Is poincare group simply connected?
  • Context: Graduate
  • Thread starter Thread starter andrea.dapor
    Group Poincare
The Poincaré group is not simply connected, as established by Wald in "General Relativity" (1984). The discussion centers on the function F(s, t) = sI + (1 - s)C(t), where C(t) represents a closed curve associated with a rotation of 2π about the z-axis. The error identified is that F does not maintain continuity within the Poincaré group for all s in [0, 1], as it fails to satisfy the group properties required for transformations. The conclusion emphasizes that the function must be constructed using matrix products of Poincaré transformations, not linear combinations.
  • Understanding of group theory, specifically the properties of Lie groups.
  • Familiarity with the Poincaré group and its role in physics.
  • Knowledge of continuous functions and their applications in topology.
  • Basic understanding of Lorentz transformations and their determinants.
  • Study the properties of Lie groups and their applications in theoretical physics.
  • Learn about the topology of groups, focusing on concepts like simply connected spaces.
  • Explore the implications of the Poincaré group in quantum field theory and special relativity.
  • Investigate the construction of continuous functions within the context of group transformations.
The discussion is beneficial for theoretical physicists, mathematicians studying group theory, and students interested in the foundational aspects of quantum field theory and special relativity.
andrea.dapor
(I posted this in Particle Physics too)
We call a group G "simply connected" if every curve C(t) in G which is closed (that is, C(0) = C(1) = I) can be continuously deformed into the trivial curve C'(t) = I (where I is the unit element in G). This is formalised saying that, for each closed C(t), there exists a continuous function F: [0, 1]x[0, 1] -> G such that
1) F(0, t) = C(t), for all t
2) F(1, t) = I, for all t
3) F(s, 0) = F(s, 1) = I, for all s
Now, Wald (General Relativity, 1984) says that the Poincare group is not simply connected, beacuse in particular for a rotation of LaTeX Code: 2\\pi about an axis - say z - such a function F does not exist.
My question follows.
Consider the function
F(s, t) := sI + (1 - s)C(t),
where C(t) is the closed curve in Poincare group G associated to a rotation of LaTeX Code: 2\\pi about z, that is,
C(t) =
(1 0 0 0)
(0 cos2\pi t -sin2\pi t 0)
(0 sin2\pi t cos2\pi t 0)
(0 0 0 1)
with t in [0, 1].
This F seems to verify (1)-(3)... where is my mistake?
I thank you for your help, and apologize for the "matrix" above...
It seems like your formula for F could be used to prove that *any* closed curve can meet the requirements; you've set it up so that all three conditions are automatically satisfied if C(0) = C(1) = I. Since there are certainly groups which are not simply connected, you must be leaving something out. I suspect what you're leaving out is that F, for the C(t) you've given, is not continuous.
Is t\mapsto F(s,t) a curve in the Poincaré group for every s in [0,1]?
Think about a closed curve around a torus for example. If your "deformed curve" isn't required to be a curve in the torus, then you can obviously shrink it to a point by cutting through the torus. This only indicates that \mathbb R^3 is simply connected, not that a torus is.
I recommend that you don't post in two places, and that you use tex or itex tags for the Latex next time.
Ok, problem solved (in Particle Physics): I idiotically thought that if I and C(t) were in G, then also a linear combination such as sI + (1 - s)C(t) would be in G. This is false, since we are talking of a GROUP, not of a linear space! In fact, even sI is not in G (if s is not 1), since its determinant is not 1 (and hence it is not a Lorentz transformation)! The function F must be constructed using only matrix product between poincare transformations - i.e., using the group-product of G.
Sorry for my stupidity, and thanks anyway.
About the post, i put it in both the places since it concerned both the subjects, Special Relativity and Quantum Field Theory (the fact that poincare group isn't simply connected justifies the introduction of spinors).
About Latex, i tried to use it, but "advanced tools" such as "\begin{array}" (for matrices) were not accepted...
You probably just forgot the annoying "cc" syntax:
\left(\begin{array}{cc}a & b\\ c & d\\ e & f\end{array}\right)
I prefer \begin{pmatrix} for matrices.
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 50 ·
