Is My Algebraic Simplification Correct?
17 replies · 12K views
tigerd12
Hello, I just found a question, and having attempted it many times I get different answers, probably due to my messy working, however I have just tried it twice again and got the same answer, just checking with you guys to see if you think it is correct.
Thanks!
Simplify fully
2/(x-1)+(x-11)/(x^2+3x-4)
My answer is 1/(x+4)
Hope it's right!
Cheers.
Is this the fraction [tex]\frac{2}{x-1} + \frac{x-11}{x^2+3x-4}[/tex]? If so, you have missed a factor of 3.
Post
Hmm?
What do you mean?
yes the question is as you stated
I started out solving the question by getting lowest common denominator.. i.e
(x-1)(x+4)+(x-1) was my bottom line.. and then i carried on.. so which factor did I miss?
What did you do after that?
Working
Ok here is the working..
2(x-1)(x+4)+(x-1)(x-11)/(x-1)(x+4)+(x-1)
Simplifies into..
2x^2+6x-8+x^2-11x-x+11/(x-1)(x+4)(x-1)
which then is
3x^2-6x+3/(x-1)(x+4)(x-1)
which then is
x^2-2x+1/(x-1)(x+4)(x-1)
which then turns out to be
(x-1)(x-1)/(x-1)(x+4)(x-1) = 1/(x+4)
I think..
Hmm...I'm not sure how you arrived at that, but
[tex]\frac{2}{x-1} + \frac{x-11}{x^2+3x-4}[/tex] = [tex]\frac{2(x+4) +(x-11)}{(x-1)(x+4)}[/tex]
Think of it as multiplying the numerator and denominator of the first term by (x+4) and simplifying.
ahhhhh i get you, i understand, didnt spot that (x-1) was also factor or the other quadratic.. but 1 thing..
the way I got to my answer is taking the LCM by multiplying the two bottom terms, then working from there.. theoretically it should have come out right, i can't see why it didn't
The LCM of (x-1) and (x-1)(x+4) is (x-1)(x+4). Therefore the denominator becomes (x-1)(x+4), and you multiply the 2 by (x+4) and the (x-11) by 1.
yeah I get that, but couldn't (x-1)(x-1)(x+4) be used too as its still a multiple of both
We're talking about least common multiple.
I thought when adding fractions you just needed a common multiple, not the lowest? or am I wrong?
You said you took the LCM. What do you think LCM stands for? :wink:
Here's a numerical example: (1/2) + (1/4) = 0.50 + 0.25 = 0.75
The least common multiple of 2 and 4 is 4, since 2x2 = 4x1 = 4.
(1/2) + (1/4) = ((1x2) + (1x1))/4 = 3/4 = 0.75
Yeah, I thought I took what I thought was the LCM, I was wrong, but what I'm asking is that shouldn't it have worked as the denominator I gave was still a multiple of both
Ah. What you essentially did was multiply the numerator and denominator by (x-1). So the answer should be the same as the correct one.
But from going from 3x^2-6x+3/(x-1)(x+4)(x-1) to x^2-2x+1/(x-1)(x+4)(x-1), you forgot the factor of three in the numerator, just as I said in my first post. :biggrin:
But doesn't 3x^2-6x+3 = x^2-2x+1? As I took out the factor of 3?
But where does the 3 go?
What you're saying is the same as stating 3 = 1. Does that make sense?
3x^2-6x+3 is equal to thrice x^2-2x+1.
Since 3 is common to all terms, I can write it as 3(x^2-2x+1). Multiply each term within the brackets by 3 and you'll get back to old expression.
hmm ok.. kinda weird, since i thought dividing everything by three should keep it the same
