Is 2√(7)+4 an Irrational Number?
  • Topic:
  • Thread starter Thread starter nycfunction
    Rational
nycfunction
See picture for question and answer.
  • Typeset text with three lines: "Is 2√7 + 4 rational or irrational?" then "The answer is irrational." then "Can the reason be that it is a continued decimal number?"
Mathematics news on Phys.org
What, exactly, do you mean by "continued decimal number"? If you mean simply that it is not a terminating decimal, a rational number such as 1/3 has that property. That's not the reason $2\sqrt{7}+ 4$ is irrational.
First, the rational numbers are "closed under subtraction and division" so if $x= 2\sqrt{7}+ 4$ were rational so would be $\sqrt{7}= (x- 4)/2$. And if $\sqrt{7}$ were rational then there would exist integers, a and b, with no common factors, such that $\sqrt{7}= \frac{a}{b}$. From that $7= \frac{a^2}{b^2}$ and $a^2= 7b^2$. That is, $a^2$ has a factor of 7 and, since 7 is a prime number, a has a factor of 7. a= 7n for some integer n so $a^2= 49n^2= 7b^2$. Then $b^2= 7n^2$ so, as before, b has a factor of 7, contradicting the fact that a and b has no factors in common.
HallsofIvy said:
What, exactly, do you mean by "continued decimal number"? If you mean simply that it is not a terminating decimal, a rational number such as 1/3 has that property. That's not the reason [tex]2\sqrt{7}+ 4[/tex] is irrational.
First, the rational numbers are "closed under subtraction and division" so if [tex]x= 2\sqrt{7}+ 4[/tex] were rational so would be [tex]\sqrt{7}= (x- 4)/2[/tex]. And if [tex]\sqrt{7}[/tex] were rational then there would exist integers, a and b, with no common factors, such that [tex]\sqrt{7}= \frac{a}{b}[/tex]. From that [tex]7= \frac{a^2}{b^2}[/tex] and [tex]a^2= 7b^2[/tex]. That is, [tex]a^2[/tex] has a factor of 7 and, since 7 is a prime number, a has a factor of 7. a= 7n for some integer n so [tex]a^2= 49n^2= 7b^2[/tex]. Then [tex]b^2= 7n^2[/tex] so, as before, b has a factor of 7, contradicting the fact that a and b has no factors in common.
See attachment.
  • Two typed lines: A. By continued fraction I meant to say non-terminating decimal. B. Can you explain in layman terms why 2√7 + 4 is irrational?
