Is a matrix non-diagonalizable if it has fewer distinct eigenvalues than its size?
  • Level: Undergrad
  • Thread starter Thread starter Este
    Eigenvalues Matrices
6 replies · 17K views
Este
Hello,
Is it sufficient to determine that a nXn matrix is not diagonalizable by showing that the number of its distinct eigenvalues is less than n?
Thanks for your time.
You should empirically test your hypothesis; try it out on the simplest matrices you can imagine.
For example, how many distinct eigenvalues does
[tex]\begin{bmatrix} 1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1\end{bmatrix}[/tex]
have?
Ok I got your point...I think the question should be now, how to check whether a matrix is diagonalizable or not?
A theorem I've encountered in my textbook:
Theorem 3: Suppose that A is an nXn matrix and that A has n distinct eigenvalues, then A is diagonalizable.
and somewhere else I read this is sufficient to prove a matrix is diagonalizable but not the other way around.. that's why I posted the question..
So now, all I can do is to prove that Matrix x is diagonalizable, but if it's not, I can't tell for sure...what other methods should I be using?
Thanks for your responses.
The most direct way to tell if a matrix isn't diagonalizable is to try and diagonalize it.
Yes- sufficient but not necessary.
An n by n matrix is diagonalizable if and only if it has n independent eigenvectors. Since eigenvectors corresponding to distinct eigenvalues are always independent, if there are n distinct eigenvalues, then there are n independent eigenvectors and so the matrix is diagonalizable. But even if the eigenvalues are not all distinct, there may still be independent eigenvectors.
[tex]\begin{bmatrix}1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1\end{bmatrix}[/tex]
as I pointed out before has the single eigenvalue 1 but is already diagonal because <1, 0, 0>, <0, 1, 0>, and <0, 0, 1> are independent eigenvectors.
[tex]\begin{bmatrix}1 & 0 & 0 \\ 0 & 1 & 1 \\ 0 & 0 & 1\end{bmatrix}[/tex]
also has 1 as its only eigenvalue. Now, <1, 0, 0> and <0, 0, 1> are the only eigenvectors so this matrix cannot be diagonalized.
Finally,
[tex]\begin{bmatrix}1 & 1 & 0 \\ 0 & 1 & 1 \\ 0 & 0 & 1\end{bmatrix}[/tex]
also has 1 as its only eigenvalue but now only <1, 0, 0> and multiples of that are eigenvectors.
Great! Things are pretty clear now, thanks HallsofIvy!
