^{m} a_i[/tex]
As you correctly point out, one cannot directly add an infinite number of terms... which is why we're not silly enough to do it that way.
Proof #2
on the third line. x or .9999... is subtracted from both sides and the assumption is made that you will get an even number of 9 as the result.
Actually, it is fairly easy to do this in a perfectly rigorous way.. In the way mathematicians define things, the position of each digit in a decimal number is labelled by an integer.
To give a hint of the flavor of how things are done done, I'll ask you this question:
In what position does 0.999~ have a '9' that doesn't appear in 9.999~?
(again, let me remind you; by the mathematical definition, that position has to be an integer... and no integers are infinite)
Proof #3
something INFINITELY SMALL is never NOTHING.
Incorrect; zero is the only infinitessimal real number. FYI, the definition of "infinitessimal" is:
x is an infinitessimal if and only if |x| is smaller than any positive real number.
Since the decimal numbers are constructed so that they are a model of the real numbers, it follows that zero is the only infinitessimal decimal number.
Proof #4
Go ahead and do the division for yourself. One divided by three. .33333333~ forever. Where is it wrong?
It's not.
well three does not divide evenly into one no matter how many digits you take it to, so that remainder of 1 will always exist just as the digits will never terminate.
But, the way mathematicians define the decimals, they don't have remainders. So 1/3 is 0.333~.
so 1/3 would equal 0.33~ R1/3
So this begs the question, in your system, what is 1/3? We can keep substituting:
1/3 = 0.33~ R1/3 = 0.33~ R0.33~ R 1/3 = 0.33~ R0.33~ R 0.33~ R 1/3
but we'll never come to a satisfactory representation. :frown:
But consider a much more pressing issue; how can a remainder possibly make sense if we want a decimal representatino of &radic;2, or pi?
Also, allow me to suggest something for "fun". Let's assume for a moment that you actually have a well-defined and consistent number system.
Allow me to invent a new number system by decreeing that any two numbers that have the same decimal part are equal (even if they have different remainders), and furthermore I decree true any statement that can be proved from this decree. (So, for instance, 0.999~ = 1 because you've been able to prove 0.999~ R3/3 = 1 R0) I wonder what properties this number system has?
Hrm.
4/3 = 4 * 0.333~ R(1/3) = 1.333~ R(4/3)
4/3 = 1 + 1/3 = 1 + 0.333~ R(1/3) = 1.333~ R(1/3)
Problem...
i don't know that looks complicated. is it actually a real question or are you coming up with new inventive ways to waste my time? :D
Hurkyl said:
CHAPTER 3
Proof #1
Proof #2
shifting the decimal for such a number is tricky business because it causes an inequality in the infinities in both expressions.
Proof #3
i'm kinda going through this with someone in another thread at the moment as well and there is no satisfactory answer yet thus far. but expression 1 would have infinite 9's and expression 2 would have infinite+1 9's.
But consider a much more pressing issue; how can a remainder possibly make sense if we want a decimal representatino of √2, or pi?
the remainder is only used to create rational decimals for rational fraction values that would otherwise create non-terminating irrationals
the r(1/3) is not at the end of the series, rather it is part of the last digit. so you wouldn't be able to string it like that.
you could consider the last digit to be 10/3 rather than 3 <basically>
sounds like you're describing the current number system...
Hrm.
Problem...
you messed it up :D
4/3 = 4 * 0.333~ R(1/3) = 1.333~ R(1/3)
3x.333~ made 999~ the 3/3 completed the 1 which was part of the last digit 9. creating 10/10 that completes all the way to the top to make 1.
the process remainder is part of the last digit not after it.
You now need to share with us what you mean by a digit. How is something "part of a digit"
sorry if it wasn't clear enough.
when you divide out 1/3 each digit is created by a process of 10/3. each digit = 9/3 however. that 1/3 left over is the remainder I'm talking about.
You are correct, it is not clear. What do you mean when you use the word "digit"?
suppose i wanted to get the true decimal value of 1/3 (one divided by three)
i would start doing division (the tedious way)
[pre]
0.333~ r 1
3|1.0
[/pre]
each "digit" of 3 in the decimal notation resulting was created by dividing 10 by 3.
to use hurkyl's notation that he brought up
f(n)=0 where n ≥ 1
f(n)=3 where n < 1
those digits.
except in this case
f(n)=(10/3) where n = ∞
hope that formatting works
Ok, how is something "part" of a digit? Is not a digit a single bit of information how am I to interpret something as part of a single piece?
