Is mathematics invented or discovered?
  • Thread starter Thread starter Meden Agan
64 replies · 7K views
Meden Agan
The question ‘is mathematics invented or discovered?’ is a much-debated issue in the philosophy of mathematics. It is a classic. I would like to know what you think about it.
Below is my view.
IMO, the question ‘is mathematics invented or discovered?’ pits two equally plausible intuitions against each other. On the one hand, mathematicians choose symbols, definitions and axioms; on the other, once the rules are set, they encounter facts that cannot be changed at will. To bring some order to this, it is useful to distinguish between three levels: syntax (the signs and rules of deduction), semantics (the abstract structures to which those signs refer) and application (the relationship with the physical world). “Inventing” mainly concerns the first level; “discovering” concerns the second; effectiveness in science concerns the third.
On the discovery side, mathematics shows objectivity and necessity. Once Euclidean geometry has been established, Pythagoras' theorem does not depend on the taste of those who prove it. Fermat's Last Theorem didn't become true because Wiles proved it: the proof only revealed a truth already implied by the axioms of arithmetic and set theory used in the proof. The historical convergence of distant cultures on concepts such as natural numbers, divisibility, or symmetry suggests that there are robust structures that our cognitive activity encounters rather than creates.
On the invention side, however, foundations matter. Non-Euclidean geometry arises from modifying an axiom; topology arises from introducing a new notion of neighborhood; functional analysis invents spaces and norms; category theory reorganizes mathematical objects in terms of arrows and composition. These choices open up entire continents of otherwise inaccessible results. Furthermore, some statements are independent of the most commonly used axioms: the continuum hypothesis cannot be proven or disproven starting from Zermelo–Fraenkel–Choice (ZFC); the same is true for many statements about large cardinals. Here, the discipline shows pluralism: there are several coherent “mathematical worlds”, each with its own truths. This is strong evidence in favor of the constitutive role of invention in establishing the framework within which we then reason.
A rigorous way to bring the two approaches together can be as follows. Mathematics studies possible structures. We invent formal languages and choose axioms that isolate a class of structures; within that class, truths are no longer invented, they are discovered. Logic makes this transition precise: “provable” means obtainable syntactically from axioms and rules; “true in a model” means satisfied by a structure that interprets those symbols. The first-order completeness theorem guarantees that what is true in all models of an axiomatic system is also provable, and vice versa. At the same time, the incompleteness theorems say that, for sufficiently rich systems, there are arithmetic truths that cannot be proven within the system: a sign that discovery is not exhausted in a single formal framework and that sometimes axiomatic extensions guided by internal mathematical criteria (fertility, consistency, explanatory power) are needed.
Concrete examples clarify the intertwining. Non-Euclidean geometries are ‘invented’ by modifying the parallel postulate; but once the axioms are chosen, the theorems describing triangles on surfaces with positive or negative curvature are ‘discovered’ and do not depend on arbitrariness. The notion of computability has been introduced with different definitions (Turing machines, recursive functions, lambda calculus), but they all converge on the same class of computable functions: this convergence is an indication that the concept understood is not a pure artefact, but rather a stable aspect of the notion of effective computation. The arithmetic of natural numbers is often seen as particularly realistic: in second-order logic, Peano axioms characterize natural numbers “up to isomorphism”, i.e. they describe an essentially unique structure; in first-order logic, however, non-standard models appear, reminding us that the result also depends on the logical framework adopted.
The question remains as to why mathematics works so well in science. A non-mystical answer is that the physical world has relational structures that can be homomorphically represented by mathematical structures. We do not “discover” mathematics by looking at nature, nor do we “invent” it at random: we select, from among many possible theories, those that capture observable regularities with the maximum ratio of predictive power to simplicity. When the choice is successful, mathematics is applicable because there is a structural correspondence between the model and the phenomenon. Here, too, the invention lies in proposing the model; the discovery lies in drawing the necessary conclusions that are then empirically verified.
This perspective also explains the authority of rigor without falling into metaphysical dogmatism. Rigor is the discipline of the second step: once the framework has been invented, it is proven. Mathematical creativity, on the other hand, lives in the first step: defining concepts, conjecturing axioms, changing points of view. The objectivity of the conclusions doesn't deny the historicity of the premises; the historicity of the premises doesn't diminish the necessity of the conclusions. In central and stable cases (elementary arithmetic, real analysis), the various approaches converge, and the sense of “discovery” is strong; at the exploratory margins (foundations, advanced set theory), the weight of inventive choices and pluralism grows.
