- 19,378
- 15,612
All of this is incorrect. You are confusing time dilation with differential aging due to different paths through spacetime. Yes, if you synchronize two clocks and then move them apart, either having one go deeper into a gravity well or move at a high speed, and then you bring them back together, they will show different times. This is NOT "time slowing down" (or speeding up), it is differential aging. EVERYTHING see time move at one second per second, regardless of where it is in a gravity well or how fast it is moving relative to something else.Noah332 said:thats Einsteins invention. its called time dilation. In order for the speed of light to remain constant in all inertial frames of reference then time has to be able to slow down. as well as space needs to expand. hence the idea of spacetime and it curving.
"Gravitational time dilation is a form of time dilation, an actual difference of elapsed time between two events as measured by observers situated at varying distances from a gravitating mass. The higher the gravitational potential (the farther the clock is from the source of gravitation), the faster timepasses. "
https://en.wikipedia.org/wiki/Gravitational_time_dilation
when you are near a black hole's event horizon the closer you get the slower time gets.
This is part of GR.
Your misconception about time changing rates is a very common one, but that doesn't make it right. Again, I suggest you study the actual physics.
