Is Distance/space Lorentz contracted?
  • Level: Graduate
  • Thread starter Thread starter Austin0
    Lorentz
84 replies · 14K views · last reply
Originally Posted by Austin0
SO I ask ; just looking at a Minkowski diagram of the FR system at a given moment do you see any geometric difference between it and an inertial frame?
I saw
PeterDonis said:
I saw this on reading through your last post again, and I wanted to comment on it, because there might be another point of misunderstanding lurking here. You can't change the geometry by changing reference frames. The "geometry" is a fixed, four-dimensional object. For example, in the scenario we've been discussing, the "geometry" is Minkowski spacetime. This is a definite four-dimensional object, which is the same regardless of what coordinates we use ("station frame" or "ship frame") to label points on it, just as the Euclidean plane is a definite two-dimensional object, regardless of what coordinates we use ("Cartesian" or "polar") to label points on it.
So when you ask if there is any "geometric difference" between the "ship frame" and an inertial frame, the answer is that of course there isn't: the geometry is the same no matter what frame you choose, just as the distance between New York and Chicago is the same no matter what coordinate system we use for the surface of the Earth. The geometry may "look different" with different coordinates, just as the surface of the Earth "looks different" in a Mercator projection than it does on a globe. But that's not because of any change in the geometry; any invariant, such as the distance between two points on the Earth's surface, or whether two events are simultaneous to a given observer in Minkowski spacetime, will be the same no matter what coordinate system we are using. It is the invariants that really constitute "the geometry", not the particular coordinates we assign in particular reference frames to events.
How does all that relate to what we've been discussing? Well, consider the statement we're having trouble agreeing on:
* Events R99 and F100 are simultaneous in the station frame, but they are *not* simultaneous in R's frame at R99, or in F's frame at F100.
The reason they are not simultaneous to R at R99 or to F at F100 is simple geometry: if we draw R's line of simultaneity through event R99, that line will *not* pass through event F100, and if we draw F's line of simultaneity through event F100, that line will *not* pass through event R99. Both of these facts follow from the fact that R and F are moving relative to the station frame at events R99 and F100; their motion means that their lines of simultaneity through those events are "tilted" up and to the right compared to the station frame's line of simultaneity, which is horizontal and passes through both R99 and F100 (because those events *are* simultaneous in the station frame).
In short, R's line of simultaneity through event R99, and F's line of simultaneity through event F100, are *different lines*. That is a geometric fact, an invariant, and no amount of jiggering with coordinate systems can change it, just as no amount of jiggering with coordinates on the Earth's surface can change the fact that the Equator and the Tropic of Cancer are different lines. So it doesn't matter how you try and construct a "ship frame" for R and F; as long as the geometry of Minkowski spacetime is what it is, you can't make R99 and F100 simultaneous to R and F, because you can't make two different and distinct lines coincide by changing reference frames.
Hi PeterDonis There is no question that the scope of my ignorance is vast.
On the other hand I have some grasp of area of discussion, .:smile:
SO I am afraid you have been flogging a dead horse in this case.
Here I asked a very simple and specific question and it appears that somehow you have interpretated it into indicating having no idea whatsoever of the function of coordinate systems or Minkowski space in particular. In the same post you are referring to here, I gave specific instances of the application of Lorentz desynchronization. Specific responces to your earlier post regarding this. SO if you think my application is wrong that is fine , simply show me. But it is not that we disagree that it would occur.
It seems to me that we need to know our respective interpretations of the meaning of lines of simultaneity or we are going to have confusion as to what we are talking about?
What do you think? thanks
Austin0:
I apologize if I've given a wrong impression; I'm sure I've been saying much more than I needed to about how the mechanics of SR work. But some of the things you've been saying have suggested to me that you either don't really know or aren't ready to accept just how much those mechanics constrain the situation we're talking about. That's why I wanted to make absolutely sure (a) that I was stating everything explicitly and correctly, in a way you agreed with, even the simple stuff, so we'd be certain to have a common understanding of the scenario; and (b) that you were willing to accept SR as a valid theory. You've said you are; that makes everything a lot easier.
You said:
1) Length contraction. The math gives a complete description of the quantitative effect between inertial frames but does not provide predictions regarding accelerating frames.
and you later on made similar comments about other aspects of SR, such as clock desynchronization. All of these comments are incorrect. The math *does* provide predictions regarding accelerating frames, because of the clock postulate. At any event on an accelerating worldline, we can define a "momentarily comoving inertial frame", or MCIF; this is just an inertial frame in which the accelerating object, at that event, is momentarily at rest. The clock postulate then tells us that *all predictions about what would be observed in the MCIF at a given event, are also predictions about what will be observed by the accelerating observer at that event.*
By the above, since events R99 and F100 are not simultaneous in R's MCIF at R99, or in F's MCIF at F100, they are not simultaneous in R's and F's "accelerating frame" either. That's all there is to it.
(Btw, when I said in my last post that the geometry doesn't change with a change of reference frame, that it's a fixed, four-dimensional object, and that if the two lines of simultaneity are distinct in one frame, they are distinct in all frames, I was trying to say the same thing I just said above in different words. All these things tie together in a logical whole.)
Before I go any further, I'd like to have your input on what I've just said. Bear in mind where I'm coming from: what I've just said is a logical consequence of SR, which you've said you accept. The general principle I gave, on how to deal with accelerating observers, is not something that's just added into the rest of SR, and could be changed while holding the rest of the theory fixed; it's logically linked to a lot of other things, and all those other things would have to change if the principle changed. (For example, I don't see how you could possibly change the rules for accelerated observers to make events R99 and F100 simultaneous in the "ship frame" without also making them no longer simultaneous in the station frame--this is another way of saying what I was saying above about the geometry being fixed.)
That principle is also essential for constructing the general theory of relativity--without it, GR would not work. It also has been experimentally confirmed to a high degree of precision; check out the two links I gave in post #28, which I'll give here again (I admit that in post #28 I didn't really make them stand out):
http://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html"
http://relativity.livingreviews.org/Articles/lrr-2006-3/"
Also, the Usenet Physics FAQ has a short page on http://math.ucr.edu/home/baez/physics/Relativity/SR/acceleration.html" .
Re: Is Distance/space Lorentz contracted?
Austin0:
This iseems like a case of pulling statements out of context , reinterpreting them and then declaring them wrong.
The complete context was:
I say that because my operative assumption is:
That the Lorentz math, the gamma function in it's various applications ,is a valid description of the physics of motion as it occurs in the real world.
Eg. JesseM's assertion that it is not an inherent result of motion and would not occur in a uniformly accelerated system. I am not making any judgement regarding the reality of this , only pointing out that this is an area of speculation, not merely applying known principles of SR
Eg. JM's assertion that acceleration would have no effect on clock synchronization.
Would you disagree that this is a speculation on the mechanics of clock desynchronization?? Physics.
____________________________________________________________________________
So maybe you would like it better in the form.
The Lorentz math provides a complete description of the quantitative effect of contraction which would seem to apply through the clock hypothesis but JesseM has asserted it does not apply
The math provides a complete description of relative clock desynchronization but it has been asserted that this does not apply..
It was not my assertion or my belief that they would not apply. I made that even clearer in a previous post..
(3) Acceleration to relativistic velocities is *not* "without empirical input". For example, every particle accelerator that's ever been built has subjected huge numbers of subatomic particles to huge accelerations and relativistic velocities, and those particles have exhibited *every* phenomenon that relativity says they should: time dilation, length contraction, clock desynchronization, the whole enchilada. We also have tested relativity with macroscopic objects: the GPS system, for example, wouldn't work if our understanding of both special and general relativistic effects on orbiting objects in the Earth's gravity well were not correct.
Response Austin0 I was aware of particle acceleration and the effects regarding dilation. But would be very interested to learn of the results regarding clock desynchronization as it relates to particles. Actually I have searched for information about particle bunching on the net but have found only references but no explicit explanation regarding how it relates to Lorentz contraction. Any links?
If there is observable clock desynchronization does that indicate that it is not a matter of clock convention but is an intrinsic result of acceleration?
Again i made that statement in the context of this discussion. I had made specific references before to electromagnetic acceleration of macro rods and tubes, we are talking about systems of clocks and rulers. DO you really think I could not be aware of the muon results etc etc etc etc or that I could possibly doubt their validity?
____________________________________OK certainly no disagreement over ICMIF's. But my memory is that the postulate goes far beyond that. Besides asserting that there would not be any dilation due to acceleration itself, it basically said that the Lorentz maths would apply on an instantaneous basis as usual.
Well you seem quite sure but I don't get how you jumped from the simple assumption of an MCIF to events not being simultaneous..
My understanding of lines of simultaneity is: They accurately graph relative clock times and locations between frames. That the intersections with the rest frames coordinate locations have direct spatial and temporal interpretation for both frames. And that observers will always agree on these events.
Exactly as if observers with clocks were actually present and cojacent in both frames. That multiple lines of simultaneity for disparate locations in a frame are simply different segments of a single continuous line which is actually congruent with the x' axis The slope being merely a result of convention. The Minkowski version of JesseM's clocks and rulers. So I don't quite see why you seem to think that they would in some way indicate loss of simultaneity within the frame itself but maybe i am not understanding what you are saying.