Let me know.
I am, and many mathematicians are, too, a Platonist. It is discovered. I even go as far as thinking that great compositions or paintings are discovered, or better: uncovered. However, it is sometimes hard to maintain this point of view when I see which constructions mathematicians "find" to prove theorems.
My favorite example is a circle. There is no such thing as a circle in real life. Nevertheless, we all know what is meant and can well calculate with it. Mankind may have invented the wheel, but not the circle. In the end, this is a purely philosophical question.
Why do we assume that one of the concepts of invention and discovery must apply to mathematics? Perhaps it's neither. Perhaps mathematics has its own category: either incovered or disvented.
  • Haha
jnhrtmn said:
physics degree is 100% math
I disagree. You can do physics without mathematics, I don't mean University physics, research level but you can investigate it like Faraday did say.
You can split light using a prism, see a straight stick bend in water, draw the position of the stars, sun and moon, perhaps make a stone circle to map them? See what happens to a photographic plate when exposed to certain rocks. Some qualitative things.
Mathematics describes physics very well but I would not describe physics that way.
I am not a mathematician so I am curious as to what mathematics is and what people who study it think it is.
Fresh42 once said, "Mathematics is philosophy," that surprised me.
To say that now in the 2020s, surprised me.
I don't think I necessarily disagree, but with that it is a bit strange that when something in the natural world is combined in a new interesting way we call it invention implying it has arise from human inspiration, but when human inspiration define some new mathematical object (i.e. a set of consistent rules) that doesn't really can be found in nature, then it is discovered.
Everyone know how extremely powerful math is for modelling the natural world, so if we go with math being uncovered then it must imply that math already exists as a part of the natural world, hence when a new mathematical structure is uncovered it seems it will be a new interesting combination of something already existing in the natural world, hence it is also an invention. Or what?
I'd say that math is formal description of relationships. The natural world is full of relationships. So it's not surprising that math is useful in describing the natural world.
What was the context? I would say that mathematics is definitely not philosophy (in fact I may go far enough to say that it is the oposite of it).
Sorry I cant remember that. It could have been a similar "what is mathematics?" type thread but it may have been edging towards philosophy which is not allowed. If Fresh was a mentor then he may have closed it.
Guessing he was referring to the logic, analysis side? A lot of those prominent philosophers overlapped with Mathematics.
Guessing though.
What mankind invented was the axle.
As fresh points out, there are plenty of circles in the natural world - and even things that roll. But nature never invented the wheel because it is predicated on the axle. Nature can't have two independent parts rotating in relation to one another in that sense because it never found a way to pass nutrients between them*.
* except one tiny case, which is left up to the reader to divine
Whether mathematics was invented or discovered is itself a philosophical question.
My latest contribution to the homework forum is the idea of using a simple recurrence relation to calculate a probability, instead of summing an infinite geometric series. The sense in which that idea was invented or discovered can be argued ad infinitum.
And most discussions about it happen because people use "invented" and "discovered" with slightly different meanings.
The magic of math is that we can use it to make predictions in many fields.
When you say math hides what's going on in physics, it's true, but not for the reason you think.
Math is used to model what we see, what we measure. There is nothing that says math describes the physical process. This is the reason we test everything. Whenever we find something that the math predicts wrong, we reevaluate our test hardware, our measurements, and finally our theory.
NOVA had an episode The Great Math Mystery that can explain it better:
https://www.pbs.org/wgbh/nova/video/the-great-math-mystery/
It's also available on YouTube.
  • Agree
My example to the "is mathematics invented or discovered?" question is the monster group. This is the largest simple group, with 8x10^53 elements. So if you think mathematics is invented, you would have to agree that when Galois first wrote down the definition of a group, that at that instant the monster group sprang into existence from nothing. To me this is obvious nonsense, and I think it must be that the structure of the monster group existed before there were mathematicians, and we discovered it by studying mathematics.
  • Skeptical
I thought you were going to say that the monster group shows that mathematics is invented!
