Is spacetime a vector space under Galilean relativity?
146 replies · 19K views
robphy said:
The eigenvectors of the boost should primarily be about maximum signal speeds.
So, if I were to redo that poster,
I would say "absolute maximum signal speed is infinite" instead of "absolute time"
for the ##(0,1)^\top## eigenvector of the Galilean boost.
And the eigenvectors represent limiting the possible 4-velocities (future-timelike directions)
in the Galilean case, as the lightlike eigenvectors in (1+1)-Minkowski spacetime.
(Note that the ##(0,1)^\top## eigenvector of the Galilean boost is also a null vector with respect to the temporal-Galilean metric. Together with the discussion below about absolute time,
this means that ##(0,1)^\top## is both null and spacelike in Galilean geometry,
as a result of "opening up the light cones" from the Minkowski case).The notion of "absolute time" is really about
different frames of reference agreeing on what sets of events are simultaneous.
Further thoughts on the same subject, in the line of relating the Galilean eigenvector to an infinite speed.
You cannot define it as a speed, just like you don't define it as the speed of light in SR. It must be a displacement vector composed of x and t intervals. If it travels instantaneously, it means that, despite employing t = 0, its x is everywhere. Would it then make sense to define it, not as ##(0,1)^\top##, assuming that x = 1, but as ##(0,x)^\top##, assuming that x is everywhere? (note that in fact, in the derivation of the eigenvalue, x was the X coordinate of "a certain vector"; we can assume that it was a unitary vector, but that is an assumption; understanding now what it means, I would leave the x).
Also, it is to be noted that in SR the eigenvectors are the lightlike vectors going in each direction, X and -X. Here, instead, we have only one Galilean eigenvector. This may imply that its expression is telling you precisely this: "don't see me as a vector that is somewhere, looking either left or right, but as one that is everywhere at the same time".
In conclusion, this is what I would understand from your development, in terms of eigenvectors / eigenvalues:
eigenvectors:
- just like Minkowskian observers have a finite speed instrument with which they fix lengths and synch clocks (actually 2 instruments, one going in each direction), Galilean observers have also an infinite speed instrument for the same purposes;
- in agreement with its nature of eigenvectors, these instruments remain on their respective lines despite boosts and this requires that they keep the same correlation between x and t, i.e. the same speed, either a finite or infinite one, as the case may be: in the Minkowskian case this has the simple reading of the same correlation between t and x, in the Galilean case what remains invariant is the statement "I am a vector that in no time can reach everyhwere";
eigenvalues: in the Galilean case, the eigenvalue = 1 entails that the scale is maintained and objects keep their lengths and clocks keep their time rates and remain synched, whereas in the Minkowskian case we only manage to keep the invariance of the speed of light at the cost of a dilation and a change of scale, the change of scale being given by Doppler-Bondi factor and being reciprocal, so that each frame sees the other as "out of scale" (and hence length-contracted, time-dilated and de-synched).
Would you agree to this para-phrasing of your points?
I am quite happy with it, as it accommodates the idea of speed as a quality of the eigenvector and the idea of scale (affecting both length and time) as a quality of the eigenvalue.
[ snip]
I think you have mostly got it.
However, these passages sound contradictory (word-coloring by me)
... [snip] ...
eigenvectors:
- just like Minkowskian observers have a finite speed instrument with which they fix lengths and synch clocks (actually 2 instruments, one going in each direction), Galilean observers have also an infinite speed instrument...
I would describe an eigenvector of the (1+1)-Lorentz-boost
as having a velocity-magnitude of "the speed of light".
This speed is not attainable by any future-timelike vector,
although a sequence of repeatedly-boosting a future-timelike vector tends to it.
This is in analogy to what I said in #47,
where an eigenvector of the (1+1)-Galilean boost
is not attainable by any future Galilean-timelike vector,
although the sequence of repeatedly-boosting a future Galilean-timelike vector tends to it.
I describe that as an infinite speed (although I don't want to get into discussions about infinity).
At this point, I'm more concerned with what the mathematical structure implies
in terms of describing the physics and less concerned about what the structure is called.
(Since I recently re-watched on YouTube Feynman's The Pleasure of Finding Things Out....
this made me think about the passage about "knowing the name of something".)
By the way, one could describe the finite speed of light eigenvector in the (1+1)-Lorentz boost
by an infinite rapidity, not attainable by a timelike vector, but it is an upper bound.
The Galilean rapidity associated with its eigenvector, not attainable by a Galilean-timelike vector,
is also infinite.
