I Is a Locally One-to-One Proper Map Globally Bijective?
  • I
  • Thread starter Thread starter Ashley1209
    Continuous
Ashley1209
TL;DR Summary
φ is a continuous, proper and locally one-to-one map.Is it a globally one-to-one map?
Welcome to PF.
Please remind us of what a proper map is. IIRC, it had something to see with inverse image of compact sets being compact?
WWGD said:
Welcome to PF.
Yes, inverse image of compact sets being compact.And the map is between two topological discs.
This looks like a school textbook problem. For those, you must show work in a certain format. We are not supposed to give more than hints on your work.
do you know about covering spaces?
Likes lavinia and WWGD
1) Take a rubber band and twist it into a figure 8.
2) Take a rubber band and push two oppose points together to make a figure 8.
Keep pushing so that the rubber band intersects itself in two points.
Try the same idea with a sphere.
Yes.Does this have something to do with covering spaces?
All coverings are continuous and locally 1-1. If the covering space is compact then the covering map is also proper.
For instance, take a finite discrete set and map it onto one of its points.
re: Lavinia's post #6, 1), can you visualize z --> z^2, for complex z: |z| = 1?
and I guess a continuous map between "nice" spaces (locally compact and Hausdorff?) should be a finite covering map if and only if it is a local homeomorphism, surjective and proper.
In fact since a continuous bijection of compact hausforff spaces is a homeomorphism, maybe even a locally bijective proper continuous map of locally compact hausdorff spaces is a finite covering of its image. So if "one to one" means "bijective", as it sometimes does, then this is why I was thinking of covering spaces as soon as I heard proper, continuous and locally one to one. I.e. that is essentially equivalent to "finite covering".
Likes Ashley1209 and lavinia
