- 22,170
- 3,335
What do we mean with "metric" here? A distance function that generates a metric space? Or a metric tensor?
friend said:What would quantized geometry/gravity do to the topology of spacetime? Does QG destroy topology?
tom.stoer said:The question is whether we can answer the question "what it means that geometry is fundamentally discrete".
Suppose CDT is the correct description; it's a rather simple model using (discrete) triangulations of spacetime. Of course we can change the scale and look at spacetime at different resolutions, we can probe the triangulations, gravity and other interactions at different scales; we can calculate physical observables at different scales.
Now the following could happen: when changing scale and zooming to finer triangulations = to higher resolutions the physical answers we get become scale independent. That means that finer and finer triangulations do not have any effect on physical observables (below some "fundamental length").
So we make two observations
1) the theory allows for arbitrary small triangulations, i.e. it has a continuum limit
2) below some length scale physics doesn't change
1) means that the theory is not fundamentally discrete
2) means that it behaves as if it were fundamentally discrete
My description says that the model uses a discrete spacetime with length scale L, wherefriend said:I don't see how your description differs from a numerical computer method for solving a differential equation. Do numerical methods have anything to do with the underlying topology on which differential equations are formed?
tom.stoer said:My description says that the model uses a discrete spacetime with length scale L, where
1) a continuum limit L→0 is possible, but where
2) a length scale Lmin>0 exists below which no physical process can probe any smaller length scale L<Lmin
My question to you is whether this means that spacetime is continuous b/c of (1) or whether it is discrete b/c of (2)
Natron said:i don't mean to be extremely simple here, but if Planck's constant is considered to discretely divide spacetime, then wouldn't there be a conundrum with gravitational forces over extreme distances? the obscure thing that comes to mind is imagine a complete vacuum of a universe that has 2 grains of sand (classical physical objects) but are placed 15 trillion light years apart, if spacetime is a continuum then these objects will affect each other, if spacetime is discrete, then either one of 2 things would happen, their gravitational forces against each other will be zero, or will be some sort of minimal constant that maintains regardless of the distance they are from each other.
friend said:When you think of Hausdorff, you can think of "house" dorff. This is the property where each point in the topology can be enclosed in a neighborhood that does not include any other point you may choose. Even if you choose points very close together, you can always construct even smaller neighborhoods that exclude the other point you chose. No matter how close you choose the points, they each have their own little house to dwell in.
But if the metric is quantized and with it areas, then you cannot always construct a neighborhood that excludes a close point. The property of Hausdorff could not apply to such a space, and it would not be a manifold. Then since GR is constructed on manifolds, GR would not be applicable, right?
friend said:This all begs the question as to whether neighborhoods in topology are necessarily defined in terms of a metric.
I mean the ususal description I've seen in textbooks is that neighborhoods are "balls" of radius r, and r is allowed to be any size.
Can you define neighborhoods in topology without reference to a metric?
Thank you, micromass. I think I will buy the paper back version of the book. But in the mean time, maybe you could give us a very brief definition of neighborhoods without use of the metric. For me it seems inescapable not to talk about some sort of size associated with neighborhoods, especially when considering concepts of continuity, where the neighborhood is allowed to strink in size to near zero, whatever that means without a metric.micromass said:They aren't. Please see a basic topology book such as Munkres.
There's a theorem about open sets in metric spaces that you may be familiar with. It says that if X is a metric space, the following statements are true:friend said:maybe you could give us a very brief definition of neighborhoods without use of the metric.
Topology doesn't care about size e.g. in topology one can show that the unit open ball ##B^{n}\subseteq \mathbb{R}^{n}## is homeomorphic to all of ##\mathbb{R}^{n}##. That's the whole point of point-set topology: it removes the structure associated with metric spaces that gives us a notion of distance and size in the primitive geometric sense and instead just deals with neighborhoods in a more abstract sense. Also note that the metrics being spoken of in the context of space-times are pseudo-Riemannian metrics endowed on smooth manifolds, not metrics in the analysis sense. The two are completely different animals.friend said:As I recall, and it's been a while, a metric is an added structure to a topology. But once you define a metric on a topological space, it becomes impossible to talk about the size of neighborhoods of points without automatically saying something about their size in terms of the metric. So that if the metric were quantized, then so must be the neighborhoods, and one wonders what happens to the Hausdorff property of any manifold defined on that topology.
As I tried to explain quantization (of the metric) does not necessarily lead to discretization (of the space, metric, ...); there are proposals with quantized but continuous gravitational field (in QM both x and p are quantized, i.e. they are operators, but nevertheless x is always continuous and p is only discrete for some eigenvalue problems; nevertheless the Hilberts space is a space of functions u(p) where p is a continuous variable); so again: quantizing the metric does not necessarily imply discretization.friend said:... if the metric were quantized, then so must be the neighborhoods, and one wonders what happens to the Hausdorff property of any manifold defined on that topology.