In terms of coordinates, in light-cone ##(u,v)## coordinates,
where frontward-future eigenvector is ##(1,0)## with finite speed,
nonzero timelike-vectors can't have one of these coordinates as zero.
Similarly, in ##(t,x)## coordinates, where the eigenvector is ##(0,1)## with my "inifinte" speed,
nonzero Galilean-timelike-vectors can't have the t-coordinate as zero.
In the business of extending an idea by a specific set of analogies,
we sometimes have to loosen the traditional definition of a word.
At this stage,
I am happy calling the Galilean-eigenvector ##(0,1)^\top## an "infinite" speed
because I can and have used the mathematical construction to make progress toward
formalizing the analogies and connecting them to the physics.
There may be a better term.
But in my current intuition, I think of velocity as a slope.
On occasion, in Euclidean geometry, I may have a vertical segment,
where one has a similar issue with the "slope" of a vertical segment.
How one handles this situation could be how we should handle the description of ##(0,1)^\top##.
Saw said:
Would it then make sense to define it, not as ##(0,1)^⊤##, assuming that x = 1, but as ##(0,x)^⊤##, assuming that x is everywhere?
An eigenvector is really a direction, a slope (if I am permitted an extension on the term).
When ##(0,1)^⊤## is an eigenvector ##(0,17)^⊤## is also an eigenvector. And, of course,
they have the same eigenvalue.
The discussion of the eigenvector-eigenvalue table and its interpretation from my poster
has been useful. It helps me address issues that may be unclear, which would help
when I present these ideas in a talk, a poster, or a paper.
...but the "eigenvectors and eigenvalues" concept is only the tip of the iceberg
of the Galilean spacetime (which was introduced by the eigenchris video you linked in the OP).
What is more interesting and more useful is
how well it can describe Galilean physics
(as a stepping stone as to how well Minkowski-spacetime geometry
can describe [Special Relativistic-]Spacetime physics).
vanhees71 said:
Galilei-Newton and Einstein-Minkowski spacetime have in common the special principle of relativity, i.e., the existence and equivalence of all "inertial frames of reference" together with the Euclidicity of space for all inertial observers. From a physical point of view in Newtonian physics (i.e., classical non-relativistic mechanics) the paradigm are point particles and actions at a distance, such that one can establish the existence of rigid bodies, which enable global clock synchronizing by using rigid rods, which have an infinite sound velocity, i.e., you can synchronize all clocks with instantaneously propagating signals, and thus you can even synchronize all clocks, no matter in which however accelerated motion they are, which ensures that you have an absolute time, (...)
In SR there are no rigid rods and no faster-than-light signal propagation that can be used to synchronize all clocks in arbitrary motion relative to any inertial frame, (...). Clock synchronization in arbitrary (inertial or non-inertial) is a matter of definition or convention, and the most simple one for inertial frames is the use of light signals and light clocks as, e.g., in Einstein's famous paper of 1905. Mathematically this is the choice of pseudo-Cartesian (Lorentzian) basis vectors in Minkowski spacetime, i.e., the possibility to choose a global constant tetrad fieldm which establishes the SR spacetime manifold to be a 4D pseudo-Euclidean affine space with a fundamental form with signature (1,3) or equivalently (3,1), i.e., a 4D Lorentzian affine manifold.
I am not qualified to comment on the rest of your post, but I am happy to see that we are all non the same page in the description of this point (well, that I landed over that page, you were both already there...!): if I am not mistaken in my previous post, the Galilean eigenvector would be this rigid rod that you mention, which can sustain infinite sound velocity and serve for synching clocks and fixing lengths and which, under a boost, would keep its spacetime direction (i.e. its speed would remain infinite) and would be multiplied by an eigenvalue = 1, thus preserving the scale (measurements of time and length remain invariant).
Surely it is and we have to come back to the issue of time as a vector vs a scalar, but please let me say a couple of things more on the eigenvector subject, because this is a little like the foundation of the building.
That is enlightening. You are telling me that one must not read an eigenvector as if it were a basis vector (you must not interpret that at time = 0, all frames agree that a bird is overflying x = 1 or whatever), but read that all frames agree that the eigenvector's slope is whatever. So it can make sense that the second term is arbitrarily anyone.
But (apart from the just mentioned correction, which I take) I don't think that my view of the eigenvector contradicts what has just been said.
robphy said:
At this point, I'm more concerned with what the mathematical structure implies in terms of describing the physics and less concerned about what the structure is called.
Yes, and when semantics turns muddled, I suggested before (#14), in order to describe the physics, to look at the operational meaning of concepts.
