Is Gravity Really a Fundamental Force?
  • Context: Graduate
  • Thread starter Thread starter Searching
    Force Gravity
The discussion centers around the nature of gravity and whether it should be considered a fundamental force. Participants explore various perspectives on gravity's characteristics, its relationship with mass, and the implications of general relativity.
  • Some participants question why gravity is not associated with a detectable particle and why it is significantly weaker than other forces.
  • There is a suggestion that gravity might be an effect rather than a fundamental force, possibly linked to the properties of space-time or dark matter/energy.
  • General relativity is discussed, with some asserting that it describes gravity as a deformation of space-time rather than a force.
  • Participants debate the concept of mass, with some arguing it is a fundamental property of matter while others suggest that mass could be a manifestation of space-time curvature.
  • Some contributions emphasize that gravitational effects can still be interpreted as a form of interaction or force, despite the framework of general relativity.
  • There are differing views on whether gravity should be classified as a force, with some advocating for a broader interpretation of the term.
  • Concerns are raised about the lack of understanding regarding the cause of mass and its relationship with gravity.
  • One participant proposes that mass might be conceptualized as bumps in the fabric of space-time rather than a separate entity causing curvature.
  • Some participants express uncertainty about the implications of space-time curvature and its relation to the existence of gravity.
Participants do not reach a consensus on whether gravity is a fundamental force or merely an effect. Multiple competing views remain regarding the nature of mass and gravity, as well as the implications of general relativity.
The discussion highlights limitations in understanding the fundamental nature of gravity and mass, as well as the dependence on various theoretical frameworks. There are unresolved questions about the relationship between mass and space-time curvature.
  • #31
DaveC426913 said:
It is possible to create an image showing a gravity well in three dimensions.
You still have the xyz grid but, rather than joining points on the grid with lines, you put a little vector at each intersection pointing in the direction of the apparent force.
Maybe someday I'll sit down and make it.
Drawing force lines sounds possible. Have fun ;)
  • #32
Polyrhythmic said:
I'm not sure how the statement "mass is space-time curvature" could make sense. The concept at hand, which general relativity gives us seems sufficient. It kind of works two ways: mass moves through spacetime and mass curves spacetime.
First of all, thanks you guys. This place is great! But to the question of what is spacetime. It seems that everything is matter/energy. Wouldn't space time also have to be? Otherwise, what is it made of?
Before we could detect the atmosphere people must have thought the it was empty space. Couldn't the same be true for the matter/energy that makes up spacetime?
  • #33
MegaDeth said:
Oh right, do objects on the Earth curve space time as well or does it only account for in space?
FYI, you're never going to find a fundamental theory in physics where something only happens "in space" and not "on earth" (or vice versa), i.e. that there is anything special about Earth vs. anywhere else in the universe. The laws of physics (as far as we know) are the same everywhere. All of them.
  • #34
MegaDeth said:
I actually mean 3 dimensions of space. Because in the picture, it only shows what happens at the bottom half of the Earth.
You can't visualize 3 dimensional surfaces, we only see 3 dimensions, so we can only visualize 2-dimensional surfaces. However, MATHEMATICALLY it's quite easy to work with such things. This is a point that never comes across when PBS Nova or whatever talks about higher dimensions and such. Physicists don't VISUALIZE 11 dimensions or any such nonsense, it's all in the math, and the math of higher dimensions isn't particularly difficult and ideally (stressing ideally) you then get some number which predicts the value of a certain experiment, if you then do the experiment and get that value then you may have been on to something with your higher-dimensional theory.
However, to get some idea of how space-time curves in 3 dimensions look at this: http://en.wikipedia.org/wiki/File:Black_hole_lensing_web.gif this is an example of what is called gravitational lensing. Light (photons) have no mass and thus if gravity really worked like Newton thought (G M m/r^2) it would not feel gravity, but GR says gravity is really a distortion of space-time and thus light, just light everything, just travels in a straight line, except in the presence of mass a "straight" line becomes curved by the distorted geometry. So what you're seeing there is the light from some far-away galaxy or nebula being curved around the space-time distortion caused by some large mass between us and the galaxy in the background (like a lense).
  • #35
I'm not sure how the statement "space is matter/energy" makes sense. Space is what contains matter/energy. It's some kind of dynamical background everything takes place on. If space actually was something, you could ask even further: What contains space?
  • #36
Science Fiction tell us this this is obviously subspace.
  • #37
Hah. Right.
  • #38
Can someone help me understand in a way that I can comprehend why we are some certain gravity is a fundamental force?
Maybe a little bit:
From nothing, thanks to a big bang, everything, EVERYTHING, we observe popped out or had it's origins in "nothing"...maybe a virtual particle fluctuation of some type...nobody knows...nor what caused the big bang nor ANY of the 'fundamental' entities which emerged.
It is believed that from the big bang, spontaneous symmetry breaking led a unified (combined) entity of some type to breakdown into the entities we see today...and which now eappear as separate "fundamental" entities, those that appeared almost togther...forces, mass, energy, space, time,etc, and later all the particles we observe.
We don't have a complete theory of gravity...Einstein's GR is the large scale view and Quantum mechanuics offers some small scale view of gravity...but combining them so they agree is as yet incomplete...right now that unification effort falls under the general heading "quantum gravity".
You can check out any of these terms in Wikipedia.
  • #39
Naty1 said:
[...] Quantum mechanuics offers some small scale view of gravity [...]
How does quantum mechanics offer a small scale view of gravity? Quantum mechanics tells us nothing about gravity. The problem is to apply the formalism of quantum mechanics on gravity, to quantize gravity. But it has not been solved so far.
  • #40
You can't say that gravity is just something that forces certain large objects of mass in space together because of how gravity affects us on earth.
See I think a lot about gravity because of the potential that comes with understanding it. Gravitational travel, and ways of generating energy through existing forces such as gravity, is something that interests me a great deal.
I see what you're saying and on some levels I agree, to me it feels more likely that gravity is an electrical force. All particles in matter have electrical energy and every interaction that objects have with one another is electrical because electricity within particles is the key to their information. If we assume for a moment that gravity is electrical particles trying to establish a meak connection then gravity really comes across a sort of magnetism.
I mean this in a way similar to how atoms are kept in perfect balance by electro-statistical forces.
Of course I'm tired, it's late, and that means that my lack of knowledge for this subject is shining through more than ever. I really just know words, and that's why when I put them together to try and establish a proposition on a forum like this, full of people who know their stuff, it's really just to find out some more information that can help me develop my capacity for this subject.
  • #41
We've sent men and spacecraft to the moon, spacecraft to every single planet in the solar system and to some non planets as well, we can see the effects within other solar systems and how they interact, and all of it points to gravity and all other forces to be exactly the same everywhere.
We already understand the effects of gravity. I can't see any realistic way of generating gravitational travel nor energy (barring things like hydroelectric power and fusion inside stars and etc). I hope you aren't referring to something similar to "free energy" devices.
That doesn't make any sense.
I can't see any relation between how atoms behave and gravity. Could you elaborate?
  • #42
i believe elec-stat force works like em and gravity. the four forces work their jobs and i believe that they are a lot alike. desite the diff in scale. they hold everything together.
  • #43
The electro-static force is another name for the electromagnetic force. While the four forces are similar in function, they are still very different in the details. For example, the EM force has 2 charges, + and -. Gravity, if treated similarly, only has 1 charge. On the flip side, the strong force has at least 3 different charges, or "colors", that quarks can have.
  • #44
Yes, but not always with the same strength? In some places gravity is stronger than others. I mean that has nothing to do with my initial response but ah well.
Well if we could use gravity to pull things together then 1) Nuclear fusion would be possible 2) We could contain without electromagnetism.
Electricity is formed by a charged particle right? All I mean to say is, would it be possible that the type and power of the charge from every particle affects how they attract others? In this sense Gravity could work on a much larger scale, just like magnetism but with a basis in motion. Everything with gravitational pull has a constant motion.
That's the point, and that's the problem. Quantum physicists and Cosmologists are still looking for a way to quantify everything large by everything small. The idea I was proposing that atoms can be related to much larger systems like planetary orbits if we assume that there is a correlation between the forces at work in an atom and the forces at work in a planetary system.
  • #45
Really? I always thought that Electro magnetism is a force generated by moving charges, and electro static is from startic charges?
  • #46
Back in the 18th and 19th centuries (1700's-1800's), it was believed that the Magnetic and Electric forces were two different forces. However experiments showed that a magnet can generate electric forces, and an electric force can generate a magnetic force. Eventually it was realized that both were a manifestation of the same force, the Electromagnetic force. Similarly it was realized that the Weak force and the Electromagnetic force could be combined as well, into the Electroweak force.
  • #47
The gravitational laws are the same everywhere. Gravity is just stronger in the presence of heavier objects.
But gravity is much weaker than electromagnetism. By a huge amount, the difference is around the order of 10^40.
Gravity pulls, that is correct and nothing new. What do you mean by constant motion?
Even though the idea seems tempting, there's no reason to assume that atoms behave in any way like planetary systems. The introduction of quantum mechanics has definitely destroyed any possibility for such a view.
  • #48
The amount of gravity an object has is DIRECTLY proportional to its mass. Gravity has never been shown to vary anywhere. Only the amount of mass nearby to our probes and spacecraft changes as they move around.
The universe already does that via stars. The amount of mass required for gravitational confinement is staggering to say the least. Honestly just throwing up solar panels or harnessing the heat from the sun is doing what you are talking about anyways.
Well, with a charged particle, two opposite charges bound together, for example in a Hydrogen atom, effectively cancel each others charges and make the atom overall neutral. However gravity only has one "charge" so to speak. Also I don't understand what you mean by everything with gravity has a constant motion.
But you are missing a very key point here. There is no correlation beyond vague similarity between planetary orbits and atomic orbitals. Electrons are not little spheres going in circles around the nucleus. They are wave packets that occupy set orbitals based on the energy level of the electron. (Warning: Incoming terrible explanation from an amateur) Imagine a guitar string with both ends wrapped around touching themselves so it forms a circle. If you could pluck the string the whole thing would vibrate as a "Standing Wave". Take this analogy, make it into a 3d version like a sphere, and you have an electron orbital. Each energy level can only vibrate at a specific frequency. The others don't "fit".
  • #49
Ah. Black holes. As far as we know their gravitational pull isn't from a huge amount of mass?
So you're saying that energy via nuclear fusion is useless? Harnessing the heat of 100 Million degrees centigrade is nothing to be laughed at. We wouldn't need fossil fuels at all.
Ok :) What I mean by everything with gravity having constant motion is that all planetary bodies spin, or turn, or whatever. The same, supposedly, is true for black holes but on a much more extreme level.
I understand Schrödinger's equation, energy levels of electrons and orbits of precise integers via the bohrian model. I'm just stating that there is some kind of correlation, and perhaps there are things that can be learned from atoms about the universe as a whole, and vice versa.
  • #50
Perhaps I didn't word it right. The amount of gravity per "unit" of mass is always the same. Black holes are most definitely caused by massive amounts of mass.
I was talking about Fusion due to gravitational confinement. Not magnetic or inertial or any other man made way.
Sure, but that isn't the cause of gravity nor does it have an effect on it.
Alright.
  • #51
We know space-time exists. We can observes its physical effects on planets and moons. Are you suggesting that something exists and effects the things around it, but is made of nothing? To me, that is what doesn't make sense.
As far as your question: What contains space? I don't know. The question in my mind is more along the lines of what exists beyond the point that space-time has expanded to. I don't know that either.
  • #52
Alright, because gravity doesn't always fit into a 3d sphere of motion, mainly it works with a fixed orbit. Is it probable that its realitive to our limited observations, and lack of a unified answer. I know I am out of my league, but the cause of gravity, leads to effects of energy on other bodies, right? So could the opposing effects, work as a second opposing force. Yes I know I am talking about the weaker force. I am tring to say, could a black hole open our eyes on how we observe atomic forces. Relatively speaking.
  • #53
Non - rotating black holes are like any other massive object as long as you don't go past r = 2m. The gravitational field outside such a black hole depends on its mass just like any other object.There is only a problem if you tread past r = 2m.
  • #54
The laws of gravity do not change anywhere. The rules for the effect of X amount of mass never change, on the moon there's just a lot less stuff (X is smaller). Just like Coulomb's law doesn't change if you have two electrons versus one, you just now have double the charge. Black holes are not an exception, they were once stars that collapsed in on themselves (due to gravity) after they exhausted their ability to undergo fusion. Stars are in a sort of equilibrium, their massive mass results in a constant gravitational "force" trying to collapse the star, but the absurdly high pressures cause hydrogen atoms to fuse to make helium, helium atoms to fuse to make beryllium and so on. These nuclear fusions release enormous amounts of energy that try to push outwards, this balance of gravitational collapse versus fusion is what gives a star its stability. As the core gets denser (i.e. as most of the hydrogen has fused to make helium, helium to make beryllium, etc.) the gravitational collapse will start to win the battle. Then one of two things happen, if the star is relatively small it will become a super dense compact star; such as a black hole, if it is large it will likely supernova.
I would also like to re-iterate what has been said many time already: The "orbit" of electrons "around" and atom (I use quotes because it is neither orbiting nor moving in time) is NOTHING like how a moon, say, orbits a planet. There's really nothing for it. Those images on like the cut-away CGI animations between scenes of the Big Bang Theory and such (you know http://www.epa.gov/radiation/images/atom.jpg these sorts of images) are simply completely wrong. That does not represent the behaviour of atoms in the slightest. Electrons have no set position, their position does not change in time, their angular momentum is quantized, etc. NOTHING LIKE PLANETARY ORBIT.
  • #55
That's what I'm suggesting. There is nothing outside of what we call spacetime, and we have no reason to assume that spacetime behaves analoguous to anything we could actually imagine. Whether that mates sense to us or not is another question, but if this description successfully accounts for our measurement, it should be considered a valid.
  • #56
What? Gravity works everywhere.
None of this makes any sense. What do you mean by a second opposing force? What is it opposing? What was the first one? As for the black hole affecting our view of atomic forces, it would only show us the effects of extreme gravity on an atom. Our current views would be unchanged.
  • #57
"3d sphere of motion"? What is that supposed to mean?
  • #58
3d sphere. I mean to say, In atoms the motion of electrons produces what i believe a bubble of matter. when i think of space-time gravity theroy, i can only see planets rolling around a drain, a 2d flat space. Am I way off base, thinking that way about gravity, or is it more of a 3d bubble solar system.
  • #59
Debt said:
3d sphere. I mean to say, the motion of electrons produces, what i believe a bubble of matter, limited to its charge. when i think of space-time gravity theroy, i can only see planets rolling around a drain, a 2d flat space. besides the drain of course. Am I way off base, thinking that way, or is it more 3d, bubble solar system.
Space is 3d and Spacetime is 4d. The analogy of spacetime like a flat grid that mass deforms is simply that, an analogy. My personal view is of 4 of those grids surrounding an object with the grids curving inward toward the object. The more massive it is, the more curving gets done.
  • #60
Gravity is the first force, I am asking if a second force that acts opposing gravity. I'm sure I'm just rusty.
  • · Replies 20 ·