This is exactly the reason I specifically asked you if you agreed that the instantaeous diagram at the moment of colocation with the stations was geometrically identical to, [indistinguishablefrom] a diagram of an inertial frame and you agreed that it was. In that case it is axiomatic that from the stations perspective the ships [or ship] are going to be out of synch.[not simultaneous] and that the ships are going to disagree. It is also axiomatic ,explicitly stated in the fundamental postulates that there is no real or absolute temporal meaning to either view. That there is no real meaning to any evaluations of simultaneity regarding spatially separated events between two frames.
I also fail to understand how if the geometry is the same you could from this geometry derive completely different conclusions from the normal ones?
So if you want me to agree [as it appears] that the simultaneity of the stations is the real true, simultaneity and that therefore it is obvious that the ships simultaneity is false ,well I have a real problem with that as it goes completely against my understanding of the basic postulates.
So if you would care to let me know what you mean by simultaneity and how you interpret lines of same it might be helpful. Or how you see my understanding is in error.
In my mind this complete question is much more complex and this query was only an attempt to get new insight into a limited aspect of it.
It involves fundamental physics as it applies to the Lorentz effects ,acceleration ,clock theorem, EP , Born acceleration .
And the question of explaining the anisotropic time dilation as described by the Rindler implementation of Born acceleration as being due to relative velocity between the front and the back. An explanation apparently in response to the conflict between the implicit dilation due to acceleration, and the clock postulate.
So I have a simple question for you. Do you know that the physics as we know it supports the idea that a constantly accelerated rod or spring would not only sustain significant compression or expansion, but that this would continue to increase over time without an increase in acceleration rate. And further would be a permenant condition after the termination of acceleration?
I do know that I have read both engineers and physicists who did not agree.
What do you think about the apparent conflict between the Rindler dilation and EP ?
If it is assumed that Einsteins elevator has relatively dilated clocks at the floor then, over time, the proper time discrepancy wrt the ceiling clocks would have to increase and the measurement of light speed would become increasingly anisotropic. Registering greater and greater speeds from the ceiling to the floor and lesser the other direction.
Thanks
Austin0:
I do agree with you that there are plenty of complexities in how to handle accelerated objects in relativity--but the scenario I've been discussing doesn't address them. For example: it does not address Born rigidity or Born acceleration; it does not address the complexities involved with Rindler coordinates or Rindler observers, or what happens to the speed of light in accelerated frames; it does not address any of the actual physics of how objects respond to stresses, such as the stresses imposed by acceleration. All of that stuff is irrelevant in this particular scenario, because those complexities involve how we determine the worldlines of the observers we're interested in, and in the above scenario, we've already specified those worldlines (they're specified by the condition that both observers experience the same constant proper acceleration, but are separated in space, in the station frame, by one "station separation"). And once you've done that, in any frame, in Minkowski spacetime, you have already implicitly answered every question that can be asked about how any observer would observe events on those worldlines.
I'm not unwilling to discuss all the other complexities; I'm just not ready to discuss them until we have agreement on the simple scenario I specified above, and in particular on the proposition that we currently don't seem to agree on. The simple scenario involves nothing except relativistic kinematics, and without agreement on that, the complexities will never fall into place.
Let me briefly restate the scenario: we have a line of stations, numbered 1, 2, 3, etc., and we have two observers, R and F, who start out at adjacent stations (#1 and #2) and both experience the same constant proper acceleration. Define Rn as the event at which R passes station #n (n >= 1), and Fn as the event at which F passes station #n (n >= 2). We are discussing the proposition:
* In R's frame, or in F's frame, events Rn and Fn+1 are *not* simultaneous, for all n > 1. (They *are* simultaneous for n = 1--i.e., R1 and F2 are simultaneous--because those events happen at t = 0, when R and F are at rest in the station frame. But this is the *only* such pair for which that is true.)
I'll explain how in a moment.
That multiple lines of simultaneity for disparate locations in a frame are simply different segments of a single continuous line which is actually congruent with the x' axis.
This is *not* correct. Distinct lines of simultaneity indicate distinct, different clock readings. Consider the two lines of simultaneity we've been talking about, which I'll define names for as follows:
S-Rn: R's line of simultaneity through event Rn, with n > 1.
S-Fn+1: F's line of simultaneity through event Fn+1, with n > 1.
These two lines of simultaneity are parallel--they have the same slope--but they are not the same line. You appear to agree on that. But that means that, in either R's MCIF or F's MCIF, the clock readings associated with S-Rn and S-Fn+1 are *different*. They have to be, because they intersect the t-prime axis (the "time" axis of either MCIF) at different events. If we did a Lorentz transformation into either R's MCIF at Rn (making Rn the new origin), or F's MCIF at Fn+1 (making Fn+1 the new origin), only one of the two lines of simultaneity, S-Rn (for R's MCIF) or S-Fn+1 (for F's MCIF), would coincide with the new x-axis; the other would *not*. It would be parallel to the new x-axis, yes (indicating that it was a line of constant time, as expected), but it would be either *above* the new x-axis (if we transformed into F's MCIF at Fn+1) or *below* the new x-axis (if we transformed into R's MCIF at Rn).
So, by the above, the events Rn and Fn+1, with n > 1, *cannot* be simultaneous in R's or F's MCIF, because in either MCIF they lie on different lines of constant time, and will be assigned different time coordinates. Therefore, by the clock postulate, they can't be simultaneous in R's or F's accelerated frame either.
You observed that I haven't yet described how things look from the accelerated frame; that's true. But I don't need to in order to prove that events Rn and Fn+1, n > 1, can't be simultaneous in that frame (for either R or F). And if we're not in agreement on that proposition, any description I give of how the accelerated frame looks will seem wrong to you, because I'll be basing it on the truth of that proposition. I have no choice, because the proposition I've stated, as I've said, is a logical consequence of relativistic kinematics, so it has to figure in any description of how things look from an accelerated frame.
Original post Austin0
Hi PeterDonis Well here seems to be an area where I may be wrong in my understanding of lines of simultaneity.
Before going into how I am misinterpreting them I would like a little clarification.
I made that statement in the general context of standard interpretation regarding inertial frames. Persuant to the apparent agreement as to the identicallity of the geometry under consideration and an inertial frame.
So is your quote here applicable to inertial frames ?
Thanks
Thanks
Yes, it is. Each line of simultaneity, in a given inertial frame, is just a line parallel to the x-axis of that inertial frame. Each such line has its own time coordinate in that frame--which is just the time coordinate of the event where that line intersects the t-axis of that frame. All events that lie on a given line of simultaneity in a given frame have the time coordinate of that line. So events that lie on different lines of simultaneity have different time coordinates.
(Edit: The x-axis itself, for a given inertial frame, is just the line of simultaneity with the time coordinate t = 0 in that frame.)
Having thought it over I see that I was wrong in the statement as I meant it.
I was forgetting that a ICMIF was not a true inertial frame.
But I did not mean it in the sense that you seem to talking about here either.
I didn't mean that the particular lines at a given moment indicated the same clock readings which is self-evidently false. I meant that from the F frames perspective they were different segments [i.e. different time slices] but that every event [colocation of positions and clocks] that appears on one line will also, at some point in time, appear on the other line.
That over time the set of these events is singular and represents a single set of clocks ,congruent to the x' axis in the F' frame.
But I can see that this does not pertain to an accelerating system because such a system has a dynamic metric. So one line does in fact represent a unique set of clock times and locations due to a change of clock rate during the interval separating them.
If I am still incorrect in my interpretation above let me know.
=PeterDonis;2353089]Austin0:
Well PeterDonis, at the prospect that you might discuss all the other complexities, I would probably agree to being the real shooter of John Lennon. :-}
Aside from great knowledge, you seem to have a rare degree of objectivity. The ability to play the "devils advocate" as you put it.
Although in my case so far, there seems to be a tinge of the devils prosecutor. ;-(
So I am a little befuddled by the course of this discussion and still unclear on what it is I am supposed to agree to.
I have tried to respond to you point by point, but so far I have no response from you, aside from the few points that have been somewhat taken out of context, reinterpreted or scanned for subtext indicating doubt of SR or wild speculative alternate theories. I am not quibbling over this and understand your desire to have a firm base of understanding but it leaves me in doubt as to whether you actually read the rest.
Equal proper acceleration must result in equal distance and time. But exactly the same obvious logic is applicable from the ships frame.
I've been watching this thread for a few days now but haven't jumped in because I've been waiting for you to say something short and to the point that gets at the heart of the point of disagreement between you and JesseM. I think the above quote is it. PMFJI, but I'd like to give my take on why the above quote doesn't apply in this situation.
Austin0 Post 9
So for the moment, if you could consider this question solely within the given parameters , with no reference to how things appear in the station frame or whether the acceleration is proper or not, what does your logic predict would be the outcome of the events?
This is purely a matter of logic and known physics. They have the same acceleration ,same instantaneous thrust , as determined by the identicallity of their mechanisms of propulsion.