What I said is that an eigenvector is a "measurement instrument", whose measured values are cross-frame "shared", although what is shared may be more or less: it is essential that there is cross-frame agreement on the ratio between the values, it is contingent that there is also agreement on the scale (which depends on the eigenvalue).
So I think that we converge on the essence: I agree that what is essential is the ratio (here the infinite speed), it is just that I see this as the output of a measurement instrument: it is the rigid rod inspired by vanhees71's comment (see my post #63), one endowed with infinite sound speed.
A usual difficulty that I have is that you apply the SR distinctions (timelike, spacelike...) to Galilean relativity, where they are not supposed to apply... Isn't the key that in Galilean relativity we assume that all vectors are timelike precisely because we assume that the eigenvector (= shared instrument = a rod endowed with total rigidity and infinite sound speed) can be manufactured, even if it can't?
My take would rather be that Galilean relativity sees this infinite speed as achievable, but one can see that it is wrong.In particular, if we take the slope as run over rise = horizontal over vertical = x over t (i.e. we maintain the rule x over t, to get a speed, although following the relativity convention, we put t as vertical), then we get whatever x over 0, which is an undefined expression. Whenever I spot an undefined, I interpret it as a thing that breaks the rules of math and hence is a physical impossibility, unless interpreted as a limit. So this would be an indication that you need evolution to a better paradigm because the thing that the Galilean transformation hinges on (its eigenvector) turns out to be a physical impossibility.
(Although one should be prudent in this, however, since our mathematical approach has assumptions leading to this step which a Galilean might contest...)
is also infinite.
Just noting that I am too tired and will need time to assimilate this...
How often do I have to repeat this! There is no single physical theory, where time is a vector!!! It's a real oriented parameter parametrizing the causal order of things.
In Newtonian mechanics it's just a real number, and at each point in time there's a 3D Euclidean affine space, i.e., Newtonian spacetime is a fiber bundle, at least that's the natural mathematical structure depicted closest the physical meaning of the Newtonian spacetime model, not these artificial "Newtonian four-vectors" we are unfortunately still discussing and which obviously are very confusing for you.
In SR spacetime is described by a 4D Lorentzian (pseudo-Euclidean) affine manifold. Choosing an inertial reference frame can mathematically be defined as choosing a space-time origin (the arbitrary event, we label with ##t=0## and ##\vec{x}=0##) and a Lorentzian basis (tetrad). Then the corresponding "coordinate time" is the time-component of the four-vector wrt. this choice of (global) inertial reference frame. Another much more convenient choice of time is a scalar, depending on the physical situation you want to describe. E.g., if you do special-relativistic point-particle mechanics for a single particle (maybe moving in some field, like an electromagnetic field) a convenient choice for the time parameter is the particle's proper time, which is a Lorentz scalar, parametrizing the worldline of the particle.
I have no problem with Newtonian time as a real number. That was the point of the OP: that the video showed a "time basis vector" that seemed incompatible with Galilean relativity and not the good way of introducing SR, as it implied that you will find in the latter what already exists somehow in the former. I must say however that the discussion is being very productive for me.
Ah, but here you are pointing out that my understanding of SR is wrong. Maybe! The thing is that I have seen a few descriptions of SR in terms of linear algebra, with the LT presented as a change of basis and the basis vectors being (putting t first and x later and assuming just one spatial dimension) a unit spatial vector (0,1) and a unit time vector (1,0), the combination of which (with the specific metric of SR where the dot product has minus sign) gives a spacetime interval as distance between two events.
In fact, if we talk about a four-vector (a 2-vector if we restrict ourselves to T and X), the time-component that you talk about must be a vector as well: a coefficient multiplied by a basis vector. This coefficient will be "coordinate time"... or "proper time", if the interval in question happens to be timelike and the inertial reference frame that we are talking about also happens to be present at both events of the interval. But... if I look at the Euclidean analogy, there may also be situations in which one frame has one single axis linking the two extremes of the distance. For example, you may measure the height of a tree with an X axis paralell to the ground + an Y axis parallel to the tree, whereas my X axis is a ladder leaning on the top of the tree. So your solution comes from the combination of two coordinate values, while mine flows from a single proper value. With regard to another problem, it may be the other way around. But because of this, we don't stop saying that the basis vector of X axis is a vector.
Also note that there is proper length as well, and because of this we don't stop saying that there is a space basis vector.
Are you here talking about 4-velocity vectors instead of 4-displacement (i.e. the tangent to the wordline of a particle)?
Well, I do understand that proper time comes here in the denominator, even in SR, as a Lorentz scalar.