You have shown me how you generate digits but you still have not told me what a digit is.
okay... a digit(in base ten) is one integer of values 0 through 9 which exist in sequence to describe real numbers such that these digits multiplied by various powers of 10 can be summed to create the number they describe.
i'm going to assume that your follow-up question will be "if you just said the digit is integers 0 through 9 how can you have a digit that is 10/3"
the answer is, this is new notation
Can you state yourself in a precise way?
Here are two interesting questions for your system:
What is 9 + 0.99~?
What is 0.99~ * 10?
Can you even divine a difference in your system?
In the standard mathematical definition of decimals, the two are the same string of digits (and thus equal as decimals), because for every integer n, the digit in the n-th place in the first is equal to the digit in the n-th place in the second.
Mathematicians do study these kinds of things; they're called order types. There really is a way to rigorously say that a sequence has length "infinity + 1" (where "infinity" is the order type of the positive integers). However, there is no such thing as an "infinity - 1"; the problem is that in order to take things off of the end of an ordering, the ordering has to have an end.
Because the digits to the right of the decimal place are indexed by the positive integers (or negative, if you prefer), this ordering doesn't have an end from which things can be removed. This is why it is possible to left shift all of the digits and have "one more" than you started with. (Mathematically, it still has the same order type and cardinality)
You, like most others who have similar ideas, seem to be imagining an order type that does have an end. Now, if you were to define the decimals as having two groups of digits to the right of the decimal place, an "a group" and a "b group" so that the positions went like this:
| 1a, 2a, 3a, ... | ... 3b, 2b, 1b |
(where I've used pipes (|) to denote the boundary of a group)
then when you multiplied this new type of decimal by 10, you would indeed "lose" a digit off the right end; the 1b position would be filled with a zero.
Exactly right. :smile: I was trying to demonstrate that even if you did have a consistent number system with infinitessimals, you can recover a number system that behaves exactly like the standard mathematical system. The point is to show relative consistency; if you believe the standard system to be flawed, then your system must be flawed as well because your system can be used to create the standard system.
Here's a puzzler. If you are only introducing remainders in the case of dividing things, then what is e^(-ln 3)?
So once again what do you mean by part of a digit? You are going to need a better definition then simply saying it is notation. The ellipsis is simply notation, I can define it in a few words; it stands for a infinitely repeating pattern. Now what do you mean by "part of a digit" ?
You seem to have agreed that infinity must have some default value, which to me says that you have confused infinity with a large finite number, all of your work is consistent with that conclusion. If you replaced infinity with any large finite number all of your work would make sense and you would have little disagreement from anyone on this board.
Your belief that 1 - .999... >0 means that the interval (.999...,1) has a finite non zero length, thus there must be a hole in the real line at this point, are you saying that .999... is the hole? are there other holes? If there is a hole at .333... why is it that .1(base 3) exists is it not right in the middle of the hole that you have placed at .333...?
I think it is your system that is full of holes, it simply does not work. Your time would be better spent actually attempting to learn how the real number system works rather then trying to reinvent a square wheel. It's your time.
Consider this.
Choose any of the 9's in 0.999~.
Consider the 9 in the next position to the right.
This 9 gets shifted underneath the 9 you chose when you multiply by 10.
Thus, 9.999~ has a 9 in the same position as the 9 you chose in 0.999~.
If this argument holds for any 9 you choose, then we have proved that 0.999~ cannot have a 9 in a position that 9.999~ does not.
Again, this works because decimal numbers don't have right ends; each position has a next position to the right.