So if you are saying that logic and physics does not lead to productive insights within the parameters I wanted to examine the situation from, then at this point, I can't argue. It has certainly not led me to any useful conclusions and it is even more certain that it is not a productive format for discussion with those of this forum.
#1 Does the above argument convince you? I should add that this argument is purely kinematic; it doesn't make any assumptions about how objects respond to stresses under acceleration, and so forth. It's
#2 * Do you want both ships to experience equal proper acceleration?* Or do you want both ships to remain at a constant spatial separation, as seen by the ships?
You *can't* satisfy both. Which one you pick will determine what specific scenario you're talking about, and until you do that, it's hard to have a discussion because you may be talking about different scenarios.
It seems to me there is a bit of contradiction here.
#1 States there is no assumption of physics involved.
#2 Makes all kinds of physical assumptions. Born acceleration seems to be based on several physical assumptions . Non-Born acceleration, as outlined by JesseM, also makes several physical assumptions. And the assumption that there is no other possibility other than these two is also a prediction of physics , no?
SO it looks like; having, a priori , made all possible physical assumptions regarding the situation, it resolves to a purely kinematic problem.
Well it certainly leads to definitive results of a sort.
But, as the original question was an attempt to circumvent physical assumptions beyond the known physics of acceleration, it pretty much negates that pursuit.
Or at least, certainly redirects it into an examination of these physical assumptions themselves.
So if all the above assumptions are to be taken as known facts and in addition the stations frames simultaneity is to be taken as the only relevant criteria; then the transformations can, of course, only produce one set of figures. There is no logic involved there, it is only a set of functions.
So if this is the agreement that you are asking for then you have it.
I do have a question though: The Lorentz math itself makes physical predictions which are integrated into the transform. Newton and Galilleo in one.
So the Born hypothesis says that the Lorentz math is insufficient to accurately describe the physics of accelerated motion without additional assumptions. JesseM has said it is not an accurate description of the physics of non-Born accelerated motion.
So how is expecting the math [as a transform] to make accurate coordinate predictions in this context , any different than expecting Galillean transforms to produce accurate predictions regarding relativistic motion between frames where Newtonian kinematics doesn't apply?
Thanks
Austin0:
I'm going to respond to things in both of your last two posts here. You said:
I did, but I've already explained why I haven't commented on most of what you said. Once again, let me reiterate that there are at least two separate questions involved here:
(1) Given a specific worldline (or worldlines) in Minkowski spacetime, how will observers traveling along that worldline (or worldlines) "see" other events?
(2) Given a description of a physical situation, how do we translate that description into a specification for one or more worldlines to which we can then apply our knowledge with regard to question #1 above?
So far I have only been talking about question #1, because your original specification of the scenario was enough to determine a pair of specific worldlines in Minkowski spacetime. Question #1 is what I'm talking about when I say that a question is "purely kinematic": given a specific worldline in Minkowski spacetime, the question of how observers traveling along that worldline will perceive events is *entirely* determined by the specification of the worldline and the laws of SR. No "physical assumptions" other than those are involved.
In the course of this thread, you, and JesseM, and you in response to my posts, have also talked about a lot of things that *only* become involved when you're talking about question #2--in other words, when you haven't yet obtained a specification of a particular worldline or worldlines that an object or parts of an object will follow. In particular, the statements JesseM was making about whether or how acceleration would affect the length of bodies, how bodies would respond to stresses, whether length contraction would apply, etc., were talking about question #2, *not* question #1. All of those things are necessary to consider if you want to figure out, for example, what specific worldlines each end of a rod made of steel, let's say, would follow if subjected to a certain acceleration. But if you have already specified (as your original scenario did) the worldlines you want to consider, all that other stuff is irrelevant.
Right now, as I've said, I am *only* talking about question #1. So I'm simply not going to respond to things that don't involve question #1, or that mix in question #1 with other stuff. There's no point in my doing so until we have a clear understanding of question #1, by itself, with the specific worldlines specified in the scenario we're discussing.
In response to my statement that:
There's no contradiction. My statement #1 was in reference to a specific scenario, the one in which you specified that both ships experience equal (constant) proper acceleration--which is enough to specify a worldline for each ship. In other words, #1 only involved question #1 above, and so, as I've said, is purely a matter of kinematics--the specific worldlines and the laws of SR.
My statement #2 was simply pointing out that the specification that both ships experience equal proper acceleration, and the specification that both ships will remain at constant spatial separation, as seen by the ships, are two *different* specifications; they result in two *different* pairs of worldlines. It is true that, in order to determine that, other "physical assumptions" may be involved, but that's part of question #2, which I'm not yet discussing. Even if it were to turn out (which it won't) that those two specifications, equal proper acceleration vs. constant spatial separation, *did* result in the same pair of worldlines, I would still not want to discuss that until we have agreement on question #1 by itself, dealing with the pair of worldlines that are specified by equal (constant) proper acceleration. If it helps, just suppose that I've withdrawn my statement #2 above from discussion until we are finished with question #1.
With regard to question #1, I want to first make sure that we are using the same definitions for terms. First, you said:
Yes, it is. An MCIF *is* an inertial frame, by definition; it's just that the accerating object is only at rest in that frame momentarily, because it's accelerating. But considered just as an inertial frame, an MCIF is no different from any other.
Also, you said:
An "event", as I've been using the term (and as it's standardly used in relativity) means a single *point* in spacetime. In any given inertial frame, an event has specific coordinates t, x (and y, z too if we're using all three dimensions of space--we've just been using x in this thread to keep things simple). For a given inertial frame, no event can possibly appear on more than one line of simultaneity--the one that has the t-coordinate assigned to that event.
If you meant in your quote above the same thing by "event" that I mean, then your statement is simply false: events that appear on one line of simultaneity *cannot* appear on any other. If you were using "event" to mean something else, then please give an explicit definition.
I'm not sure exactly what you mean by this, given my uncertainty about how you're using the word "event" above. But let me state what I think you may be saying about accelerated frames in my own words:
* Given a worldline along which an observer experiences constant proper acceleration, each individual event on that worldline has a *different* MCIF. In other words: the MCIF at any given event on that worldline will be in motion relative to the MCIF at any other event on that worldline--no two MCIFs at different events on that worldline can be at rest relative to one another.
First, I never said that "the stations frames simultaneity is to be taken as the only relevant criteria". I simply said that the station frame is the only frame in which events Rn and Fn+1 are simultaneous, for n > 1. But let me split that claim up, and take it in two stages. Let's first consider just inertial frames alone, without making any claims as to how the "accelerating frame" relates to them. Let's just consider the claim that the station frame is the only *inertial* frame in which events Rn and Fn+1 are simultaneous, for n > 1. In other words, do you agree to the following propositions? (I'm using the same names for events that I used in my last post.)
* Events Rn and Fn+1 are simultaneous in the station frame for all n > 1.
* Events Rn and Fn+1 are *not* simultaneous in R's MCIF at Rn, or in F's MCIF at Fn+1, for all n > 1.
I don't know that I'd say there's no "logic" involved, although maybe "mathematics" would be a better word--but mathematics is just logic using equations and symbols as tools. And again, please note that those two propositions don't talk about the "accelerating frame" itself--just the station frame and the two MCIFs, R's at Rn and F's at Fn+1--all inertial frames. I'm not asking here if you agree that the "accelerating frame" itself *has* to see things the same way at each event as the MCIF; I want to make sure first that you agree on how things will look in the MCIFs themselves. Since those are just inertial frames, there shouldn't be an issue, since you've already said you agree that relativistic kinematics gives correct predictions for how things look in inertial frames in relative motion. But I want to be sure before going on.
Maybe it would help if I responded to this statement as well. Here's why I came into this thread:
You (Austin0) raised the issue of an apparent logical contradiction between two propositions (to save time I'll state them using my more recent specification of the scenario):
(1) According to SR, observers R and F will *not* observe events Rn and Fn+1 to be simultaneous for all n > 1; those respective pairs of events will only be simultaneous in the station frame.
(2) However, the proposition that "equal acceleration leads to equal distances and times" would seem to imply that events Rn and Fn+1 *would* be simultaneous to R and F, for n > 1; and this appears to be confirmed by the fact that the proper time on R's clock for event Rn will be the same as the proper time on F's clock for event Fn+1, for n > 1.
(I know the above is not the only issue you raised; but as I've said, I believe that until the above issue is resolved, any discussion of the other issues you raise is premature.)
Now I believe SR to be a correct theory (within its domain of applicability--that is, as long as the effects of spacetime curvature are negligible, so that we can assume spacetime to be globally flat). That means that anything which is a logical consequence (or mathematical consequence, if you like) of the laws of SR along with whatever specific premises are assumed for a given scenario, I believe to be true. Given that, I'm quite sure proposition #1 above is not in error; the situation you posed is not a new one, and I've worked through it myself in detail in the past, and I've found plenty of references to confirm my solution. I'm also quite sure that the proper time on R's clock for event Rn *is* the same as the proper time on F's clock for event Fn+1; that's a simple consequence of the solution for proposition #1 (and anyway, you agree that it is, so it hasn't been in question).
