Is gravity an emergent phenomenon?
66 replies · 22K views
baywax
If this has been covered or is so fundamental a question that its dumb... please excuse me...:redface:... otherwise, an answer is appreciated, thank you!
Actually I just realized its probably a property if it is emergent at all.
Another two properties I'd like to know about in terms of emergence are light and heat. Are these two emergent properties at all?
Out of those three, heat is the only 'emergent' property.
I'd say gravity it's not an emergent phenomenon, because it's not generated by the complex interaction of simple systems. In GR gravity is just the space-time curvature produced by mass-energy-momentum.
While there has been research done that shows hints of the possibility that gravity can be understood as a thermodynamic phenomena, it's certainly not mainstream. Black holes have a temperature. This has lead to speculation about what this really means for gravity as a whole. Nothing has really come of it, however.
Yes, gravity is an emergent phenomena as are all observable phenomena. The language of emergency allows all of nature to be explained in terms of one observable emerging from an underlying organizational feature of constituent building units. These building blocks of matter have emergent arrangements in three dimensional space that improve the use of space relative to the disorganized units. The result is energy lowering for the system and stabilization of the organizational matrix.
Wow, thanks everyone...
So, on the microscopic level of the quantum universe gravity continues to exist and therefore is not an emergent property... ie loop quantum gravity?
In what way is it that light escapes the label of "emergent property"?
Light is an emergent property. We know this because the quantum field theory (quantum electrodynamics) that describes light at low energies is mathematically inconsistent at high energies. So quantum electrodynamics is just an approximation to another theory, and "emerges" from that still unknown theory.
There are constructions in which QED emerges at low energy from something different. However those theories don't get other sorts of matter correct (yet?), so it is still unknown how QED in our universe emerges.
By "unknown" theory, do you mean "unproven"?
From a purely semantic point of view, I don't think the uses of 'emergent' as it has been applied to gravity (@rkirby) and light (@atyy) are correct:
See:
http://plato.stanford.edu/entries/properties-emergent/"
http://cscs.umich.edu/~crshalizi/notabene/emergent-properties.html"
Laughlin, Robert (2005), A Different Universe: Reinventing Physics from the Bottom Down, Basic Books
An emergent property is one which arises from a collection or system, each element of which does not exhibit said property, and is fundamentally at a higher level of abstraction.
rkirby7 said:
Yes, gravity is an emergent phenomena as are all observable phenomena. The language of emergency allows all of nature to be explained in terms of one observable emerging from an underlying organizational feature of constituent building units...
And in this case, I don't see what 'underlying organizational feature' the poster is referring to... Perhaps the poster is suggesting that gravity emerges from the fundamental properties of space-time; if this is the case, I would reply that gravity is simply tautological with the nature of space-time, nor is space-time any time of conglomerate or assembly of smaller elements.
atyy said:
Light is an emergent property. We know this because the quantum field theory (quantum electrodynamics) that describes light at low energies is mathematically inconsistent at high energies. So quantum electrodynamics is just an approximation to another theory, and "emerges" from that still unknown theory...
This line of reasoning suggests that our understanding of light is simply incomplete, not that it 'emerges' per se from more fundamental principles. If one assumes that gravity is not emergent (it doesn't matter for this example if that is true or not), then it is no more or less emergent in an incomplete Newtonian understanding of gravity than in a full general relativistic framework.
Additionally, from a particle perspective, if the photon and graviton are viewed as fundamental particles---they clearly cannot be emergent.
Now, even from a non-semantic perspective, I don't see that its in any way informative to view light or gravity as an emergent property. We know of no underlying system which in a macroscopic sense gives rise to these phenomenon. If such systems exist, the case may need to be reconsidered, but at the moment the point would be purely speculative, unverifiable and irrefutable---and thus not science.
See:
As far as I know,
"Light is created when electrons absorb the energy of photons. The excess energy from absorbing this photon results in light because an electron can only absorb so much energy and then has to release the rest."
http://answers.askkids.com/How_Stuff_Works/how_is_light_created
So from this microscopic, quantum level of interaction between electrons and photons, light emerges. This sounds like the formula for an emergent property.
While most of this statement is true, per se; it is in no way an explanation for how light is created. Also, its just a bad description of physical processes.
Let me paraphrase the above quotation: 'light is created when light hits an electron, because electrons can only have so much energy'.
1) It starts out with light, thus its not especially helpful in presenting a primary cause of light.
2) This is an accurate example of a single type of electron-photon scattering interaction, which isn't especially interesting or insightful about the physical processes.
3) An electron can hold an arbitrarily large amount of energy, but not necessarily stably---in a particular situation.
But anyway, that is all somewhat unrelated... It still suggests nothing about light emerging from more fundamental processes or systems.
Here you are just stipulating that light "emerges" from something, and then using that as evidence that light "emerges" is general. That doesn't quite work.
Again, you're starting with photons (photons = light) and thus it doesn't make sense to say light emerges from light. Also, as I tried to illustrate with the references I cited, interactions don't warrant "emergent phenomena".
