Is it the protons or electrons that are responsible for an element's propert
  • Thread starter Thread starter Modernization
    Electrons Protons
The discussion centers on the debate regarding whether protons or electrons are responsible for an element's physical and chemical properties. Participants assert that electrons, particularly valence electrons, govern chemical reactivity and influence physical properties such as boiling and melting points. While protons define the identity of an element and its electron count, the consensus is that the interactions between electrons and the nucleus primarily dictate an element's characteristics. The conversation highlights the complexity of atomic structure and the role of isotopes in understanding these properties.
  • Understanding of atomic structure, including protons, neutrons, and electrons
  • Familiarity with the concept of valence electrons and their role in chemical bonding
  • Knowledge of isotopes and their significance in chemistry
  • Basic principles of physical properties such as boiling and melting points
  • Research the role of valence electrons in chemical bonding and reactivity
  • Study the impact of isotopes on the properties of elements
  • Explore the relationship between atomic structure and physical properties of substances
  • Learn about the periodic trends in atomic properties and their implications
Chemistry students, educators, and anyone interested in deepening their understanding of atomic theory and the factors influencing element properties.
Modernization
[SOLVED] Is it the protons or electrons that are responsible for an element's propert
On a chemistry test I took, there was a question that asked "What subatomic particle is responsible for an element's physical and chemical properties"?
I picked the "proton" as the answer choice, but the teacher's answer is "electron"
I do not see why her answer is correct, not saying that I'm right. I understand that the electron, valence electrons respectively, are responsible for chemical reactivity. But what about physical? Since the number of protons also determine the number of electrons, the protons should be considered when it comes to elements physical and chemical properties. Physical, besides appearance, would be like boiling point and melting point and how can those properties be based on the number of electrons? the electrons are only responsible for chemical reactivity, right? If you know any sources, please cite them...
Thanks
Chemistry news on Phys.org
electrons are responsible for bonding.
therefore, boiling point, melting point, etc. are determined by the electron.
Chemistry, really is all about the study of the outer electrons of an atom.
The proton merely is a signature for an element. i.e it determines number of electrons in an electrically neutral atom
Obviously if it is a huge element with lots of nucleons, then the physical properties will be inherently different (although the electrons still play a significant role), but the electrons are responsible for the chemical properties.
Thanks
That is a common question and the common answer is "electron"; but, actually, it's not a deep one. If you want to make your teacher feel uncomfortable, ask him/her: "So, if I remove a proton from an hydrogen's atom, I still have an atom with the same physical and chemical properties?" :wink:
This is a terrible question. There ought to be a good way to prevent this horror from being inflicted upon more students.
No, does it even exist, actually?
if it only has 1 neutron in the nucleus, then there will be no electronic attraction to the electrons, then either the ionization energy of that is VERY low, or even non existent, or is probably is somewhere else right now.
If you remove a proton from say, Calcium, then it SHOULD change some properties. Since there is less electronic attraction to the electrons, so...
The H-atom has no neutrons.
If you pull a proton out of Calcium, you get K- (the number of neutrons matches). The latter is super reactive and will reduce anything within a mile of it.
I guess that when they say "properties", it means a specific element. Since changing the number of protons (typically) changes the element, that doesn't satisfy the question.
It still is quite a terrible question, though.
Yes, it's terrible the same because the physical and chemical properties of an atom are given by the atom as a whole: the electrons's orbitals are not created by electrons only, but from the interaction nucleus-electrons.
I did not know that. So in the molecule H2 there is no neutrons present, only 2 protons and 2 electrons?
In a Pure Hydrogen Sample, MOST of the hydrogen will have no neutrons.
Then there are isotopes.
Deuterium and Tritium are isotopes, and they increase 1 and 2 neutrons respectively.
Yes; is it surprising for you?
Certainly, as Invictious said, in a normal (that is, non prepared) sample of hydrogen, there are all the three isotopes: H2, D2, T2, but H2 is the greater percent: 99.985%; D2 is 0.015% and T2 only traces. See:
http://en.wikipedia.org/wiki/Hydrogen
  • · Replies 46 ·
  • · Replies 16 ·