So given the above, I believe that there has to be something wrong with the proposition that "equal acceleration leads to equal distances and times". I already know what *I* believe is wrong with that proposition: I stated it in my first post in this thread. "Equal acceleration" is an invariant (provided we mean "proper acceleration", the acceleration that would be measured by an accelerometer moving with the given observer, but we've already agreed on that), but distances and times are frame-dependent, so there can only be *one* frame in which equal accelerations can lead to equal distances and times, and we already know the station frame is that frame.
You weren't satisfied with that resolution of the issue, so I'm now trying to pinpoint exactly where our understanding diverges. Every question I've asked and you've answered has narrowed it down.
Please ignore this if it distracts you from your discussion. It’s just that I have followed it and I feel as if the discussion were incomplete without a practical background, i.e., a problem to solve. Trying to think of one, the example has reminded me of a similar discussion we’ve had.
Imagine that the ships (we keep calling them R and F) depart from the same place and fly in opposite directions. After some “whiles” with equal proper accelerations, each ship reaches its respective finish line. Both finish lines are, in the station frame, equidistant from the origin.
So a referee in the station declares that the arrivals are simultaneous and the race to be a draw.
However, in R’s MCIF, R has arrived at its finish line earlier than F at its own. In other words, when it reaches its finish line, a longer patch of the station’s frame has passed by R itself than by F, as per R's simultaneity line.
But F’s MCIF measures that F has arrived earlier! At that time, a longer patch of the station’s frame has passed by F than by R.
In spite of that, R’s and F’s MCIFs read the same proper time intervals when they reach their respective finish lines.
PeterDonis, would you agree that the solution of the problem (who wins the race) is a draw?
Austin0, if we all agreed that the solution, in accordance with orthodox SR, is a draw would you not mind that SR holds that in R’s and F’s MCIFs there is discrepancy with the station frame and between themselves as to simultaneity/distances traversed?
If the definition of "who wins the race" is "who reaches their respective finish line first, as judged from the station frame", then yes; your statement of the scenario stipulates that they arrive at their finish lines simultaneously in the station frame.
However, you can't say categorically that that is "the" solution of the problem precisely because simultaneity is frame dependent. Any condition on what happens "first" when the respective events are spacelike separated has to include a specification of whose frame "first" is going to be judged from. Otherwise the condition is ambiguous.
I think this is the same scenario that Saw and I discussed a little while ago. If it is, I think Saw is right. Of the 3 frames, the station frame is the only inertial frame, because the inertial frames associated with R and F are ambiguous, since R and F both accelerated. A frame in which R is always at rest is non-inertial.
The coordinate independent way of selecting the station frame is to make R and F both carry clocks, and declare the winner the one who reaches his end point in least own proper time.
Yes, this would be a good way of avoiding a frame-dependent specification, and under this definition, the race would be a draw.
This is true, but I don't think it disqualifies R or F from having a legitimate "point of view" (if you don't like the word "frame") according to which they are at rest and other objects are moving. R's or F's point of view will not "work the same" in all respects as that of an inertial observer, but that's OK; as long as spacetime is flat, SR can be used to work out how R's or F's point of view will work.
Indeed. R has the temerity to say that he won the race, even though he was at rest!
This is a way to phrase it with which I disagree. In this particular respect, at this more fundamental level, I think Atyy and I fully agree. I’ll explain myself. This is something which is at the core of SR. Someone might say it’s philosophical, but it seems to me totally physical. After all, physics is about solving problems, isn’t it?
With your statement, you seem to be implying that SR means that the “specification” of the race (the rule for determining who wins) can be arbitrary: if you choose a coordinate-independent quantity, you’re doomed to disagreement; if instead you manage to specify an invariant, then you’ll get agreement; but the choice is whimsical, there is no physical reason to prefer one over the other. If this were true, the significance of SR would be that a whole bunch of problems (those where the relevant events are non-colocal) have been shifted to the realm of problems without an objective solution.
To take an extreme example: this would amount to the same as saying that, in the classical scenario, the police has no objective reason for arresting you for driving faster than the speed limit… wrt the ground! You could always say that in your brother’s frame, who was co-moving with you, you were at rest! And you could challenge the traffic regulations on the grounds that they are arbitrary and discriminatory! That would not be right: it’s obvious that, in this context, the ground frame is the relevant reference. That does not mean that any other frame is not apt for predicting what is wrong and what is right. A spaceship flying by just has to measure the speed of the ground wrt it and your speed wrt it, apply the relativistic rule for combining velocities and thus conclude that you were creating danger on the road, which is the outcome that the rule tries to avoid, i.e., the spirit of the problem.
The same applies to this race example. You have to find the spirit of the problem, the practical objective: what do we want to reward by saying R or F won the race? Technology of the spaceship, ability in driving it? It seems to me that both proper acceleration and proper time are good indications thereof. So the choice of these indicators is not arbitrary but a must.
Here instead I tend to rather agree with PeterDonis. If I have understood PeterDonis well, with the concept of MCIF you can always convert R and F frames into an inertial frame at a specific event. Once this is done, you find that they disagree with the station frame and between themselves in terms of simultaneity and hence in terms of distance traversed by R and F. However, they do not disagree in terms of who won the race. They understand the spirit of the problem and so do not trust their simultaneity judgments on face value and work a little further. For example, what R should do is finding F’s proper time = dt^2 – dx^2. If the result is the same as the reading of his own clock, he agrees that the race was a draw.
Or did I catch it wrong? Would R and F, in spite of being non-inertial, make those calculations? Well, that was your discussion, which I don’t want to interrupt. Just thought that having this practical background might be helpful.
PeterDonis said:
Austin0:
OK it was simply to this, not inconsequential difference ,that I was refering. That regarding the frame it was only transitory and was in effect a series of MCIF's with differing metrics
#1* Events Rn and Fn+1 are simultaneous in the station frame for all n > 1.
#2* Events Rn and Fn+1 are *not* simultaneous in R's MCIF at Rn, or in F's MCIF at Fn+1, for all n > 1.
reduced to this,disregarding all other considerations, there has never been any disagreement. I am sure I have explicitly recognized this more than once.Two frames cannot agree on simultaneity regarding any two events
On #1 alone,, #2 is an automatic conclusion.
Perhaps I phrased that badly. Obviously the math was derived with impeccable logic, both mathematical and mental. I meant that having reached the point of applying the math, you are already beyond the point of exercising your own logical mind toward the question.
Approached from the point of #'s 1 and 2 above, it appears to me to be straight forward application. Just looking at it mentally, it seems to me , we have R now behind ,so its clock is running behind ,exactly opposite the normal situation. F is ahead, with clocks running ahead.
They turn off the engines and resynch their clocks so that R is running ahead and F running behind and we have an inertial frame like any other ,except that it is exactly the same size as it was at rest in its original frame as observed in that original frame. And will continue to be so through any period of extended acceleration. As this is assumed to apply to a single ship as well , this presents an extraordinary picture. A frame that continues to attain greater and greater instantaneous velocities but remains the same length as observed from an inertial frame.
If you have done the math I am sure it all works out fine and I would like to hear any points I am missing.
So what is your interpretation of this picture?? Consider a single long ship.
What immediately occurs to me : The ship is extended beyond its rest length and Lorentz contracted back to exactly the same length?
or
The ship is not extended because Lorentz contraction is a result of specific application of force? But simultaneity, in effect , extends it so the stations are relatively contracted?
Or there is a flaw in the original logic [my own] and this does not describe an actual possible reality
All of these seem to have real problems so what is a better one??
And the real questions behind the query: Does the Lorentz contraction apply simply to material bodies or does it apply to extended frames and the space between bodies?
Is the phenomenon a purely physical one of forces, with implied stresses etc. or is it simply a stressfree result of the geometry of spacetime?
Is it fundamentally a temporal effect that is perceived as a spatial effect??
This one I have spent a lot of time playing with.
These questions do not seem to be clarified by this exercise. Maybe I should have left out the stations and simply gone directly to the physics??
thanks
I didn't mean to imply that there was no reason to prefer the invariant way of specifying who wins the race (i.e., preferring "lower elapsed proper time" as the criterion). Of course there is: invariants are the things everybody can agree on, so you avoid the ambiguity of specifying things in frame-dependent ways. I was just pointing out that you do, in fact, have to specify the invariant; you can't just say "whoever reaches the finish line first wins", without qualification, and expect everybody to agree, because those words are ambiguous. Saying "whoever has the least elapsed proper time when they cross their designated finish line, wins" is unambiguous.
Of course R and F can each calculate what the other's proper time elapsed would be, given the appropriate data. Anyone can. That's not in question.
I think what I said agrees with all of your points and PeterDonis's too.
No, that's not the point. You're saying that the reason to prefer one specification over the other is just unambiguity. Unambiguity is not sufficient. With this rationale we could also say that the race is won by the ship whose driver is a lady. That's also unambiguous. (Well, not always..., but you catch the point). And unambiguity is necessary at the level of the ultimate meaning of the chosen concept, but only at that level. In fact, the specification might perfectly be: "whoever arrives earlier in the station frame". A different thing is that the ship frames may reach the same conclusion (not as to simultaneity, but as to the solution of the problem) through their own measurements of proper time. But as I said I don´t want to interrupt the discussion. If it's to going to be controversial, let's leave it aside. If you want to contest this, you can do it in the thread Elegant Universe Example, where this subject is already advanced.
ok, please answer Austin0.
