- 4,023
- 2,072
- TL;DR
- Using diffusion MRI, they reconstructed the brain connectomes of 123 mammalian species. Network analysis revealed that both connectivity and the wiring cost are conserved across mammals.
This paper was published in Nature: Mammal Brain Connectivity
And was described by the University in this press release: https://www.aftau.org/press-release---brain-connectivity---july-20-2020
What interests my is the editorial spin:
From the press release:
From the Abstract:
Cajal and "widespread conjecture" notwithstanding, I have never had any expectation that the basic component technology in the human brain was any better than any other mammal. In fact, I would not be surprised if a few component enhancements are found in a much smaller species - for example mice.
Here is my take:
It's all about evolution and circuitry. It's hard to evolve any system one small change at a time. So step one would be to evolve it in an evolvable direction - tending towards modularity. Then later, small changes can have narrow results. If a small change is made in one place, it will not be at the cost of destroying other parts of the system.
With a nervous system, this become problematic. It needs to be modular, but any change is likely to create a system-wide compatibility problem.
For example, once I have established a communications protocol - say RS-232 at 1Mbaud - I would have to make matching changes to the transmitter and receiver to improve it - two exactly complementary changes in a single mutation - very unlikely. So, if the system is to be evolvable, it needs to have fairly tolerant components. Ex, a transmitter and receiver that can operate at a range of current levels and baud rates.
But that is just a communication link. What about the encoding of basic notions (thoughts) and the subsequent processing of that data? There will be some system-wide standards (such as how notions are encoded) that will be effectively set in stone for the entire evolutionary future of an organism. As the data processing becomes more elaborate, more and more subsystems will depend on these standards and the only avenue for changing the standard will be extinction and replacement. In other words: starting over.
How would you get "big improvements" when the evolutionary process is such a burden? Answer: Lot's of experimentation: lots of time; big populations; small gestation periods; lot's of competition during that gestation period. Mice have it over people, paws down.
Then how would you evolve a person - in 66 million years, populations in the thousands; gestation period of little more than a decade? You start with something like a mouse that has evolved a good basic nervous system - one that has evolved to be adaptable through evolution. Then you create variations on that theme: language areas that works off existing audio and socialization circuits; analytical areas that work off the language. Stuff like that.
The intriguing results, contradicting widespread conjectures, revealed that brain connectivity levels are equal in all mammals, including humans.
From the Abstract:
Over 100 years ago, Ramon y Cajal hypothesized that two forces played a role in the evolution of mammalian brain connectivity: minimizing wiring costs and maximizing conductivity speed.
Here is my take:
