Is it possible to fly horizontally using augmented fly pack?
  • Thread starter Tabaristiio
In summary: How do other wingless aircrafts fly horizontally? Assuming enough power exists, can't human augmented jet packs / flight packs also fly like that? Or is it mandatory for the aircraft to have to travel at orbital speeds in order to accomplish this?Other wingless aircrafts fly horizontally by using a different type of propulsion. Augmented jet packs or flight packs cannot fly in a horizontal position because they do not have the required vertical thrust. To fly horizontally, the jet pack would have to be arranged in a way that produces a vertical thrust equal to the force of gravity.
Tabaristiio
61
Assume there is a wingless augmented flight pack such as a jetpack attached to a person's body. Assuming that there is sufficient amount of power.
will it be possible according to the laws of physics to fly in a horizontal position instead of a vertical position?
What are the requirements for someone to be able to fly horizontally using a wingless augmented flight pack?
This question ignores irrelevant factors such as health risks and etc. It's just asking if it's possible within the laws of physics to fly horizontally using a wingless flight pack.
I'm not sure if you are asking about horizontal flight or about pointing the jetpack horizontally.
The thrust would have two components -- one part vertical and one part horizontal. As long as the vertical part is equal to the force of gravity, the flight would be horizontal. That is a lot easier if the jetpack exhaust is pointing down. If it was pointing more horizontally, it would have to be a huge jet to have a downward component great enough to oppose gravity. Then the horizontal component and resulting horizontal speed of flight would be like a rocket.
Likes russ_watters
In skydiving (ski-jumping too) it is possible to shape one's body in the general shape of an aerofoil and gain considerable lift, one can even notice stall. Whether there is sufficient lift at non-injurious speeds I'm not sure.
Cheers
Likes russ_watters
Yes, I was referring to flying horizontally with the body in a horizontal position during flight. So does everything else you wrote still apply?
So the jet pack is horizontal -- purely horizontal thrust. And the person's body is horizontal. No lift from the person's body. No wings allowed. So there is no vertical thrust of any sort. Then the jet pack and human will fall like a rock and hit the ground. Possibly miles ahead if the launch was from the top of a cliff.
The only way out would be to reach orbital velocity. Move horizontally fast enough and the ground curves downward beneath you as fast as you fall. That would burn you to a cinder if it didn't tear you apart first. But we are told to ignore such issues.
The jet exhaust would have to tilt down. It needs a vertical component large enough to counteract gravity. It seems impractical to me. Wings are very important for horizontal flight.
What do you mean by a vertical component? Could you provide an example of something like that please?
The only rule is that the person's body is horizontal during flight and no wings are allowed. The jetpack itself can be arranged in anyway required in order to accomplish this and accommodate the body. If possible, it's allowed for the jetpack to be arranged in a way where it can do enable the horizontal fight. This includes enabling vertical thrust.
Tabaristiio said:
The only rule is that the person's body is horizontal during flight and no wings are allowed. The jetpack itself can be arranged in anyway required in order to accomplish this and accommodate the body. If possible, it's allowed for the jetpack to be arranged in a way where it can do enable the horizontal fight. This includes enabling vertical thrust.,
Sure that would work. Point the jets down at some angle and some of the thrust stops him falling and some pushes him along horizontally. Take a look at the Harrier jump jet and it's vectored thrust. Yes it has wings but at slow speeds these have no lifting effect.
Likes FactChecker
Any force can be divided into parts of force in different directions. The force of a jetpack can be divided into the force upward and the forces sideways (horizontally). You can call those the components of the total force.
1. Can humans fly horizontally using an augmented fly pack?
Currently, there is no technology that allows humans to fly horizontally using an augmented fly pack. However, there have been experiments and prototypes that suggest it may be possible in the future.
2. How does an augmented fly pack work?
An augmented fly pack is a device that uses advanced technology to mimic the mechanics of flight. It typically consists of wings or propellers that are powered by a motor and controlled by a computer system.
3. What are the limitations of using an augmented fly pack?
Some limitations of using an augmented fly pack include the weight and size of the pack, as well as the power source needed to sustain flight. It also requires a significant amount of training and skill to operate safely.
4. Are there any safety concerns with using an augmented fly pack?
As with any form of flight, there are potential safety concerns with using an augmented fly pack. These include the risk of crashes and collisions, as well as potential malfunctions or errors in the technology.
5. What are the potential uses of an augmented fly pack?
An augmented fly pack could have various uses, such as recreational activities, transportation, and search and rescue missions. It could also have military and defense applications, although these have not been fully explored yet.
  • General Engineering
  • Mechanical Engineering
  • Classical Physics