Ah, then I misunderstood. Thanks for the comment.
Ok, good.
I'm not sure what you mean by "opposite the normal situation". What is the "normal" situation I'm supposed to compare this one to, that comes out the opposite way?
But in any case, we haven't gotten to whose clock is running "behind" or "ahead" yet; all we've established so far is that events Rn and Fn+1 aren't simultaneous to either R or F, for n > 1. Now we take the next step: call the proper time elapsed on R's clock at event Rn, T-Rn. Call the proper time elapsed on F's clock at event Fn+1, T-Fn+1. These two proper times are equal, but let's keep separate symbols for them. Then we have the following:
* In R's MCIF at event Rn, the time coordinate of event Fn+1 is *less* than T-Rn.
* In F's MCIF at event Fn+1, the time coordinate of event Rn is *greater* than T-Fn+1.
This is a precise statement of what I think you were trying to get at by saying that R's clock is running behind and F's clock is running ahead. However, a I think a more natural interpretation for R and F to put on these observations would be:
* R, at event Rn, sees F pulling ahead of him, because in R's MCIF at event Rn, F has already passed event Fn+1--i.e., F has already passed his corresponding station.
* F, at event Fn+1, sees R falling behind him, because in F's MCIF at event Fn+1, R has not yet reached event Rn--i.e., R has not yet reached his corresponding station.
These interpretations are simply manifestations of the fact that the spatial separation of R and F, in the frame in which they start out--the station frame--*must* inevitably turn partially into time separation in any other frame in relative motion to the station frame. And the time separation must inevitably lead to "speed separation" in each observer's MCIF at any point along their worldlines.
Furthermore, all of the above will lead to a change in the distance between R and F, as measured in either of their MCIFs. For example, consider R's MCIF at event Rn (n > 1). What is the distance between R and F in that frame? Well, the "distance" between any two worldlines in a given frame is the spacelike interval between points on each of the worldlines that have the same time coordinate. But we've already seen that, whatever event on F's worldline has the same time coordinate as Rn in R's MCIF at Rn, it is *not* Fn+1--it is some event further along F's worldline than Fn+1. So the interval between events Rn and Fn+1 is irrelevant to answering the question, "how far away will F be from R when R passes station #n?"
And similarly, to answer the question, how far away R will be from F when F passes station n+1, we will have to find the event on R's worldline with the same time coordinate as Fn+1, in F's MCIF at Fn+1, and that event will not be as far along R's worldline as Rn. I won't do the math explicitly here (I can in a follow-up post if desired), but when you do all the calculations, it turns out that both distances, that between R and F at Rn and between F and R at Fn+1, are *larger* than the spatial separation between R1 and F2 in the station frame (which is the original separation between R and F, since those are the events where they start out). And of course this is consistent with R's observation that F is pulling away and F's observation that R is falling behind.
All this is also consistent with what is observed in the station frame. In that frame, the spatial separation between the worldlines remains constant. But in that frame, the ships are moving (for any time t > 0), so the separation between them in the station frame is Lorentz contracted, compared to the separation between them in either ship's MCIF (in which one ship is momentarily at rest).
Now, let's consider your suggestion:
You failed to specify the most important thing: at precisely which events on their worldlines do R and F turn off their engines? It makes a difference.
Let's suppose that R turns off his engine at event Rn and F turns off his engine at event Fn+1 (i.e., they turn off their engines when they each pass their respective stations n and n+1, with the exact value of n being prearranged). This is what I think you meant to specify. Then, they resynchronize their clocks; R emits a light pulse towards F from event Rn, and F emits a light pulse towards R at event Fn+1.
What will happen? Of course their clocks will be out of sync. But to re-sync them, they have to know the distance between the ships, in what will now become their common (inertial) rest frame. What is that distance? They will find (and they can check, of course, by timing round-trip light pulses) that the distance is *not* the same as the original separation between them in the station frame; it is *larger*--in fact, just enough larger so that its Lorentz-contracted value, as it appears in the station frame, is the same as the original separation in the station frame. So it is *not* true that the separation between R and F, in this new inertial frame, will be "exactly the same size as it was at rest in its original frame". (It *is* true that the separation between R and F, in the *station frame*, will be the same as it always was--and this may have been what you meant by your statement of "exactly the same size" above, I'm not sure--as long as R and F each stop their engines at events which are simultaneous in the station frame, as I specified they did, above).
Armed with this (larger) distance value, R and F can each, by observing the "time stamps" on light pulses giving the time of emission, correcting those for light-travel time, and comparing those with the time of reception, correct their clock readings so that they are in sync. How they correct depends on what they want the new "origin" of time in their new common rest frame to be, but in general, R will have to advance his clock reading, or F will have to move back his clock reading, or some combination of the two, in order to get them in sync. (Btw, at the end of the synchronization, both clocks will have a common "origin of time"--R's clock will not be running ahead or F's running behind.)
No, it is *not* assumed to apply to a single ship as well--at least not by me. Everything I've said above applies only to the case of separate ships, with no physical connection between them, who each experience equal, constant proper acceleration, and therefore travel along the worldlines I've labeled R and F.
To apply any of what I've said to a single ship, you would have to set up a scenario such that the front end of the ship traveled along the same worldline as the "front" ship F in the scenario I've been discussing, and the rear end of the ship traveled along the same worldline as the "rear" ship R in that scenario. That can be done, of course, but it's going to look like a very unusual scenario. For example, here's one way of doing it:
Let there be a line of stations, numbered #1, #2, #3, etc., all moving inertially, and all at rest relative to one another. Let there be a long ship whose rear end, R, is located next to station #1, and whose front end, F, is located at station #2, at time t = 0 in the station frame. Let there be rocket engines at each end of the ship (R *and* F), and let them be identical in construction and performance, so that each imparts an equal, constant, proper acceleration to its end of the ship. At time t = 0 in the station frame, both rocket engines turn on, and remain on continuously thereafter.
In the scenario I've just stated, the worldlines of the rear and front ends of the ship *would* be the same as those, R and F, that I've been discussing. And in this scenario, the ship would gradually be stretched, and eventually, when the tension caused by the two rocket engines, each pushing its end of the ship, exceeded the tensile strength of the ship's hull, the ship would break apart.
But notice that to achieve that result, I had to put rocket engines at each end of the ship--not a typical design. :-) Suppose instead that I adopted a more normal rocket design principle:
Let there be a line of stations, numbered #1, #2, #3, etc., all moving inertially, and all at rest relative to one another. Let there be a long ship whose rear end, R, is located next to station #1, and whose front end, F, is located at station #2, at time t = 0 in the station frame. Let there be a rocket engine at the rear of the ship that, when turned on, imparts a constant proper acceleration to its end of the ship. At time t = 0 in the station frame, the rocket engine turns on, and remains on continuously thereafter.
In *this* scenario, the worldline of the *rear* end of the ship will be the same as the one, R, that I've been discussing. But as it stands, the scenario tells us *nothing* about how the *front* end of the ship will move! To draw any conclusions about that, we need to bring in some sort of physical assumption about how the force of the rocket engine at the rear of the ship gets transmitted through the ship's structure to the front of the ship. Different physical assumptions will result in different worldlines for the front of the ship, and that, in turn, will result in different predictions about what the ship will "look like" in its MCIF, and in the station frame--whether it will appear "Lorentz contracted" and by how much, and so on. All of that gets into what I called question #2 in my last post, and I haven't been discussing that up to now.
(Btw, one thing I haven't mentioned in any of the above: I've been quoting above how things would be observed in R's and F's MCIFs, without addressing the point of how the "accelerated frame" relates to the MCIFs--in fact I've simply been assuming that the view from the "accelerated frame" at a given event is the same as the view from the MCIF at that event. Do I need to go into how that works? If so, I will.)
The question you're asking here is certainly a valid question, and hopefully will be somewhat clarified by what I'm saying. But the way you ask it may not be the best way to ask it. That's why I went to the trouble of separating the issue of "kinematics" from the issue of physical assumptions. Here's what I think is a better way to get at the points you're interested in.
(1) I would use the term "Lorentz contraction" *only* to refer to how a spacelike interval between a specific, defined pair of events appears in different frames which are in relative motion. In other words, the term should be used only for the "kinematic" aspects--the changes in "how things look" that are due *solely* to relative motion, *not* to any other physical assumptions.
(2) This means that the question of Lorentz contraction doesn't even come into play until you've already determined all the worldlines and events of interest. Lorentz contraction, defined as I recommend, is a "result of the geometry of spacetime", and that is all it is. It applies to any spacelike interval, once that interval is specified, regardless of whether the interval is occupied by empty space or by a material body (in the latter case, of course, the worldlines of all the points in the material body must already have been specified).
(3) All the "physical" questions about forces, stresses, etc. should be construed as questions about *how to specify the worldlines and events of interest*. In other words, they are questions about how to figure out which specific points and curves in the geometry of spacetime are the ones we are dealing with. This is where all the stuff about Born rigidity and so forth, and how reasonable various physical assumptions are about how bodies respond to stress, comes into play.
