Is 0<d,l<1 equivalent to writing separately 0<d<1 and 0<l<1 ?
  • Context: High School
  • Thread starter Thread starter FortzaParis
    Equivalent Writing
The expression "0 PREREQUISITES
  • Understanding of mathematical notation and inequalities
  • Familiarity with scientific writing conventions
  • Knowledge of set notation, specifically interval notation
  • Experience with clarity in technical communication
  • Research the use of interval notation in mathematical writing
  • Explore best practices for clarity in scientific communication
  • Learn about common conventions in mathematical expressions
  • Investigate how to effectively convey complex ideas in concise formats
Researchers, mathematicians, and anyone involved in scientific writing who seeks to enhance clarity and precision in their expressions and notation.
FortzaParis
Is "0<d,l<1" equivalent to writing separately "0<d<1" and "0<l<1"?
Dear all, I'm writing a paper for a scientific journal and I need to save as much typographic space as I can. In a proposition, I need to specify that the parameters "d" and "l" assume values between zero and one. I am wondering if (in scientific writing) is it correct to write "0<d,l<1", instead of writing separately "0<d<1" and "0<l<1". Thanks!
Mathematics news on Phys.org
I've been using the shorthand form like that for years now, and no professors of mine have ever complained about it. In fact, from my recollection, I've seen some professors use the short form while others don't.
The way I see it, if it is clear to the reader and doesn't need moments to be deciphered, it's good enough to use.
Thanks, Mentallic!
I would personally interpret that as 0<d and l<1, but I don't know if this is common. The comma seems to separate the two statements "0<d" and "l<1".
What about d,l \in (0,1)?
I also would tend to interpret "0< d,l< 1" as "0< d< 1" and "0< l< 1" or "both d and l are between 0 and 1". If you mean 0< d and l< 1, grammatically, you should have the word "and" between them, not a comma.
How would one interpret the sentence "0<d, l<1 and p>3"?
This is probably an insignificant issue, but grammatically commas are used to separate things.
I tend to agree with HOI here, but the context does matter. If this was part of a statement that disregardthat proposes, I would lean the other way.
But if there was no listing of relations, and the comma appeared instead of an and, there would be no reason to write something that way unless you meant what the OP intended.
I often write ##0<d,l<1## to mean ##0<d<1## and ##0<l<1##. I've also seen it in a lot of mathematical texts, so I guess it's standard.
I agree with micromass, it (or in equivalent circumstances) is used regularly in school level maths
Dear all, thanks for the suggestions! I think I will write d,l \in (0,1) so that there is no possibility of misunderstanding.
Personally, the reason I wouldn't interpret it like that is because it would be a very odd way to do it.
0<d,l<1 is a quite commonly used expression, while it's very uncommon to put the variable of an unbounded inequality on the right side. 0<d would most often than not be d>0.
  • · Replies 55 ·
  • · Replies 0 ·
  • · Replies 33 ·
