Is Brass Magnetic: Debunking the Myth
  • Thread starter iknownth
  • Tags
    Magnetic
In summary: Ferrous alloys don't have to be magnetic to be used in things like this, they just need to be strong.And there are ferrous alloys that aren't noticeably ferromagnetic either. Marine grade stainless steel is a good (and expensive) example.
Chemistry news on Phys.org
"Because brass is not ferromagnetic, it can be separated from ferrous scrap by passing the scrap near a powerful magnet."
This sentence seems contradictory.
Not ferromagnetic but can be separated near a magnet?? What does it mean??
You remove the ferromagnetic and you're left with the brass? Plus the gold, aluminium, tin etc. of course, which gives you a different problem.
I'll take the gold, so you have one problem less.
The ferromagnetic material is picked up by the magnet, leaving the non ferromagnetic material behind.
There is a brass alloy that is slightly magnetic. It has 1-2% of iron in it. It used to be used quite often for coating ships bottoms to prevent critters from attaching themselves. As far as I know it's not used anymore.
It won't really stick to a magnet though other than with a real slight attraction. I.E. you can't pick a piece of it up with a magnet. You can hang a small piece of it from a thread and move a good magnet close to it and see movement from it due to the magnetic field but it's very small amount of movement.
What is brass?
Brass is a metal alloy made primarily of copper and zinc.
Is brass magnetic?
No, brass is not magnetic. It is considered a non-ferrous metal, meaning it does not contain iron and is not attracted to magnets.
Why do people think brass is magnetic?
This misconception likely comes from the fact that brass is often used in musical instruments, which may contain small amounts of iron or steel for reinforcement. This can cause the brass to be slightly attracted to magnets, leading people to believe it is magnetic.
Can brass be made magnetic?
No, brass cannot be made magnetic. It is a non-magnetic material and cannot be altered to become magnetic.
Are there any types of brass that are magnetic?
No, all types of brass, regardless of their composition or production method, are non-magnetic.
  • Electrical Engineering
  • DIY Projects
  • Classical Physics
  • STEM Career Guidance
