Is Fire a Plasma? Answers & Discussion
  • Context: High School
  • Thread starter Thread starter Synetos
    Fire Plasma
The discussion revolves around whether fire can be classified as a plasma, exploring the nature of fire, its ionization, and the conditions under which it exists. Participants examine the chemical processes involved in combustion and the characteristics of plasma, including temperature and ionization levels.
  • Some participants propose that fire is simply the breakdown of hydrocarbons into water and carbon oxides, suggesting it consists of hot air and vapor rather than being a plasma.
  • Others argue that plasma is defined as a gas that is completely ionized, and while fire may contain some ions, it does not meet the criteria to be classified as a plasma.
  • A participant mentions that certain flames can contain ions that are affected by magnetic fields, hinting at a partial ionization in some cases.
  • There is a suggestion that the glowing of flames may be due to soot and solid particles rather than ionization, raising questions about the visibility of different types of flames.
  • One participant suggests a method to test for ionization in flames using a circuit and a lightbulb, indicating a practical approach to exploring the topic.
  • Another participant references a NASA link that states fire is not a plasma, while also acknowledging that ions can exist in flames, albeit in very low quantities.
  • A later reply suggests that fire could be considered a very weak plasma, but emphasizes that it is not a strong example of one.
Participants do not reach a consensus on whether fire can be classified as a plasma. Multiple competing views are presented, with some arguing against the classification and others suggesting that fire exhibits some characteristics of plasma.
The discussion highlights the complexity of defining fire in terms of plasma, with varying definitions of ionization and the conditions under which it occurs. There are unresolved questions regarding the extent of ionization in flames and the influence of soot and other particles.
Synetos
So is it? I had a long discussion about it in school and the internet gave very mixed answers. Because we are wondering if fire is ionised and this magnetic?
Fire is just the process of hydrocarbons breaking down into water and carbon oxides. It is hot air and vapor.
Plasma is atoms becoming new atoms. Usually protons and neutrons being combined to make a heavier more complex atom. It is much hotter.
But is it ionised?
I don't know. It is in such a chaotic state. Are you trying to find if the substance as a whole has a charge?
A plasma is just a gas hot enough to be completely ionized. What you are describing is nuclear fusion. Granted, at the temperatures required for fusion, it would probably be taking place in a plasma. But that does not mean that they are synonymous.
I stand corrected. I suppose that's why plasma tvs don't get as hot as a sun.
But it is partly ionised, otherwise this would not be possible:
Some flames (I'd hazard but not commit to all, due to the randomness involved) contain ions which can be affected by magnetic fields. You can dope the flame to have more ions and make a Flame Speaker: http://en.wikipedia.org/wiki/Plasma_speaker
Yea, I've heard of those, they are awesome. :P
I should make a post asking how exactly they make the air vibrate in the right way.
The gas given off in combustion is usually CO2 and some water vapor. Take a look at the ionization energies of these gases and see if its reasonable to assume that they can be ionized at the temperature fire normally burns at.
So it is plasma? xD
I don't think so. Remember that fire is also associated with soot and smoke - and in fact if you've ever seen a "dirty flame" it glows brightly while a "clean flame" is almost invisible.
I would suspect the glowing is mostly due to the little bits of soot and solid particles in the flame. I think I know a way you can test this though:
Take a 9V battery, connect it to a small lightbulb but somewhere in the circuit introduce a gap across the wire. First make sure your circuit is working by placing the gap in some salt water and seeing if your light turns on. If it's working, try now holding the gap inside of a flame.
A better way would be to try to do it using a multimeter, but you probably don't have one of those handy.
We have some at uni, I might be allowed to try it, if they won't nag about me putting those connectors in fire :P
In combustion, we would be happy if we got only molecules like CO2 and H2O, but sadly no combustion process is 100% perfect. Therefore, ions do exist in a flame, but not nearly enough to be detectable (the above NASA link simply said that a standard multimeter would not detect a current, implying very few ions). So a proper answer would be, fire is a very, very weak plasma. Almost not.
11K
