Is 0,999999.... actually equal to 1?
  • Context: High School
  • Thread starter Thread starter entropy1
The mathematical expression 0.999999... is definitively equal to 1. This conclusion is supported by the limit of the infinite series represented as lim_{n \to \infty} sum_{k=1}^n (9/10^k), which evaluates to 1. The discussion emphasizes that limits are exact values rather than approximations, and it is crucial for educators to correct the misconception that limits approach a value. The equivalence of 0.999999... and 1 is a well-established fact in mathematics, often demonstrated through various proofs.
  • Understanding of infinite series and limits in calculus
  • Familiarity with mathematical notation and concepts such as cardinality
  • Basic knowledge of real numbers and their properties
  • Experience with mathematical proofs and reasoning
  • Study the concept of limits in calculus, focusing on lim_{n \to \infty} and its implications
  • Explore proofs that demonstrate the equality of 0.999999... and 1, such as algebraic manipulations
  • Investigate cardinality and its significance in set theory, particularly in relation to infinite sets
  • Review common misconceptions in mathematics education and effective teaching strategies
Mathematicians, educators, students studying calculus, and anyone interested in the properties of real numbers and infinite series.
entropy1
Is 0,999999... actually equal to 1, or does it approach 1?
This is mathematics, so before we give an answer I ask you: what is your definition of ##0,9999\dots##?
This has been discussed a thousand times on this forum. I suggest to perform a forum search. The keyword 0.999 should do.
I would say something like the limit of n to infinity of ##\lim_{n \to \infty}\sum _{n}\frac{1}{9\cdot 10^n}##.
Ok. Figures. Will do.
\lim_{n \to \infty} \sum_{k=1}^n \dfrac{9}{10^k}=9\cdot \sum_{k=1}^\infty \dfrac{1}{10^k}=9\cdot\left( \dfrac{1}{1-\dfrac{1}{10}}-1\right)=1
And limits (if exist) are numbers, and numbers do not approach anything, they just are.
As an aside note: unfortunately quite a lot of students use that improper phrasing, that is "limit approaches something"... Teachers should emphasise that it is incorrect. I always do.
You can read other proofs of this too. When you subtract the infinite digits because those infinite digits do not end in a digit, they can be subtracted, so it is correct according to the definitions of infinite sums and their subtraction. If they ended in a digit 9 then 0.9 would remain but they do not end.
So the possible wrong doubt is about the correspondance of the digits subtracted, but the correspondance is for infinite digits of 9 not finite. When x=0.999... and 10x=9.999... the 10x contains as many infnine digits of 9 after the dot as x does. So does 100x or 100000000x or generally kx where x is a mulitple of 10.
kx, where k is a multiple of x contains the same infinite amount of 9s as x because that amount of 9s has the same cardinality as N, the set of natural numbers does i think. It is not a different kind of cardinality like Cantor showed with sets like R or I or Q i think. Is this correct?
Without getting into the mathematical technicalities of the infinite representation, here is one way of thinking about it.
If they are different, how large is abs(1 - 0.999...)? No matter what number you pick, it is easy to show that the true difference is smaller than that.
The question has been answered and there are already existing threads, too, so this one will be closed.
  • · Replies 44 ·
11K
  • · Replies 20 ·
  • · Replies 18 ·