Ok, I'll look in that thread.
Saw:
I looked and it looks like the thread has died. But I don't disagree with the position you were taking there: you were basically saying that (1) the "solution" (i.e., the "right" specification of who wins the race, for example) has to involve quantities that everyone can agree on, so there's no ambiguity, and (2) which quantities you choose has to be guided by the "spirit" of the problem. I agree with both of those statements. I was focusing on (1) in my comments, but I didn't mean to imply that (2) isn't important too.
=PeterDonis;2358975] Originally Posted by Austin0
Ok, good.
I am well aware that I have to improve my grasp of accepted terminology. I am working on this. In this case the normal situation would be that relative to a another inertial frame the clocks in the rear would be running ahead of the clocks positioned forward in the direction of motion. As you point out here, that is exactly what we assume would transpire when they synch their clocks by the convention. The rear ship would set its clock ahead or the front ship would set its clock behind.
Fine or alternately; at event Rn the simultaneous location of F is Fn+1+? with T-F > T-Rn
OK or at Fn+1 the position of R is Rn minus (?) and the T-Rn-? is less than T-Fn+1
I assumed that a precise statement was not necessary and in fact you do seem to have figured out what I was saying in my casual way.
Agreed. I was not assuming anything from the perspective of the ships, but only from our perspective of looking at the diagram and applying the assumption of simultaneity from that perspective, to spacetime positions of the ships.
Agreed of course. From the point where it became a matter of simply applying the transformation and its implications to the ships, there is no longer any question. You have already answered any question of physics because the transformation itself predicts the complete spatial-temporal coordinate outcome. When I said I was sure your mathematical analysis was correct I did not mean that personally. As I see it, from this point it is purely the logic of mathematics. That any theorem or results validly derived from allowable arguments and axioms is bound to be true. I don't need to see or do the math to be "convinced" that it is going to be totally consistent . I already assume so.
All the rest; the spatial separation etc. is all immediately obvious as soon as you adopt the assumption of that simultaneity. If R is behind and F is ahead of course the distance in that perspective is going to be greater. Etc,etc
Of course you are correct , it makes a difference. But I didnt see how the difference is relevant to the actual question here so I didnt specify. So if F cuts its engine at Fn+1 it will be before Rn and therefore R will continue acceleration for a longer period thus equalizing the velocities, I would assume. There are interesting detaila here I am sure , figuring out the relative time dilation between the ships etc. But I assume they also would work out consistently and don't add anything to these questions.
Of course. That would only apply as observed from an inertial frame moving in the direction from F to R
So I may have been taking JesseM's statement too literally.
AH HA! Finally ;-) From this it seems you are saying that the assumption of stretching does not come from the physics of acceleration re: propagation of momentum etc. but is derived from a conception of simultaneity. That this is a temporal translation but in this context is given a very physical interpretation.
I am not questioning this. My own "intuition" is that simultaneity is at the core of a lot of questions and could very well have physical implications , or at least as "physical" as any other phenomena.
I would guess then that you expect a steel rod , uniformly electromagnetically accelerated to stretch apart?
It would appear that Born rigid acceleration is an ideal abstraction impossible to even approximate in the real world. SO it would seem that any propulsion from the rear , a more normal rocket design as you put it , would automatically be as close to Born acceleration as we could get ?
The course of this thread is ample demonstration of the truth of that
I understand what you are saying and certainly agree on the effects being the "result of the geometry of spacetime" but don't see the distinction between kinematics and physics you are implying.
On one hand you seem to be saying that contraction has no physical implications but then adopt assumptions of simultaneity from kinematics that then seem to dictate both contraction and the physical forces involved in acceleration.
Perhaps you could elaborate on this??
Thanks
The stretching isn't an assumption; it's a logical consequence of specifying the worldlines R and F the way we've specified them (that both ends of the ship, R and F, experience equal constant proper acceleration). Once you've specified that, the stretching has to happen, by the laws of SR; you don't have to assume it.
If the rod has a rocket engine at each end, with both engines imparting equal, constant proper accelerations to their respective ends, as with the ship I specified in my last post, then yes, it will stretch apart. I'm not sure what "electromagnetically accelerated" means here, but if it means that some electromagnetic force is applied all along the rod, as with the scenario I describe below for Born rigid acceleration, then no, the rod won't stretch apart.
Neither of the scenarios I specified corresponds to Born rigid acceleration. You're right that Born rigid acceleration is an ideal abstraction, but it's certainly possible to construct a scenario that would realize it, which is no more physically impossible than the others we've been considering. :-) Here it is:
Let there be a line of stations, numbered #1, #2, #3, etc., all moving inertially, and all at rest relative to one another. Let there be a long ship whose rear end, R, is located next to station #1, and whose front end, F, is located at station #2, at time t = 0 in the station frame. Let the ship be divided into very short segments, running from R to F, and let each segment have its own rocket engine; each rocket engine is programmed to impart to its segment an acceleration equal to [itex]\frac{c^2}{x}[/itex], where x is the distance of the segment from the origin in the station frame at time t = 0. This means that, as we move from the rear end R to the front end F of the ship, the acceleration imparted to each segment gradually gets smaller, in inverse proportion to distance. At time t = 0 in the station frame, all of the rocket engines turn on, and they all remain on continuously thereafter.
In the above scenario, the ship as a whole will undergo Born rigid acceleration. Born rigid acceleration is a "nice" way to accelerate the ship because (1) in the MCIF of any given segment of the ship, at any point on that segment's worldline, the proper length of the ship appears unchanged from its initial value in the station frame at time t = 0; (2) because of this, the internal stresses within the ship stay the same as it moves. But as you can see, you need to arrange things very precisely in order to achieve this--and of course no real rocket ship would be designed to do this. (If you see a reference to Born rigid acceleration requiring a "conspiracy of forces", that's what it refers to.)
I'm not saying that Lorentz contraction has no physical implications. For one thing, kinematics is a part of physics. I'm just trying to separate two stages of "solving" a problem that's posed. First, you analyze the specification of the problem to determine all the worldlines and events of interest. Then, you use relativistic kinematics to determine how those worldlines and events will appear in whatever frames you like. You could call both stages "physical" if you want to.
Also, I'm not "assuming" the kinematics, or the simultaneity relations, or the physical forces involved in acceleration, or anything of that sort, except insofar as I'm assuming that SR is correct. The laws of SR *require* all these things to be related in certain specific ways, once you've determined the worldlines and events involved. That's all I'm trying to emphasize when I talk about kinematics.
Re: Is Distance/space Lorentz contracted?
The stretching isn't an assumption; it's a logical consequence of specifying the worldlines R and F the way we've specified them #1(that both ends of the ship, R and F, experience equal constant proper acceleration). Once you've specified that, the stretching has to happen, by the laws of SR; you don't have to assume it.
Hi PeterDonis In this case [i.e. a single ship] we have not yet specified the world lines have we?
#1 This appears to make assumptions:
A) That simple application of force from one end would not result in equal acceleration at both ends.
B) That length contraction would not intrinsically occur as the result of instananeous velocities.[clock hypothesis]
C) It seems to be taking kinetic conclusions arrived at through consideration of two ships and then applying them to a different situation. Simply assigning world lines on that basis.
But I may be misinterpreting your statements so further clarification might help.
My knowledge of electromagnetic acceleration is minimal derived mostly from reading about railgun technology, current and hypothetical. From what I understand there are various methods of application depending on the timing and directions of fields. It seems that it is possible to, in effect, pull a rod , or push-pull or apply uniform fields , so I imagine it is also possible to control the force in the specific format required by Born acceleration.
So in this context do you still think a uniformly accelerated rod would deform?
Let there be a long ship whose rear end, R, is located next to station #1, and whose front end, F, is located at station #2, at time t = 0 in the station frame. Let the ship be divided into very short segments, running from R to F, and let each segment have its own rocket engine; each rocket engine is programmed to impart to its segment an acceleration equal to , where x is the distance of the segment from the origin in the station frame at time t = 0. This means that, as we move from the rear end R to the front end F of the ship, the acceleration imparted to each segment gradually gets smaller, in inverse proportion to distance. At time t = 0 in the station frame, all of the rocket engines turn on, and they all remain on continuously thereafter.
This raises a lot of interesting questions.
It would seem that application of force to the rear would represent maximal resistance to expansion. Now if compression was the issue, then it would make sense to apply additional forward force throughout the system. But that is not the object in this case, so I don't see how this calibrated application has any effect regarding the reduction of expansion. ?
If this does apply then what is the expected result for the contents of this vehicle??
Does this mean that a steel ruler hanging from the wall of Einsteins elevator would stretch like silly putty??
What of a ruler that has been accelerated while positioned transverse to the motion and is then rotated longitudinally?
Suddenly subjected to the cumulative acceleration of the total course?
Agreed kinematics is a part of physics of course. It seems to me this question enters an area of a certain ambiguity.
