Is All Human Reasoning Circular?
  • Thread starter GTdan
    Circular
50 replies · 16K views · last reply
There's no such thing as "false knowledge", it's simply not knowledge.
Similarly, there's no such thing as "False Logic" by virtue of it being emotional, it's simply not logic.
GTdan said:
Is all logic/reasoning circular?
Consider this: Science uses experimentation and physical evidence (logic, reasoning, and the senses) to prove or disprove a hypothesis, theory, or judgment. The hypothesis/theory/judgment, however, was made by using logic/reasoning/senses.
What do you take proving something to mean? It sounds like you are saying that if you walk from X to Y, you have walked in a circle because there was a time at which you were not walking.
You learned how to reason just like you learned how to walk. (You might have learned to reason in a large part by learning your native language(s) as a child.) Do you assume that reasoning is anything more than just pushing things around, be they abstract symbols, electrons in a circuit, or ions in your brain?
Following some set of rules to get from one sentence (or thought) to another sentence is not necessarily circular just because the rules themselves might happen to be sentences.
You can find two rocks on a path and beat them together to make one a chisel and then use the chisel to make the other into a chisel and then break the first chisel into two pieces and use the second chisel to make chisels out of the pieces, and so on. That doesn't change the fact that you started with two rocks.
Maybe you are wondering where logic and reasoning originate.
If your point was more about the relationship between a language and its metalanguage, that can be cleared up as well, but it takes a bit more work.
We essentially "created" human logic and reasoning. By using logic and reasoning to prove theories that were created by our own logic and reasoning, are we really proving anything at all?
So you are disturbed by the fact that your conclusion follows from premises? That is what a conclusion is. Perhaps you are expecting a conclusion to be absolute in some way. If so, you are expecting too much from it. You have to start somewhere, or yes, you cannot get anywhere, not even in circles.
Gödel's incompleteness theorems states
"For any consistent formal, computably enumerable theory that proves basic arithmetical truths, an arithmetical statement that is true but not provable in the theory can be constructed. That is, any effectively generated theory capable of expressing elementary arithmetic cannot be both consistent and complete. 1"
While the theorem deals with math it applies to all rational constructs. All rational constructs ultimately rest on axioms and as such these constructs cannot prove their own axioms/themselves. These constructs are said to be consistent with themselves but are incomplete in that they cannot prove themselves.
My understanding is a logical system can be made complete if it's situated within a context of other system(s). For example, the scientific method heavily depends on mathematics(which depends on other constructs, which also depend on other constructs, etc...) and vice versa. The issue here is it becomes an infinite regression of constructs. So which do you prefer? Circular but consistent or Infinitely regressing but complete?
No it doesn't. It only applies to
consistent formal, computably enumerable theories that prove basic integer arithmetical truths.​
Those are the hypotheses of the theorem, and thus are the only things that this theorem can prove incomplete.
The elementary theory of Euclidean geometry and the elementary theory of real number arithmetic are notable examples of consistent formal, computably enumerable, complete theories. (In fact, they are essentially the same theory)
Furthermore, I'm fairly certain that there exist consistent formal theories that can prove their own consistency. (which, of course, requires that the theory fails to include integer arithmetic, or that it fails to be computably enumerable)
No, they are said to be incomplete in the sense that there exists a statement in its language that it can neither prove nor disprove.
IMHO, the main contribution of this theorem is that such a thing can be done, so it's worth seeing what else might be incomplete, not that it says anything about anything else.
At some point, you have to reach axioms. I don't know of any such infinite regression. If you try to force it, you'll just end up restating stuff.
True enough, however the nature of axioms are universal regardless of what construct they are used in.
I'm just an armchair thinker here so you'll have to forgive my lack of in depth experience with either one of those. My understanding is it's impossible to have a construct be both simultaneously complete AND consistent due to the fact that all constructs rest on axioms. It's just the nature of the relationship we have with reality. We can clearly see that 1 + 1 = 2, and use that as an axiom to build up the construct consistently however you can't use that construct to prove that 1 + 1 = 2, since the construct assumes that it's true already. In the end it would be like saying 1 + 1 = 2 therefore 1 + 1 = 2.