As a final note, askkids.com isn't a source which holds much water.
I was under the impression that:
"In physics, a photon is an elementary particle, the quantum of the electromagnetic interaction and the basic unit of light and all other forms of electromagnetic radiation. It is also the force carrier for the electromagnetic force."
http://en.wikipedia.org/wiki/Photon
and that the photon is not restricted to the description of a unit of light.
All true.
'Light' can mean the visible spectrum (although this would make the common phrase 'visible light'
redundant), the visible and near-visible (IR and UV) spectrum, or colloquially the entire electromagnetic wave spectrum. Photons apply to the entire spectrum, not just the visible---if that's what you are saying, then that is correct.
There is still nothing here to suggest that light 'emerges' from photons, or anything else for that matter.
The photon is the quantum of excitation of the electromagnetic field. First come the field, then the photon.
The two are inextricable. Neither came first, nor second.
Yes, they are inextricable, but what I mean is that to talk of "a quantum of excitation of an em field", you first must have the concept of "the em field".
I do appreciate what you're saying, but I think (as wittgenstein would point out) this is just a feature of our language and way of thinking about things, not of the underlying physics.
Does this article help?
Origin of Light
Xiao-Gang Wen¤ Department of Physics, Massachusetts Institute of Technology, Cambridge, Massachusetts 02139
(Dated: June 15, 2001)
The existence of light (a massless U(1) gauge boson) is one of unresolved mysteries in nature. In this paper, we would like to propose that light is originated from certain quantum orders in our vacuum. We will construct quantum spin models on lattice to demonstrate that some quantum orders can give rise to light without breaking any symmetries and without any fine tuning. Through our models, we show that the existence of light can simply be a phenomenon of quantum coherence in a system with many degrees of freedom. Massless gauge fluctuations appears commonly and naturally in strongly correlated quantum systems which originally contain no gauge fields.
http://dao.mit.edu/~wen/pub/light.pdf
No, it doesn't. A speculative, unrefereed, non-mainstream or established article from 10 years ago with numerous typos and grammatical errors in the abstract (alone), is not helpful.
Here's a little more about one of the authors...
http://en.wikipedia.org/wiki/Xiao-Gang_Wen
I'll agree that it's speculative, but the article was published in PRL: http://prl.aps.org/abstract/PRL/v88/i1/e011602
If mass is an emergent phenomenon/property, wouldn't that make gravity the same?
Here's what wiki says about mass being an emergent property:
In some theories of particle physics, even such basic structures as mass, space, and time are viewed as emergent phenomena, arising from more fundamental concepts such as the Higgs boson or strings. In some interpretations of quantum mechanics, the perception of a deterministic reality, in which all objects have a definite position, momentum, and so forth, is actually an emergent phenomenon, with the true state of matter being described instead by a wavefunction which need not have a single position or momentum. Most of the laws of physics themselves as we experience them today appear to have emerged during the course of time making emergence the most fundamental principle in the universe and raising the question of what might be the most fundamental law of physics from which all others emerged. Chemistry can in turn be viewed as an emergent property of the laws of physics. Biology (including biological evolution) can be viewed as an emergent property of the laws of chemistry.
http://en.wikipedia.org/wiki/Emergence
Gravity couples to energy, not just mass. That's how massless particles like the photon interact with gravity. So emergent gravity does not directly follow from emergent mass.
fzero said:
gravity couples to energy, not just mass. That's how massless particles like the photon interact with gravity. So emergent gravity does not directly follow from emergent mass.
e=mc2?
baywax said:
e=mc2?
No, that's the expression from special relativity for the energy of a massive particle at rest. The central equation of general relativity is
[tex]R_{\mu\nu} - g_{\mu\nu} R = \frac{8\pi G}{c^4} T_{\mu\nu} .[/tex]
The quantities on the LHS describe the curvature of spacetime, while [tex]T_{\mu\nu}[/tex], called the stress-energy tensor, describes the energy and pressure of the matter that acts as the source for gravity. You can read a bit more at http://en.wikipedia.org/wiki/Einstein_field_equations#Mathematical_form The point is that [tex]T_{\mu\nu}[/tex] does not depend only on mass, but also involves electromagnetic energy, fluid pressure, and anything else that contributes to the energy of a collection of matter.
OK... this is really interesting. But, does this mean matter, an emergent phenomenon, gives rise to gravity as well as electromagnetic energy etc... and does that make gravity emergent as well?
Further to this... is energy an emergent property?
Thank you!
No. The RHS of the Einstein equation is the energy of matter, which may not be emergent. The LHS is the gravitational field, which may also not be emergent. (Actually the gravitational field is in the RHS too, since the energy of matter cannot be defined without it. However this indicates the mutual interaction of matter and gravity, not the emergence of one from the other.)
However, there are research programmes in which gravity and matter both emerge from more fundamental degrees of freedom (ie. the Einstein equation emerges as a limit of other equations). String theory is an example of such a programme.
The contrasting programme in which gravity is not emergent is called Asymptotic Safety.