WannabeNewton said:Topology doesn't care about size e.g. in topology one can show that the unit open ball ##B^{n}\subseteq \mathbb{R}^{n}## is homeomorphic to all of ##\mathbb{R}^{n}##. That's the whole point of point-set topology: it removes the structure associated with metric spaces that gives us a notion of distance and size in the primitive geometric sense and instead just deals with neighborhoods in a more abstract sense. Also note that the metrics being spoken of in the context of space-times are pseudo-Riemannian metrics endowed on smooth manifolds, not metrics in the analysis sense. The two are completely different animals.
A topological space X is called locally Euclidean if there is a non-negative integer n such that every point in X has a neighborhood which is homeomorphic to the Euclidean space En (or, equivalently, to the real n-space Rn, or to some connected open subset of either of two).[1]
A topological manifold is a locally Euclidean Hausdorff space.
in topology one can show that the unit open ball Bn ⊆Rn is homeomorphic to all of R
tom.stoer said:As I tried to explain quantization (of the metric) does not necessarily lead to discretization (of the space, metric, ...); there are proposals with quantized but continuous gravitational field...
tom.stoer said:... (in QM both x and p are quantized, i.e. they are operators, but nevertheless x is always continuous and p is only discrete for some eigenvalue problems; nevertheless the Hilberts space is a space of functions u(p) where p is a continuous variable); so again: quantizing the metric does not necessarily imply discretization.
tom.stoer said:But if there is discretization (either as a result of the quantization procedure or as a starting point put in by hand) then the usual topological properties will not survive. So what? Of course we expect that "quantum geometry" is different from classical one. Where's the problem?
The Hawking at al. approach does not assume any discreteness; asymptotic safety approaches use a continuous metric; string theory and supergravity theories do use continuous fields for spacetimefriend said:I'm not aware of any metric quantization procedures that don't assume a result of a discrete spectrum. Maybe you could share some of these efforts with us.
Manifolds do not rely on any kind of metric. A smooth manifold is just a topological manifold with a smooth atlas; a topological manifold is a special kind of topological space. The locally euclidean property does not require a metric in any way; note that the property involves a homeomorphism which is an isomorphism in the category of topological spaces. Isomorphisms in the category of metric spaces are called isometries and these of course require a metric. It isn't your fault but you are confusing metrics from analysis with metrics from Riemannian geometry. The two are different. I don't blame you though because physicists tend to use the word metric when they really mean Riemannian metric. It's a horrible abuse of terminology but its rather ubiquitous. You must realize that the metrics from real analysis are in no way a priori related to Riemannian metrics. It is true that the topology of Euclidean space is usually defined as the one generated by the base of open balls of the Euclidean metric (the one induced by the 2-norm) but with regards to the locally Euclidean property we only care about the fact that topological manifolds are locally homeomorphic to Euclidean space i.e. we only want to check whether the topological space is locally topologically equivalent to Euclidean space. In this sense the metric space structure of Euclidean space is irrelevant to the locally Euclidean property, only its topological structure is of relevance.friend said:OK, so now we have two metrics to worry about and whether they are in any way connected to the size of neighborhoods. As I understand it, GR relies on the existence of an underlying manifold, and manifolds seem to rely on a continuous Euclidean metric, per wikipedia.org, which says,
A Euclidean space is a space with a Euclidean metric. And this Euclidean metric is continuous as indicated by the word "local". But it is not the pseudo-Riemannian metric of GR, since a pseudo-riemannian metric is not the Euclidean metric. All very confusing. What is the locally Euclidean metric on the manifolds associated with GR if not the pseudo-riemannian metric?
WannabeNewton said:Manifolds do not rely on any kind of metric.
You are still confusing quantization and discreteness.friend said:If you have a metric on your manifold, then how can you have a quantized metric and a smooth point-set topology.
tom.stoer said:You are still confusing quantization and discreteness.
friend said:What I don't understand is how you can have a discrete metric on a smooth manifold.
TrickyDicky said:To understand this you just need to read any differential geometry text as adviced before.
TrickyDicky said:But the important thing here is that such mathematical structure is not demanded in the standard current physical theories either quantized or not quantized , as Tom has said several times quantization doesn't imply a discrete topology.
WannabeNewton said:Correct me if I'm wrong but the thing being quantized is the space-time metric (in the sense that it is promoted to an operator field and quantized in the QFT sense) and not metrics in the analysis sense; a topological manifold can always be given some metric in the analysis sense but the proof of this is rather complicated-the proof for compact manifolds is simple if one uses Urysohn's lemma. Regardless, the existence theorem doesn't tell us explicitly with the metric actually is. There is no such thing as a "continuous" topology (note that discrete topology has a very strict definition: it is the finest topology that can be endowed on any set i.e. the power set of the original set).