But then I would not say that "there are no time basis vectors in SR". I would say that coordinate time (which may sometimes coincide with proper time) is the magnitude of the time basis vector component that you use to compose a 4-displacement vector, although then such vector divided by proper time (coming here as an invariant or frame-independent value) gives you the 4-velocity of a particle.
I must admit, though, that I have difficulties wrapping my head around the concept of 4-velocity and that I may not perceive the importance that you and robphy give it. And I am also prepared to be shown that I am wrong, but please see above the reasons why I am saying what is after all the object of the OP: I do see the possibility of talking about a Minkowskian time basis vector, while I don't see a Galilean time basis vector.
Saw said:
Ah, but here you are pointing out that my understanding of SR is wrong. Maybe! The thing is that I have seen a few descriptions of SR in terms of linear algebra, with the LT presented as a change of basis and the basis vectors being (putting x first and t later and assuming just one spatial dimension) a unit spatial vector (0,1) and a unit time vector (1,0), the combination of which (with the specific metric of SR where the dot product has minus sign) gives a spacetime interval as distance between two events.
But that's correct, but still time is not a vector but either a component of a four vector given a basis ("coordinate time") or a scalar (like "proper time" of a particle).
A component is a component (a number in the field of the vector space, i.e., here in the field of real numbers), not a vector. It's very important to distinguish components from vectors although unfortunately in most textbooks they say something like ##x^{\mu}## is a vector, although this symbol means the components of a vector wrt. a (sometimes no explicitly!) given basis. A lot of confusion can be avoided when one clearly distinguishes vectors (invariant objects) from vector components (transforming by a linear transformation under change of a basis).
There are time-like and spacelike vectors indeed, but that doesn't mean that time and space are vectors.
Of course, there are time-like vectors in SR and you can use them also as basis vectors (as one does when choosing a pseudo-Cartesian basis, which is most convenient), but that doesn't imply that time is a vector!
Four-velocity is a time-like four-vector along the worldline of a (massive) particle, which obeys ##u_{\mu} u^{\mu}=1##, when defining it as ##u^{\mu}=\mathrm{d}_{\tau} x^{\mu}/c##.
It's a time-like basis vector, but time itself is not a vector.
@Saw,
from my examples in #58 (clarifying #54 ) ,
in accord with @vanhees71 , wristwatch-time is a scalar, not a vector.
My final summary is
  • Observer-Wristwatch-time (the age of the observer along his worldline) is a scalar.
  • Along the observer-worldline at a particular wristwatch-time (age),
    the Observer 4-velocity vector (a unit tangent vector to his worldline)
    determines the instantaneous observer-time-axis "forward-into-the-future along the worldline".
like
  • Car odometer-reading (the distance traveled along its path) is a scalar.
  • Along the car's path at a particular odometer reading (distance traveled),
    the car's direction (a unit tangent vector to his worldline)
    determines the instantaneous direction of "forward along the path" for the car.
  • If the car travels in a straight line,
    the odometer reading is the "radius", a scalar,
    a number that tells you how far away you are from the origin.
  • The "unit radius vector" is a vector that points in some direction
    that determines the direction "away from an origin O".
I have nothing further to add on this issue.
Concerning eigenvectors...
Take as much elapsed wristwatch-time ( a scalar ) as you need.
  • Haha
The meaning of this is clear to me, since quite a few years ago... :) although thanks for taking the time to specify it!
It seems that we may be using different terminologies (after all English is only my fourth language...). :)
I (of course) assume that a vector is an invariant object, which can be described in different manners, i.e. from different perspectives or, in our context, with different bases.
The (as a minimum linearly independent, ideally orthogonal and unitary) vectors that compose a basis serve to describe (span) a vector space. This description is made by associating a scalar of the corresponding field of the vector space (in our case a real number, in other cases it may be a complex number) to each basis vector.
I have always referred to this scalar as the "coordinate" or "coefficient" scaling the basis vector as per a given basis.
Instead, I have used the term "component" to refer to, as I said in my previous post, the basis vector as scaled by the relevant coefficient. The use of the term seems logical, because, when the time comes for putting together the components (i.e. to compose them), what you compose is not the coefficients but the basis vectors as scaled by the coefficients.
However, clearly above you are using the term "components" as meaning what I called "coefficients". Which is then the right term for what I called "components", i.e. the basis vectors as scaled by scalars?
This is important to know because here for example...
what do you mean by "component of a four vector given a basis ("coordinate time")"?