A theory can prove it's own consistency, it just can't be complete at the same time.
True enough
True, the thing is it applies to all axiomic systems. Basically everything.
In a consistent system you end up where you started. What can be done is the axioms can be pawned off to another construct to test it's provability(out of the box so to speak). The problem with this is the other construct itself rests on axioms(whose own axioms can be pawned off to another construct that rests on axioms to infinity).
I don't have any experience with this however an earlier conversations noted to me that the infinite nature of number set theory illustrates this as well.
And I'm telling you that your understanding is incorrect.
The content of Tarski's theorem1 is that the elementary theory of real arithmetic2, or equivalently the elementary theory of Euclidean geometry, is simultaneously consistent complete, consistent, and computably enumerable.
An easier theorem is to prove that any consistent theory can be extended to become a complete, consistent theory. From this it follows that there does exist a consistent and complete theory of integer arithmetic. (so, by Gödel's theorem, the completion must not be computably enumerable)
And that's a perfectly valid proof.
Do you have a reference for that? I can't seem to find one.
1: alas, there are a few that go by this name, and Wikipedia doesn't have an entry for the one I'm talking about
2: if you want a buzzword to start investigating, try real closed field.
I fail to see how this doesn't rest on unproveable axioms(e.g 1 + 1 = 2).
Maybe I'm not interpreting the Godel's incompleteness theory correctly but all math is essentially sitting on unproveable givens(as apparent as they can be).
It's a perfectly valid observation, a perfectly valid observation but you can't "prove" its validity by using mathematics(since mathematics simply assumes it's true). You can only observe it. As such it's proof lays outside of the formal system in direct observation.
It's just Kantian philosophy. It's not specific to mathematics.
Interesting stuff, I just may have to try and wrap my head around it.
It seems like "proof" is being used in more than one way. To some people, an axiom is a proof of itself, so there is no such thing as an "unproveable axiom".
What do you take "proof" to mean? Logic and mathematics have defined the term for themselves already. You seem to be using a different meaning.
Also, a deductive system doesn't even need to have any axioms. You can have rules that allow you to deduce sentences from "nothing" (or the empty set).
I'm talking about proving somethings existence using a formal system without being circular.
The process of deduction introduces givens that aren't neccasarily proven. Assumptions about our relationship to reality, logic, etc...
So you are talking about a formal proof, then? How about the following definition?
Definition. If L is a formal language and F is a set of L-formulas, a proof of an L-formula fn from F is a non-empty finite sequence of formulas f1, f2, ... fn such that, for each fi, at least one of the following is true:
1) fi is an axiom
2) fi is in F
3) fi follows by your rules from some combination of L-formulas occurring earlier in the sequence.
There's no point in continuing to use words whose meanings aren't agreed on, yes?
What is "the process of deduction"? A proof? What is a given? An axiom? Are you again claiming, with different words, that there exist unprovable axioms?
What formal deductive system says anything about reality? Formal deductive systems don't actually "say" anything in the usual sense. If you want to interpret them as making promises that they cannot keep, that sounds like it's not their problem. :smile:
And how is that a response to my comment? You seemed to have problems with axioms, so I thought it might be helpful to point out that you don't necessarily need them.
I suppose this thread might be on the way back to "but how do you know that your deductive system(/your rules/your car/the key to a lock) works?".And by the bye, what exactly is wrong with being circular in the sense of having your conclusion be one of your premises, besides perhaps usually being a waste of time?
1) fi is an axiom
2) fi is in F
I'm not talking about a proof. I'm talking about proof as in being able to prove it.
I agree, it was probably a mistake to bring Godel's theorem into this. What I'm talking about here isn't particular to Math.
A given is something that seems to be readily apparent and is assumed to be true. An axiom is considered a given yes.
