Is a Circle Homeomorphic to a Subset of R^n?
  • Context: Graduate
  • Thread starter Thread starter joao_pimentel
    Circle
The discussion revolves around the question of whether a circle is homeomorphic to any subset of R^n, particularly focusing on the properties of path connectedness and compactness in topology. Participants explore various approaches and reasoning related to this concept, including attempts to construct mappings and analyze the implications of removing points from the circle and subsets of R.
  • Some participants propose that a circle cannot be homeomorphic to a subset of R^n due to differences in path connectedness.
  • One participant suggests a mapping from a closed interval to the circle but struggles to prove its homeomorphism.
  • Another participant emphasizes the importance of path connectedness and asks for clarification on its implications for homeomorphism.
  • Some argue that removing a point from the circle maintains path connectedness, while removing a point from a closed interval does not.
  • There is a discussion about the implications of compactness and connectedness being preserved under homeomorphisms.
  • Participants explore the idea that if a homeomorphism exists, the properties of the sets involved must align, leading to contradictions when comparing the circle and subsets of R.
Participants generally agree on the notion that path connectedness is a crucial factor in determining homeomorphism, but multiple competing views and approaches remain regarding the specifics of the proof and reasoning involved.
Limitations include the participants' varying levels of understanding of topological concepts such as path connectedness and compactness, as well as the incomplete nature of the mathematical arguments presented.
This discussion may be useful for students and enthusiasts of topology, particularly those interested in the properties of homeomorphisms and the distinctions between different types of topological spaces.
joao_pimentel
Hi,
how can I prove that a circle it is not homeomorphic to a subset of R^n
I can somehow, see that there isn't any homeomorphic application, for example between a circle in R^2 to a line, but how can I prove it?
Thank you
what have you tried?
Let a C be a circle, radius r
C=\left\{ x \in R^2 : |x|=r \right\}
Let A be a subset of R between a and b, i.e. A=[a,b)
A bijective map could be f:A\rightarrow C
f(t)=\left(r \sin\left(\frac{2\pi(t-a)}{b-a}\right), r \cos\left(\frac{2\pi(t-a)}{b-a}\right)\right) \ t \in [a,b)
i can't go longer :(
Are you trying to show S^{^{1}} is not homeomorphic to any subset of \mathbb{R}? If so, then think about path connectedness.
Yes, that's it!
Can you be more precise please in your answer?
Thank you
joao_pimentel said:
Yes, that's it!
Thank you
We have to see some attempt of you first. We don't just give away the answers like that.
Think about path connectedness and what happens if you remove a point.
joao_pimentel said:
Yes, that's it!
Thank you
Before we move any further, let's make sure you know what path connectedness is. Have you dealt with this property of topological spaces before? If you do then Micromass gave you the crucial idea so think about what he said.
To be honest I am not that aware what path connectedness is!
My knowledge on topoligical spaces, is not very deep!
Though, I've been reading, do you mean this
http://en.wikipedia.org/wiki/Connected_space#Path_connectedness
Ok, using what I found in wikipedia, a continuous function f from [0,1] to the circle radius 1 could be
f(t)=\left(\sin\left(2\pi t\right), \cos\left(2\pi t\right)\right) \ t \in [0,1]
so, I know what you mean (intuitevely) that a circle is always connected, and a line is not, but I don't know how to express it mathematically
Can you kindly help me?
Thank you
Yes that is what I meant by a path connected topological space. Firstly, note that since S^{1} is both connected and compact, if it were to be homeomorphic to a subset of \mathbb{R}, it would have to be a closed interval so we can just focus our attention on that. Can you see intuitively what happens differently, in terms of path connectedness, between [a,b]\subset \mathbb{R} and S^{1} if I removed a point from each?
