Is My Weight Causing My Bike's Rear Wheel Issues?
  • Thread starter Thread starter pivoxa15
The discussion centers on the impact of rider weight, specifically between 100kg-110kg, on the performance and integrity of a new road bike's rear wheel. A mechanic advised that the weight, combined with the presence of two D locks, contributed to the need for re-truing the wheel after three weeks of riding. Suggestions included removing one D lock to reduce weight on the bike frame, although this would not alleviate downward force exerted while riding. The conversation highlights the necessity for stronger rims and tires to maintain wheel integrity under heavier loads.
  • Understanding of bicycle wheel mechanics and tension
  • Knowledge of weight distribution effects on bike performance
  • Familiarity with bicycle components such as rims and tires
  • Experience with bike maintenance, specifically wheel truing
  • Research bicycle wheel truing techniques and tools
  • Learn about the specifications and benefits of stronger rims and tires
  • Explore weight distribution strategies for road bikes
  • Investigate proper bike fitting services and their importance
Cyclists, bike mechanics, and anyone interested in optimizing bike performance and maintenance, particularly those concerned with weight impacts on bicycle integrity.
pivoxa15
My rear wheel's overall tension droped and needed retruing after 3 weeks of riding. The mechanic claimed that it was because I was too heavy plus the fact that I have two D locks installed on the bike.
First of all is it true that 100kg-110kg weight on a low range new road bike is too much?
The mechanic then suggested i take one D lock off the bike and put it in my backpack instead. That would mean less wieght on the frame but I would have to carry it so I would be exerting more force downwards so no net decrease in tension in the wheel. Correct?
Have you read the replies given in your other threads? Answers await.
If you went to a shop in the first place like Chroot and others had suggested to get a proper fit, they probably would have warned you about such things. Looks like you are going to need to get stronger rims and tires. They will be heavier but at least they will have a better chance of staying true until you can switch back to the other ones.
And yes obviously mounting the D-lock on the bike and carrying it in a backpack is probably not a solution to the problem. Seeing as it would be shifting even more weight to the back of the bike(I guess assuming how you ride, but either way the effect would not be enough to solve anything..) and putting more stress on the rear tire which you are having problems with...
ps: 2 D-locks? Thats a lot of weight.
I forgot. Was this a new bike? or a new wheel? Because all new wheels go out of true in the first 100 miles. No matter how they are built, there is some stretch in the spokes, and some maleability in the spoke holes in the hubs. After re-truing, the wheels usually stay in good shape for years.
I don't think that any shop mechanic would not know that though.
  • · Replies 21 ·
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 44 ·