:rolleyes: Not trying to waste your time at all, just showing you that your system does not work at all ever. But let's go back to basics, you agreed that:
[tex]0.3\overline{3} = \sum_{n=1}^{\infty} \frac{3}{10^n}[/tex]
Well sorry to say but if you work that out using simple sums to infinity of geometric seris you get:
[tex]\sum_{n=1}^{\infty} \frac{3}{10^n} = \frac{1}{3}[/tex]
not if the flaw is inherent in the creation of the standard. eg: rounding processes.
i have no idea what that is. please explain -ln
i'm saying that because these numbers have infinity included in their nature the gaps between them are beyond human comprehension and can only be measured or described by "infinitessimal" notations.
yes but consider a static infinity.
let's say you have two numbers of .999. Each with [tex]\infty_d[/tex]
number of 9's as decimal digits.
you multiply one of them by 10.
compare the two. if they both have [tex]\infty_d[/tex] number of 9's still you have created a gap at the very end such that when you subtract the two there is not an integer result.
if you "create" another 9 (wackiness) then one has [tex]\infty_d[/tex]+1(9's) and the other has [tex]\infty_d[/tex]. hence they're using different infinities and the calculation is incorrect.
Well sorry to say but if you work that out using simple sums to infinity of geometric seris you get: [tex]\sum_{n=1}^{\infty} \frac{3}{10^n} = \frac{1}{3}[/tex]
sums to infinity are wrong which is what I've been trying to say forever now :D
Zeno's paradox is not obliterated by "sums to infinity" within the confines of the problem set forth it creates a true statement that the destination cannot be reached
go ahead
Math is a tool with which we can model the real world. Its of course necessary that the capabilities of the tool exceed the requirements of any concievable application.
What you see as a flaw in math is actually just part of its power and flexibility. But the problem of course, is that in order to get the correct answers from math, you have to use it correctly:
Not only do you see holes that aren't there, you're trying to patch them with a wire mesh. Yeah - it really would be better for you if you learned not only how math works, but how to use and apply it correctly.
Then you think [itex]0.\overline{3}[/itex] is inherently wrong anyway and thus this discussion is pointless.
If you think sums to infinity are wrong you must then believe that we have got values such as [itex]e[/itex], [itex]\pi[/itex] and [itex]\sqrt{2}[/itex] wrong. Please tell use how you define such values.
It's straightforward to show that this methodology is consistent; the "danger" is that it might wind up just saying that everything is equal.
ln is the natural logarithm (LN, but lowercase)
If you can measure or describe them by infinitessimal notations, doesn't that place them in the realm of human comprehension? :smile:
Something needs clarified here; are you saying that the real numbers has holes, or just the decimal numbers (whatever you think the decimal numbers are)?
I can't; I don't know what a "static infinity" is... but from
I'm assuming you mean an order type that has an end. As I stated, if you are using an order type that has an end, then this argumentat is correct. However, this argument fails when the order type has no end. Since there is no last integer, the decimals as they are mathematically defined has no end, so your argument fails.
Are you disagreeing with the claim that
[tex] \lim_{m \rightarrow \infty} \sum_{n=1}^m \frac{3}{10^n} = \frac{1}{3}[/tex]
? Or are you disagreeing with
[tex] \sum_{n=1}^{\infty} \frac{3}{10^n} = \lim_{m \rightarrow \infty} \sum_{n=1}^m \frac{3}{10^n}[/tex]
disagreeing with
[tex]\sum_{n=1}^{\infty} \frac{3}{10^n} = \lim_{m \rightarrow \infty} \sum_{n=1}^m \frac{3}{10^n}[/tex]
that.
the sum will never equal its limit because infinity is infinite
when you say .333 that's a sum when you say 1/3 that's its limit
i'm sure I'm not saying it correct but it should be correct enough to understand.
.333 approaches 1/3 but never reaches it.
.999 approaches 9/9 but never reaches it.
ps> i have no knowledge of how to perform logarithmic calculations and don't have a sci calc handy (not that it would help since i wouldn't know what to put into begin with..)
Ahh well that clears it up, you simply don't understand what infinity, a limit, a sum to infinity or a recurring decimal is.
Ok, then this is one precise point where we differ.
Mathematically, [itex]\sum_{n=1}^{\infty} a_n[/itex] means [itex]\lim_{m \rightarrow \infty} \sum_{n=1}^m a_n[/itex]. (i.e. it's neither a theorem nor an assumption; this is how an "infinite sum" is defined)
ah so i have to work at getting that abolished first then eh?
because it makes no logical sense that the sum of a convergent series equals it's limit when the very definition of convergent means it will never reach its limit.
so there we go.
