Is dark matter a sea of massive photons?
The discussion revolves around the concept of dark matter and its potential connection to massive photons, exploring theoretical implications and challenges. Participants examine various models, including scalar-vector-tensor theories of gravity and the implications of photon mass on dark energy and dark matter.
  • Some participants question whether the "missing mass" associated with dark matter could be attributed to the mass of photons displaced by matter.
  • Others argue that the concept of "massive photons" is nonsensical, asserting that photons are inherently massless.
  • A participant references a paper discussing massive photons and dark energy, noting concerns about the underlying theory of gravity being ruled out by experimental evidence.
  • Some suggest that even if photons had a small mass, they would primarily account for hot dark matter (HDM) rather than cold dark matter (CDM), which is necessary for large-scale structure formation.
  • There is a discussion about the implications of scalar-vector-tensor theories of gravity and their consistency with experimental data, particularly in relation to solar system tests.
  • Participants express uncertainty about the modifications to quantum electrodynamics (QED) versus general relativity (GR) in the context of the theories being discussed.
  • Some participants express skepticism about the viability of the Tensor-Vector-Scalar (TeVeS) theories, while others defend their relevance in ongoing research.
  • Concerns are raised about the compatibility of TeVeS theories with observations, particularly in relation to the Bullet Cluster and the necessity of dark matter in explaining certain phenomena.
Participants do not reach a consensus on the validity of massive photons as a model for dark matter, nor on the effectiveness of TeVeS theories. Multiple competing views remain regarding the implications of photon mass and the theoretical frameworks being discussed.
Limitations include unresolved questions about the definitions and implications of photon mass, the validity of various theories of gravity, and the experimental evidence cited by participants. The discussion reflects a range of interpretations and assumptions that are not settled.
BobbyHurley
Is the "missing mass" the mass of the photons connected to and neighboring the matter which are displaced by the matter?
Space news on Phys.org
This doesn't even make sense. There is no such thing as a "massive" photon. Photons are massless.
I can't make any sense out of this sentence but I'm sure the answer is no.
Massive Photon and Dark Energy
https://arxiv.org/abs/1512.00541
I have not read the paper in detail, but one thing strikes me from the abstract: it is using "the scalar-vector-tensor theory of gravity", which AFAIK is ruled out by experiment unless the "scalar" and "vector" parts are given coupling constants so small as to be negligible. So even though a photon mass is used which is smaller than the current upper bound from experiment, this theory still seems to me to have a problem because of the theory of gravity that is used.
BobbyHurley said:
Could the "missing mass" associated with dark matter actually be the mass of the particles displaced by the matter?
I still can't figure out what you mean by that. What particles displaced by what matter?
We can do a bit better than that with the original question.
Photons are generally thought of as massless although some heterodox theories such as that discussed in Massive Photon and Dark Energy suggest they may have a small mass:
the nonvanishing photon mass of the order of 10 - 34eV is consistent with the current observations. This magnitude is far less than the most stringent limit on the photon mass available so far, which is of the order of m<=10 - 27eV.
Let us limit our discussion to that paper, which should focus, amongst other things, on the status of the "the scalar-vector-tensor theory of gravity". Peter have you a reference(s) to your statement that it "is ruled out by experiment unless the "scalar" and "vector" parts are given coupling constants so small as to be negligible"?
Garth
I am not sure, but even if photons had a mass below the excluded by experiment region let's say 10^{-27}eV, then the photons are still supposed to be radiation (under cosmology), so at best they could account for HDM and not CDM.
But the paper discusses whether photons with a small mass could explain Dark Energy not Dark Matter.
The original question was confused, yes, and if such photons are thought to be DM, not DE, then that, as Hot Dark Matter, has been ruled out. Basically HDM wouldn't clump as required to form the obsertved large scale structure.
So the question remaining is, "Can photons with a small mass explain Dark Energy?"
Garth
I'm going by what I have seen in textbooks such as MTW, which IIRC discusses this in some detail. As I remember it (don't have my copy handy to check), various solar system tests, such as light bending by the Sun, rule out significant scalar or vector terms in the Lagrangian. The paper that the OP linked to talks about comparisons with cosmological data, but does not talk at all about consistency with other data such as solar system tests.
ChrisVer said:
even if photons had a mass below the excluded by experiment region let's say ##10^{-27}## eV, then the photons are still supposed to be radiation (under cosmology), so at best they could account for HDM and not CDM.
I agree if we are using GR as our theory of gravity. The paper the OP linked to talks about a different theory of gravity, a "scalar-vector-tensor" theory, which can produce different behavior of photons, theoretically speaking. However, as I've noted in other posts, I don't think that theory of gravity is consistent with other experimental data (such as solar system tests).
I am not sure about this. The introduction seems to say that it is QED that is modified, not GR:
The theory consists of massive vector field and Stuckelberg scalar field interacting with Einstein gravity.
Yes, I saw this, but elsewhere they say they are using a "scalar-vector-tensor theory of gravity". It also looks to me like the effective Lagrangian they are using contains terms involving the curvature other than the Einstein-Hilbert term. So I think that by "Einstein gravity" they just mean "a spin-2 tensor field", not "exactly GR". But I am not familiar with the field theories they are drawing on and probably need to spend some time with the references in the paper to increase my background knowledge.
The TeVeS theories were proposed after MTW was published and are not inconsistent with solar system tests, papers can be found here: The Tensor-Vector-Scalar theory and its cosmology and A tensor-vector-scalar framework for modified dynamics and cosmic dark matter except, as that latter paper proposes, the MOND increase (over Newtonian/GR gravity) of gravitational sun-wards acceleration at large radii in the outer solar system would be interpreted as a Pioneer type anomaly.
Basically the scalar and vector terms of TeVeS, and indeed in \LambdaCDM DE, are too small to be detected at small solar system distances and only become significant over 'large' ranges so they only would become detectable by Pioneer in the outer Solar System.
Papers are still being submitted about MOND/TeVeS theories such as on today's ArXiv: Dynamics of Elliptical Galaxies with Planetary Nebulae in Modified Newtonian Dynamics and Highly compact neutron stars in scalar-tensor theories of gravity: Spontaneous scalarization versus gravitational collapse so it is not yet a dead duck!
The Bullet Cluster poses a greater problem for TeVeS theories as investigated here: Asymmetric gravitational lenses in TeVeS and application to the bullet cluster with the conclusion that
TeVeS cannot explain observations without assuming an additional dark mass component in both cluster centers, which is in accordance with previous work.
So Dark Matter is still required in some form, although perhaps not to explain galaxy rotation rates.
Garth
@Garth: Interesting papers, I'll take a look! I am not very familiar with this area of research.
I still think TeVes is a mathematical cluster of hooey.
I agree but some might say that about the \LambdaCDM theory, what with the undiscovered dark sector, the coincidence problems - \Omega_M \sim \Omega_\Lambda, \Omega_m + \Omega_{DM} + \Omega_\Lambda = 1 , Age of Universe = H-1, and built on GR which has proved so far incompatible with quantum theory.
I think there is enough wriggle room to ask questions about it all.
Garth
Agreed, Garth, apologies for being unnecessarily rigid.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 34 ·
  • Featured