For a second consider Newtonian kinematics. I am sure you would agree that the Galillean transforms had no physical implications or assumptions beyond the invariance of Newtonian kinematics. Given a set of coordinate events in one frame, there were no additional considerations of physics, per se, required to derive accurate events in another frame.
I think we agree that this is equally applicable to the Lorentzian transforms as applied to events between inertial frames.
But regarding the transitional state between inertial frames is a different situation.
To get coordinate events in any frame then requires consideration of physics, assumptions about, not only the physics of acceleration, but also about the meaning and interpretation of the Lorentzian effects, which did not need to be considered at all when dealing with inertial frames.
So IMHO it is not just a question of whether a particular set of assumptions is consistent with the fundamental constraints of SR, but whether or not it is the only set of assumptions that is consistent or the set that is the most consistent with the physics of acceleration as we know it from empirical testing to this point. I do not presume to have an answer to this, but it does appear to me that there are other possibilites.
Thanks. BTW this is starting to get more and more interesting
In each of the single ship cases I specified, the worldlines of any point on the ship where I put a rocket engine were specified (because the accelerations that the rocket engines imparted to their locations on the ship were specified). But those were the *only* points whose worldlines were specified.
So, in the first case, with a rocket engine at the rear and front end of the ship, the worldlines of the rear and front end were specified, but the worldlines of intermediate parts of the ship were not. The front and rear end worldlines being specified were sufficient to conclude that the ship would stretch, but the exact worldlines of intermediate points would depend on the exact details of the stretching--i.e., how each segment responded to the tensile stress caused by the rear and front ends getting further apart.
In the second case, with a rocket engine only at the rear, as I said then, only the rear end's worldline was specified; the worldlines of all the other parts of the ship would depend on the details of how the force imparted at the rear end was transmitted through the ship. More on that below.
In the third case, with rocket engines all along the ship (Born rigid acceleration), the worldlines of all parts of the ship *were* specified (at least to the accuracy of the size of each "segment" of the ship that was assigned an engine). I had to do that because it's the only way to realize Born rigid acceleration--in effect, specifying that an object undergoes Born rigid acceleration *does* specify the worldlines of every part of the object.
That's correct. It can't possibly, because it takes time for the information that the force has been applied to travel from one end of the ship to the other.
That information can't travel faster than the speed of light, so, for example, if the ship is one light-second long, then the front end can't possibly begin accelerating sooner than 1 second after the rear end does (as seen in the "station frame", the frame in which the ship is initially at rest). For any actual known material, it will take a lot longer than that for the applied force to propagate through the ship (because the speed of sound in all known materials, which is the speed at which applied forces propagate through the material, is many orders of magnitude less than the speed of light).
Austin0 said:
B) That length contraction would not intrinsically occur as the result of instananeous velocities.(clock hypothesis)
Once again, don't confuse the kinematic effect of Lorentz contraction, which requires that you have already specified the worldlines and events you're dealing with, with the dynamic effects like how objects respond to applied forces, which are what you use to *figure out* which worldlines and events you're dealing with.
The kinematic effect is simply this: if I know the length of a given object in a given frame, I also know its length in any other frame, just by applying the Lorentz transformations. But in order to know its length in any frame, I have to know the worldlines of both its ends. If I don't know those worldlines yet, I don't know its length. If I know only one particular pair of events on the worldlines of the object's ends--for example, I know the spatial position of its rear and front ends at time t = 0 in the station frame--then I only know its length in the frame in which that pair of events is simultaneous, at the particular time of those events--in this case, the station frame at time t = 0. I don't have enough information in that case to even apply the Lorentz transformation, because those two events won't be simultaneous in any frame that's moving relative to the station frame, so I can't use them to determine the object's length in any other frame. I have to find a pair of events on the worldlines of the object's ends that are simultaneous in the *moving* frame to determine its length in that frame, and if I don't know the worldlines of the ends, I can't do that.
Discussions of the Lorentz transformations in textbooks usually gloss over all this, by just specifying (often implicitly) all the worldlines that will be needed to solve whatever problems are posed, including performing whatever Lorentz transformations are required. But if you look "under the hood", you'll see that all the above stuff still applies; it's just hidden by the way the problem is stated. In other words: the kinematic effects, as I've defined them above, *do* "intrinsically occur"--but you have to know a lot to calculate what they are. Gaining that knowledge requires figuring out the dynamic effects first, so you can determine the worldlines and events you're dealing with, and the dynamic effects are *not* "intrinsic"--they depend on the physical assumptions you make.
Nope--the only conclusions I'm drawing for each case are based on the worldlines that I know are specified in each case (I discussed which ones those were for each case above).
Austin0 said:
My knowledge of electromagnetic acceleration is minimal derived mostly from reading about railgun technology, current and hypothetical. From what I understand there are various methods of application depending on the timing and directions of fields. It seems that it is possible to, in effect, pull a rod , or push-pull or apply uniform fields , so I imagine it is also possible to control the force in the specific format required by Born acceleration. So in this context do you still think a uniformly accelerated rod would deform?
Once again, if the force is controlled the way I specified for Born rigid acceleration, then no, the rod would not deform. (I would think, as you do, that this is possible, but I don't know if any actual electromagnetic acceleration technologies do it in practice.) If the force is applied some other way, then the deformation of the rod would depend on how the force was applied.
In the case of Born rigid acceleration, we *are* applying additional forward force throughout the system. At each point along the ship, we're applying just enough force to keep it "ahead" of the rear end of the ship by just the right amount, so that the total length of the ship remains constant (and internal stresses likewise remain constant). If we applied more force--for example, if we applied just as much force at the front end of the ship as at the rear--the ship would stretch, as in the first "single ship" case I specified. If we applied less force, the ship would compress, which is what would happen, at least initially, in the second "single ship" case I specified, where there was only a rocket engine at the rear end of the ship.
(How do I know the ship would initially compress in this case? Because, as I said above, the information that the force has been applied at the rear can't travel through the ship faster than the speed of light, so there will be an unavoidable minimum time delay before each part of the ship forward of the rear end starts accelerating. That means the ship will initially compress, as each segment, when it first starts accelerating, moves closer to the segment in front of it, that hasn't received the information to start accelerating yet.)
If the elevator were accelerated hard enough, yes. Just as a steel ruler hanging from the ceiling in a room that was stationary in a strong enough gravitational field would stretch. Remember that in many of these cases, the implied accelerations we've been talking about are in the billions or trillions of g's.
Accelerated how? Does the acceleration stop before the ruler is rotated?
I'm not sure I understand what you're asking here.
The last statement here is incorrect; the meaning and interpretation of Lorentz contraction and time dilation is an integral part of figuring out how SR works for inertial frames. If Einstein had not been able to give each of these effects a direct physical interpretation in inertial frames in relative motion, I doubt he would have made much headway in getting people to consider SR. There is no fundamental difference here between inertial and accelerated motion, except that an object on an accelerated worldline "changes its inertial frame" as it moves--you have to use its MCIF at any given event to determine how things will look to it at that event. But as long as you know the object's worldline, its MCIF is fully determined at each event.
Once more, I think it's important to keep emphasizing the distinction between kinematic and dynamic effects. As far as the kinematic effects are concerned (i.e., how things look in different frames, once you've already determined the specific worldlines and events you're dealing with), there is only *one* way to deal with them that is consistent with the fundamental constraints of SR (basically, the principle of relativity and the fact that the speed of light is the same in all inertial frames, plus the clock postulate). Once you have a specific set of worldlines and events, the way things look in any frame, inertial or accelerated, is fully determined by the postulates of SR (the three I just listed above) and the specifications of the worldlines and events. The only restriction is that spacetime has to be flat, at least to a good enough approximation for the problem you're dealing with.
However, that still leaves quite a bit of freedom in dealing with accelerated objects, because you still have to somehow determine the specific worldlines of the various parts of those objects, and that will depend on what assumptions you make about how forces applied to one part of the object are transmitted to other parts--the dynamic effects. There are *lots* of different assumptions you could make here that are consistent with the laws of SR, and each set of assumptions will result in a different set of worldlines for the various parts of the object. So in that sense, yes, there are certainly lots of different ways that an accelerated object could "look" that are all consistent with SR.
Good. :-)
It seems to me that the above conclusions are justified only if:
A) It is justifiable to completely disregard the physics and existence of the intermediate body. I.e. That the motion and acceleration of the actual points of propulsion are completely independent of the connection with the total system.
B) You can apply an interpretation of acceleration as applied force and disregard the interpretation of acceleration as a change in the motion of a system.
C) That the Lorentz contraction can be completely disregarded as a factor in the physical situation regarding the relevant worldlines ,but can then, simply be applied as a kinematic result, ex post facto
We are in complete agreement here regarding the propagation time. I would propose for the purposes of this discussion that Mach 1 be considered the practical limit. If the force applied is sufficient to make the speed of light relevant, I would say it is beyond the bounds of realism and billions of g's would imply inertial forces far beyond the ability of an addition of a few extra engines to counter.
Would you agree that as far as the principles involved are concerned ,the magnitude of the acceleration rate is not important?
WHile we agree on the importance of propagation time, we seem to have different ideas concerning the implications of this fact.
For discussion I will give a quick outline of my understanding and you or someone else with greater knowledge can point out any areas where I diverge from known physics.
