Is Mercator's projection conformal with equal scaling coefficients?
  • Level: High School
  • Thread starter Thread starter jk22
    Projection
1 reply · 2K views
jk22
I read the Wikipedia article : https://en.m.wikipedia.org/wiki/Mercator_projection
Section : Mathematics of the Mercator projection.
For a map to be conformal should not it be $$k(\phi)=C,h(\phi)=C$$, or the shrinking coefficient shall be not only equal but homogeneous, in order to be conformal ? We then get two partial differential equations and their solution is Simply obtained by integrating a constant towards the variable of integration :
$$x(\lambda,\phi)=Ccos(\phi)\lambda$$
$$y(\lambda,\phi)=C\phi$$
Does this anyhow makes sense ?
To be conformal, it is sufficient that the local latitude scale match the local longitude scale.
Here is the legend (as I understand it) for you equations:
x,y: The map coordinates.
ϕ: Latitude
λ: Longitude I am not clear on your k and h - perhaps they indicate x,y scale. If they do, then you are glazing over the fact that there are many C's. I would say you have a ##C_\phi##, not a C.
For Mercator, x (the horizontal, longitude direction) will always be proportional to the Longitude.
So x(λ,ϕ)=R ϕ
That leaves y to be a function that always has a scale (differential) equal to the x scale.
The full derivation is in the wiki article you cited:
{\displaystyle x=R(\lambda -\lambda _{0}),\qquad y=R\ln \left[\tan \left({\frac {\pi }{4}}+{\frac {\varphi }{2}}\right)\right].}