I assumed people would be ok with me using the term axioms outside of mathematics. Myth of the given seems to be the more appropriate phrase when talking generally. A deduction begins with a premise which is the given. We can split hairs here but it's essentiallly the same thing.
There's nothing wrong with it, I was just pointing out that it's not neccasarily circular because the givens can then be validated from another perspective(which also rest on givens)
What do you mean by "to prove" if you don't mean "to provide a proof"?
yougene said:
What do you mean?
=P
Look, all logic relies on definitions. A logical statement must have defined components. They are "defined", therefore they rest on axioms. You cannot have logic without conventional methods of reasoning. Nevertheless, reasoning doesn't have to be circular.
claim 1: A therefore B
claim 2: B therefore C
result: A therefore C
A, B, and C
But just because A, B, and C are true, does that really mean that A therefore B, and B therefore C?
Suppose we know these:
fact 1: A therefore B
fact 2: B therefore C
Then by knowing that A is true, then we can know that B and C are true. But knowing A, B, and C is not the clincher that establishes A therefore B, and B therefore C. Ways to make this estabilished (in the sciences) involve making it acceptable by the (scientific) parties involved with the subject. This is done groupwise.
An example of circular reasoning is this:
I don't have a job because I don't have any skills.
I don't have any skills because I didn't go to school.
I didn't go to school because I didn't have any money.
I didn't have money because I didn't have a job.
Circular reasoning can be used to describe viscious and virtous circles. They are valid arguments and can describe our natural world, yet they are circular.
So don't think of circular reasoning so negatively. They can and do make logical descriptions of reality. On the other hand, is all reasoning circular?
Well if there is a strict uni-directional casuality between A and B, then the system can be described without circular reasoning; actually it must not involve circular reasoning. For example:
fact 1: There are only two one pound balls on a given weight scale.
result: There are two pounds on this weight scale.
However, you cannot determine that there are two one pound balls simply by knowing the weight on the scale. Therefore sound circular reasoning concerning this is impossible. Circular reasoning is avoided when one reasons from the specific material to the general material, since you cannot logically deduce something specific (e.g. the two balls each weighing a pound on the scale) from a generality of what exists (e.g. the two pounds on the scale).
I can assure you that not all logic is circular. Also, we do not necessarily arrive a definition of words through deductive reasoning but often through trial an error (e.g. discovering what is a "cow"). Begging the question can be certainly avoided by avoiding deductive reasoning and sticking with inductive reasoning.
Turn A, B, and C into a real statement, digg down deep enough, and you'll end up where you started.
I have nothing against circular reasoning I find it rather useful.
The problem with that is we never ever directly experience the two balls or the scale. Our experience of the other is always mediated through the mind(culture, constructs, etc..). As such all similar thinking is laid down on assumptions that we hold about our relationship to the outside world. Once you start digging deep enough in the foundations of your reasoning, you start running in circles.
I'm still confused about why you consider the axioms to be any more or less "provable" than the other theorems that you derive from them. All that a proof of Q from P says is that Q follows from P by your rules. From outside, a proof of Q from P doesn't give you Q. It gives you a proof of Q from P.
And why this relation (you can view syntactic and semantic consequence as relations just like any other relations) should bother someone more than other relations (does anyone have a problem with equality?) also escapes me.
I consider them on equal footing.
How do we get P? And how did we get that? and so on?
I don't have a problem with it. I was just discussing the limitations of only being able to observe reality through mediated constructs. That's not saying the rational pov is a mediating construct and the pre-rational pov is not. All of our experience of the outside world is mediated.
Well, outside of the system, you don't get P. You can get a proof of P from P (and so on).
Oh. Roger.
Well, that is perception for you, I guess.
GTdan said:
:smile:
Maybe I am asking about truth. Can we really find truth using the system of logic we have created?
Logic depends on premises. Within the context of those premises you can determine if something is true or false. Similarly one could argue that one would have to know the initial state of a given system to be able to state any 'absolute' truth about it. As to how that applies to 'reality', this is why knowing how the universe began is important.