Here's another approach. suppose that the circle is on a plane. Naturally we will get a definition of clockwise and anti-clockwise. Then imagine that there is a homeomorphism between the circle and a line. So now take a point on the circle and continuously move clockwise until you return to the same point. The image of this path should start and end at the same point. This corresponding path will have to intersect itself otherwise it would never have returned to the same point. So take one such point of intersection. This would imply that such a point has two corresponding points on the circle. Therefore the homeomorphism does not exist since its co-image at some point on the line contaims more than one point.
Not really very rigorous, unless you're going to talk about fundamental groups.
Hi, sorry my delay, I've been thinking.
If I remove a point from each, we wouldn't have a connected path, I suppose nor it would be a closed interval...
@poverlod
Thank you very much :) I think I saw it, but still don't get it :) Can't I miss the last point, i.e. can't I make a map without the last point?
f:A \rightarrow B
f(t)=(\sin(2\pi t),\cos(2\pi t)) \ t\in [0,1)
why this map is not hemeomorphic if I remove the last point?
Sorry and thank you very much for attention
Given [a,b]\subset \mathbb{R}, take some c\in (a,b) and consider [a,b] \setminus \left \{ c \right \}. Will it always be possible to find a path between any two points in [a,b] \setminus \left \{ c \right \}? On the other hand, take some p\in S^{1} and try to convince yourself intuitively (and explain to me your reasoning of course) that it will be possible for S^{1}\setminus \left \{ p \right \}.
ok, I see that it will not be possible to find a path between any two points in [a,b] \setminus \left \{ c \right \} because there will be a 'hole' in the line
I see also that it will be possible for S^{1}\setminus \left \{ p \right \} because it will be possible 'to find a path around', i.e., there will always exists a path between any two points...
though, I must confess, I can't see the relation with homeomorphism, a continuous map, whose inverse is also continuous.
Thank you so much
Yes you've got the intuition. The point is to assume there exists a homeomorphism between the unit circle and a closed subset of R and to use the aforementioned difference between the unit circle and a closed subset of R to find a contradiction.
ok, so we assume that there is a homeomorphism between the unit circle and a closed subset of R, and then as we remove a point, we have a connected path in the circle and we don't have it in the subset of R.
But what is the relation between path connectedness and homeomorphism?
AHH, ok, the map must be continous! Is that?
Please just confirm it!
Thank you
João
ok S^1 is compact, i.e., closed and limited and the line would have to be if there were a homeomorphism between both.
On the other hand, if I remove a point, I wouldn't have a compact set, on both, but one is still conncted and the other is not.
And I suppose, that if one is path connected, and there is a homeomorphis to another set, the other set must be path connected...
and then we have a contradiction...
Assume there is a homeomorphism h between S^1 and E , where E is a subset
of the real line. Since connectedness is a topological property--i.e., connectedness
is preserved by homeomorphisms ( continuous maps will do)-- h(S^1) is a connected
subset of the real line. Then h(S^1) is an interval ; by compactness of S^1 (which must be preserved by h), h(S^1) is also compact in the real line, it then follows by
Heine-Borel, h(S^1) is closed and bounded in the real line , so h(S^1)=[a,b].
Now, if h is a homeomorphism, the restriction of h to any subset of
S^1 is a homeomorphism (into its image). Consider x in S^1 with h(x) not an endpoint , i.e.,
h(x)≠ a,b; say h(x)=c . Now consider the restriction of h to S^1 -{x}. This is
a homeomorphism from the connected space S^1-{x} to the disconnected space
[a,b]-{c} . This is not possible , so no such h can exist.
Moral of the story/ general point: disconnection number is a homeomorphism invariant.
Thank you so very much :)
It might be fun to try to prove this by approximating a homeomorphism of the circle in R^n by a sequence of smooth maps to see how far off from a diffeomorphism the homeomorphism can get. the image of a smooth approximation must have measure zero so it can not produce a homeomorphism between the circle and euclidean space.
  • · Replies 20 ·
  • · Replies 61 ·
  • · Replies 54 ·
