Is Chromoly the Ultimate Material for Racing Car Chassis?
  • Thread starter Thread starter raniero
    Chassis Formula
The discussion centers around the search for academic literature on the use of chromoly (41xx) and high-strength steel (HSS) tubes in racing car chassis, specifically for space-frame designs. Participants express a need for published scientific papers that delve into the material properties, advantages, and disadvantages of chromoly compared to other materials.
  • Homework-related
  • One participant seeks journal articles for a literature review on chromoly and HSS in racing car chassis.
  • Another participant references NHRA regulations regarding the design and welding of cage structures, emphasizing safety standards.
  • Some participants mention a new steel called DOCOL, suggesting it may offer advantages over chromoly due to its strength and welding requirements.
  • A participant clarifies the need for published scientific material rather than general articles, expressing frustration over the lack of in-depth discussions on material properties.
  • One participant suggests using Google Scholar for more targeted searches, indicating that focusing on automotive journals may yield better results.
  • Concerns are raised about the limited availability of scientific literature on chromoly, with some participants expressing skepticism about finding substantial academic resources on this material.
Participants generally agree on the difficulty of finding in-depth scientific literature on chromoly and HSS for racing chassis. However, there is no consensus on the availability of substantial academic resources, with some expressing hope and others feeling discouraged.
Participants note limitations in their searches, including the challenge of finding detailed discussions on material properties and the potential applicability of research from aeronautical structures.
raniero
I am in search for journal articles/papers regarding the use of chromoly (41xx) or HSS tubes in racing car chassis (space-frame) for a literature review.
I wasn't able to find any papers up till now. Any help is greatly appreciated.
I would start with NHRA regulations, specifically sections 4:4, 4:10, and 4:11.
http://www.nhra.com/UserFiles/file/General_Regulations.pdf
NHRA Regulations said:
All cage structures must be designed in an attempt to protect the driver from any angle, 360 degrees. All 4130 chromoly tube welding must be done by approved TIG heliarc process; mild steel tube welding must be approved MIG wire feed or TIG heliarc process. Welding must be free of slag and porosity. Any grinding of welds prohibited.
This also looks like a pretty good article: http://www.hotrod.com/how-to/chassis-suspension/1402-building-a-racecar-chassis-tech/. They have some interesting information in there about different materials including a new steel called DOCOL.
Keep in mind, stronger materials are typically used for weight savings because you can use thinner tubes; but in some cases they have other drawbacks (Chromoly for example requires special welding processes). Sounds like this DOCOL tubing is the best of both worlds in that respect.
What I meant by articles is published scientific material, I am able to find plenty of ordinary articles about chromoly, but I haven't been successful in finding academic, published, scientific papers. I require published material for my dissertation.
I did a quick search in Google Scholar and found a few relevant results, maybe take a look there? Honestly I don't think you've been searching "intelligently" enough, try focusing on journals focused on automotive or vehicle design.
Google Scholar Search: 4130 space frame chassis
Thanks for your help.
I have found similar articles/papers before I posted, but I am in search for papers with more in depth discussions about the actual material advantages/disadvantages, testing and comparison to other materials. These articles just barely skim on material details, usually chromoly is just mentioned followed by the reasons (stronger, cheaper and easier to be welded than other metallic alloys).
I need more specific papers to be able to produce a good literature review. I suppose papers treating aeronautical structures would also be valid to a certain extent.
I believe articles/papers about the use of low alloy steel or HSS for racing chassis would also be applicable.
That could be as good as it gets . Why do you think that there is going to be any great body of scientific information about a relatively nondescript steel ?
Nidum said:
That could be as good as it gets . Why do you think that there is going to be any great library of scientific papers about a nondescript steel .
I kind of lost hope of finding material in greater detail, I will have to see how to go about my literature review now.
  • · Replies 19 ·
10K
