Is a Constant Force Always Conservative?
1 replies · 2K views
zoner7
none...
Suppose a force acts on an object. the force does not vary with time, nor with the position or velocity of the object. Start with the general definition of work done by force, and show that the force is conservative
W = FX
Wnonconservative = KE final PE final - KE initial - KE final
I started with W = FX
W = E final - E initial
E = KE f + PE f - KE i - PE i
W = 0 + PE f - O - PE i Since KE is a non-conservation force and there is only a conservative force.
W = PE f - PEi Since PE f = PE i if PE is a conservative force
w = 0
The answer doesn't make any sense... Any suggestions?
on Phys.org
Hi zoner7,
zoner7 said:
none...
Suppose a force acts on an object. the force does not vary with time, nor with the position or velocity of the object. Start with the general definition of work done by force, and show that the force is conversation.
W = FX
This line not true. Saying that KE is a non-conservative force is not true.
I would suggest you start with some definitions. What is the general formula for the work done by a force? And also, what is the definition of a conservative force?