Given that the magnitude of force is within the materials ability to transmit it fast enough, applied energy, momentum, propagates through the system, not as motion, but as a reciprocal occilation. At initial application ,there is no actual motion at the point of contact, the energy is simply passed along , with no net motion of either molecules or pressure.
It is not until the entire system has received enough energy that there is actual coordinate movement of the system as a whole.
As the magnitude is increased and exceeds the ability to transmit it fast enough, there is a build up , a delay at the point of introduction which could result in actual compression until the whole system reaches the point of motion. The initial compression you mentioned.
But is there any reason to expect this to remain once the system is in motion and the momentum is uniform throughout the system and additional applied energy is constant?
Or to assume that the intermolecular tensile forces would not reach some kind of equilibrium with the applied force??
Even possibly a sustained occilation?
Even more important, is there any reason to expect ,not only a sustained compression but an incrementally increasing compression or expansion over time?
My own thought is that this would only be reasonable if it was a dynamic rate of acceleration.
Obviously the situation becomes more complex with more elastic subjects.
Say a spring. Where the vector of applied force would not be aligned with the path of propagation and the path length would be longer relative to the mass and system length.
Torsion effects etc etc. would seem to lead to more intitial compression or expansion but not neccessarily any more of a sustained or cumulative effect.
QUOTE] I don't have enough information in that case to even apply the Lorentz transformation, because those two events won't be simultaneous in any frame that's moving relative to the station frame, so I can't use them to determine the object's length in any other frame.[/QUOTE]
I am not completely sure what the implications are of all the above quotes as some of them seem to be in agreement with what I have been saying while others seem to disagree.
But one thing seems sure, taken all together they appear ro agree with me when I said that the situation is not as simple as it might appear.
You seem to have missed the point of what I was saying.
In this case the proposition is: Single point thrust from the rear of the system would result in system expansion. Expansion is the "problem"
Logically it would seem to follow that a physical solution to this problem would be a counter thrust applied to the front. A compressive thrust against the direction of motion.
Do you disagree with this logic?
It would also seem to follow that the addition of forward propulsion would not only not reduce expansion it would reduce the compressive effect of a single rear drive.
It would make sense if you wanted to reduce compression.
DO you disagree with this logic??
If
Consider either case.
A ruler that has not been Born accelerated longitudinally during the course of a long acceleration but is then reoriented during acceleration.
And then the same ruler a second after the engines are turned off.
What do expect the result to be in either case?
In the course of a prolonged acceleration according to the hypothesis , the system has undergone coordinate contraction as well as resisted assumed proper expansion due to the action of a specific physical acceleration , directional force. A ruler that has been translated while oriented transversely has not experienced this directed force along its length.
If rotated so that that length is aligned with the acquired motion [cumulative acceleration]
it should not be contracted according to the hypothesis unless you assume that it instantly
undergoes an equivalent acceleration through rotation, in which case I guess you could expect it to stretch and break unless it had Born rockets attached throughout to control the rotation?
Or other?
Out of context again.
So here is a more complete context.
PeterDonis
Original Austin0
_______________________________________________________________________
SO I was actually agreeing with you and somehow this was reinterpreted into implying that I thought there was no physical interpretation or meaning to Lorentz effects in SR.
In fact you seem to be contradicting yourself, since you have said more than once that physical assumptions were irrelevant to the application of the coordinate transforms.
I am happy to see an area of at least partial agreement ;-)
We haven't yet touched on the basis for the Born hypothesis. I hope you don;t get tired of this topic before we do as I am sure you are a lot more knowledgeable and I am very curious.
Thanks
You're correct that, in specifying that the rocket engines at the front and rear end of the ship each imparted the same constant proper acceleration to their ends of the ship, I was assuming that the engines could do that independently of the forces exerted on the front and rear ends by other parts of the ship. In any real case, that would mean the engines would have to be controlled very precisely, to maintain the same constant proper acceleration; for example, as the ship started to stretch, the segment of the ship just to the rear of the front end would start pulling back on the front end, so the rocket engine at the front end would have to increase its rate of fuel burn *just* enough to compensate for this extra pull, in order to maintain the same constant proper acceleration. Since that's not physically impossible (however unlikely it might be in practice), it doesn't invalidate my specification of the scenario, since it's just a thought experiment.
This isn't a matter of interpretation; the two have to be connected, because of conservation of momentum. The applied force is
[tex]F = \frac{d P}{d \tau}[/tex]
where P is the energy-momentum 4-vector of the small segment of the ship that's being accelerated, and [itex]\tau[/itex] is the proper time of that same small segment. But we have
[tex]P = m U[/tex]
where m is the rest mass of the segment and U is its 4-velocity; so we have
[tex]F = m \frac{d U}{d \tau} = m A[/tex]
where A is the proper acceleration (i.e., the rate of change of 4-velocity with respect to proper time). This is the relativistic version of Newton's second law, and if momentum is conserved, it *has* to hold.
Again, this isn't an assumption, it's a *definition* I've made in order to make it easier to avoid confusion between what I've been calling kinematic and dynamic effects. You can define "Lorentz contraction" to include those dynamic effects, if you want to, but then you'll have to come up with a different name for the kinematic ones, because they'll still be separate, conceptually, from the dynamic ones.
Mach 1 *is* the limit--the speed of sound in a given substance is the limit of how fast applied forces can be propagated in that substance. But the speed of sound varies widely according to the substance. The speed of sound in air, which is what people usually refer to as "Mach 1", is pretty slow as sound speeds go, about 340 m/s, or 10^-6 x the speed of light. In water the sound speed is about 5 times that, about 1500 m/s, and in steel it's about 20 times that in air, about 6,000 m/s.
Sound speeds in plasmas (such as, for example, the Sun) can actually get up to a few percent of the speed of light. For example, using the "ion sound velocity" formula from http://en.wikipedia.org/wiki/Plasma_parameters#Velocities", with parameters typical of the Sun's core ([itex]\gamma[/itex] = 5/3 for a non-relativistic plasma, [itex]T_e[/itex] = 1,500 eV, Z = 1 and [itex]\mu[/itex] = 1 because the Sun is mostly hydrogen), yields a sound speed of about 5 x 10^7 cm/s, or about 2/10 of a percent of the speed of light; and the Sun is actually a fairly cool plasma--larger stars have significantly hotter cores, and therefore higher sound speeds.
The muons that were trapped and their lifetimes measured to check the clock postulate experienced accelerations up to 10^18 g. There's nothing physically impossible about such accelerations, and someday we may learn how to make macroscopic objects that are able to withstand them; the laws of physics don't prohibit that. Anyway:
Yes.
The speed of transmission of forces through an object (i.e., the sound speed) doesn't depend on the magnitude of the force. Small forces don't get transmitted any faster than large ones.
*How* the force gets transmitted does depend greatly on the physical constitution of the object--see next item.
Unless the point of application of the force is physically restrained in some way so that it can't move (i.e., if there's no counterbalancing force to work against the applied force), it *will* move upon application of the force. That is, the individual atoms or molecules of the object will move; at the atomic/molecular level, of course, the applied force is transmitted by interactions between the atoms/molecules--more precisely, by the electrical repulsion between the electrons in the atoms/molecules.
As the first "layer" of atoms/molecules in the object move in response to the applied force, they will, of course, move closer to the next "layer" in the object, and will thus exert a force on that next layer. In other words, the applied force starts a "wave" of force moving through the object--more precisely, a longitudinal wave (i.e., a sound wave) of alternating compression and expansion, as each layer pushes against the next, which then responds by moving away and pushing against the next in turn.
If we assume that the applied force at one end of the object continues to be applied, then once the initial wave has traveled the length of the object, it will start to be damped out. This is because as each layer pushes against the next, not all of the energy in the push gets converted into motion of the next layer; some of the energy goes into the internal degrees of freedom in the atoms/molecules--i.e., it gets converted into heat. If the material is very stiff (e.g., very high tensile steel--or even better, carbon nanotubes), the wave will be damped out quickly; if the material is soft, it will take longer for the wave to be damped out. While the wave is damping, the object will be oscillating, expanding and compressing with gradually decreasing amplitude. Once the wave is damped out, the object will be in a state (assuming the force continues to be applied at one end) in which there is a compressive stress all along its length, and in which its material is somewhat hotter than it was before the force was applied (because some of the applied energy got converted into heat during the damping).
As the above analysis shows, it wouldn't; it would result in compression.
__________________________________________________ _____________________
I know that we agree that converting coordinates from one *inertial* frame to another is just "kinematics"; but you appeared to be saying that that was *not* true of accelerating frames. I'm saying that, since an "accelerating frame" at any given event on an accelerated worldline is just the MCIF at that event, what applies to inertial frames applies equally to "accelerating frames". Converting coordinates from an inertial frame to an "accelerated frame" is just converting from the inertial frame to the MCIF, which is another inertial frame. So it's just "kinematics" in both cases. All the physics is in how you determine *which* accelerated worldlines you're dealing with. As long as we agree on that, I'm good.
I'm certainly not tired of the topic. If you have a question about the Born hypothesis, please ask.