You could say the same about the wheel. The concept of the wheel "must" have existed before any human thought of it. In fact, the concept of the world of ideals is central to Aristotle's philosophy.
DaveC426913 said:
Why" questions are for philosophy. Science is silent on why things happen; it is about what and how.
Not so for the biological sciences, where understanding the "whys" leads to a better understanding of the organisms involved.
Why does the heart act as a pump? So it can push blood around the body to move nutrients, wastes and dissolved gasses for exchange. This keeps the body alive so it can reproduce and make more of these complex systems (organisms). These are among the most basic design issues of biology. Designed by the processes of natural selection. Selected from among heritable variants over many generations. Systems with a purpose of survival and reproductive built into their chemical operating system, will be more likely to fulfill the survival and reproductive requirements of successful systems (to live long and prosper) built into them, from the ground (when systems first formed) up.
This is a result each living thing (as a unit) acting independently as individuals. Each unit with their unique set of system (cellular-molbiol level) traits and each being independently tested by selection. Trait variants could have a different survival likelihood. Those selected (by producing more systems in the next generation) will become incrementally better at surviving and reproducing each generation as new variants are sampled.
This self-directed behavior is what sets biological entities apart from the things usually thought of as of chemistry and physics.
Biological entities each have internal processes reacting to their sensed environment, that direct their behavior. Variants in these internal processes provide fodder for natural selection to choose among. Those that win (succeed) will probably have built in goals and processes to work toward. Its a path to a winning situation.
This is among the reasons biology is a complex messy field. The number of possible outcomes would get very big, very quickly, when considering the variation of the internal processing capabilities built on the previous generation's complexity. Things are not going to be easily predicted due to the complex variation.
Couldn't that be said about any mathematical object or operation? Say, 1+1=2? Or pi?
Why pick on the monster group of all things?
And what did the monster group look like before Galois identified it? Not to be glib but can, say, monkeys see it?
These things are abstract concepts. Certainly the 'group' part of it is, since it takes abstact reasoning to decide what is in a group and what is not. That did not happen before a mind became along to form the thought.
For example, among other things: "It acts as the symmetry group for complex geometric objects in high-dimensional spaces, such as a 196,883-dimensional space."
Are you suggesting that 196,883-dimensional space exists objectively in the world? And did so before human minds came along?
Like most things it becomes a semantic argument - what does invented or discovered mean?
Maybe the guy who invented tic tac toe was too dim to understand that proper play would always result in a draw and he later 'discovered' this aspect of his invention but to anyone here it would be obvious
Or a planet of alien morons whose greatest geniuses struggle with the commutativity of addition
is it then a matter of degree to say that the proof of Fermat's last theorem would have been just a trivial implication of the concept of a right triangle if it had been invented by some entity smarter than us?
Thread is locked temporarily pending Moderation of recent posts (some now hidden)...
I chose the monster group because to me it is obvious that nobody could have invented that structure.
Yes!! I think that must be the case. That structure is part of the structure of our universe. Note that not just any random dimensionality leads to a simple group like the monster group. Only certain ones do. How else would you explain it?
jedishrfu said:
Why not pick simpler examples like ##\pi## or e?
These constants have interesting properties and appear in unexpected places.
I agree. It's clear that those constants were discovered, not invented, but I'm not sure everyone would agree. I chose the monster group because to me it is simply absurd to say it was invented.
The counter argument is that group theory was "invented". And that, although symmetries appear in nature, the concept of mathematically rigorous group theory was invented. And, that the axioms of group theory led to objects that cannot exist in the physical universe, only as abstract mathematical objects. This could also apply to magnetic monopoles, tachyons and any other mathematical physics (e.g. alternative particle and field theories) that are not part of this universe.
To say that magnetic monopoles were "discovered", when they do not exist, could be seen as absurd.
Wouldn't it be correct to say that theorems are discovered, concepts and proofs are invented?
  • Haha
@Hill I think that’s very insightful. It’s like we create/invent a game with rules on how to play it and then we discover strategies on how to win it.
Yes, it is.
I'm not sure I agree that group theory was invented. The axioms of group theory were chosen the way they are because it leads to relationships between transformations that describe objects in our universe. In this sense I would argue that Galois saw that those axioms led to particularly useful and interesting structures. If it were purely invented, then you could choose any random set of axioms for your theory.