First option: you are sticking to your above-mentioned definition, i.e. you are referring to the number scaling the time basis vector. But that number is a scalar, no matter whether it is wrist-watch time, i.e. it has been measured by a clock being present at the two events, or it has been measured by two previously synced distant clocks. Certainly, the latter thing does not make the number in question less of a number. A different thing is that the second thing ("coordinate time"), unlike "proper time", will never be the scalar being spit out by a dot product of a ST vector with itself as the invariant solution to a problem, but that is another issue (see below).
Second option: you use now another meaning and you refer to the time basis vector as scaled by the coefficient. In that case, if you use now "component" with the meaning that I usually ascribe to the word, then I don't know why you say that it is not a vector. A unit basis vector, however scaled, is obviously a vector.
I think that what you mean here is what I hinted at above: you mean that proper time is a scalar in the sense that it is given off by a dot product of a ST vector with itself as the invariant solution to a problem, whereas coordinate time would never be that. No problem with that, if that is what you mean.
Conclusion: in SR,
sure, I am not saying that it is, because after all "what is time" if not, as Einstein said, what is measured by a clock?
The only thing that I am saying is that in SR there is a time basis vector, whereas in Galilean relativity there isn't any. I am also aware that in SR proper time is a scalar that is isolated by combining the time basis vector with space basis vectors, as scaled in the basis that you are using, and that this is an invariant number with which you solve problems.
What I don't know is what ropphy is saying about SR and Galilean relativity being the same in this respect, do you? (Under Galileo you don't need a time basis vector to combine with the space basis vector and thus learn the wrist-watch reading between two distant events, since here time is universal and all time is wrist-watch time.)
A "time basis vector" (what I would call "a 4-velocity vector that is tangent to a worldline")
is needed in both SR and Galilean because (in inertial case) it is used to describe
the spacetime-displacement vector
"from the 'tick-0 on Alice's worldline'-event to the 'tick-1 on Alice's worldline'-event ",
which is different from the spacetime-displacement vector
"from the 'tick-0 on Bob's worldline'-event to the 'tick-1 on Bob's worldline'-event ",
If all one would want to do is label "hyperplanes of simultaneity"
(this hyperplane is "all space at t=0", that hyperplane is "all space at t=1", ...)
and thus only care about the "elapsed time between events"
then I could see why you may be saying that
you need the "time-basis vector" in SR (since the hyperplanes depend on inertial observer)
but
you don't need the "time-basis vector" in the Galilean case (since the hyperplanes are independent of inertial observer).
However, we generally want to do more than just label hyperplanes of simultaneity.
Implicit in what I said above,
we would also want to identify (e.g.)
the set of events that correspond to x=0 (,y=0, z=0) according to Alice, for each reading on Alice's wristwatch,
the set of events that correspond to x=0 (,y=0, z=0) according to Bob, for each reading on Bob's wristwatch,
Thus, we also care about the "spatial-separation between events at different times",
(so that we can answer "Is that particle at rest in my frame? and if not, how fast is it traveling in my frame?")
and this depends on observer.
From #58,
Every inertial observer would like to draw her spacetime diagram
with her worldline vertically upwards (in the time-upward convention),
as granted by the relativity principle. This is the diagram for the Galilean case.So, we need the "time basis vector" ("a 4-velocity vector") in both the SR and Galilean case.
but
Here you seem to be talking about "elapsed time between events" that are "simultaneous", even if separated by distance, so elapsed time between them is 0. You note that, since simultaneity is absolute in Galilean relativity, there is nothing here related to time that is observer-dependent. So no need for a "time-basis vector" for this set of events. I cannot agree more.
Here you talk about events with "spatial separation" but happening "at different times" and you say that this "depends on observer". But what "depends on observer"? Let us scrutinize each element of the situation to check if anything related to time is observer-dependent.
- The spatial separation certainly is frame-dependent, but this is the x coordinate, it is not due to the time period elapsed between the two events, which is the same for all observers, no matter if they measure with a wristwatch present at the two events or with distant clocks.
- The speed of any object traveling between the two events is also frame-dependent, but this is an automatic consequence of the previous statement: it is due to the distance traversed being relative, while the time period remains absolute.
- Certainly, if you look at Alice and Bob, as you propose, who are the observers located at the origin of each frame, it is clear that their wristwatches get progressively apart from each other... Does it mean anything in terms of time? No, because the watches keep ticking in perfect sync, as could be checked through the rigid rod with infinite sound speed which we identified as the eigenvector of the Galilean transformation. And if they stopped to do so, we would recalibrate them with that magical rod so that they keep ticking in sync. Obviously, you don't mean that the mere fact that the watches are getting apart from each other makes time observer-dependent, just like if the watches were of different colors, this would not make their time readings color-dependent.
- You say the "set of events" for Alice and Bob (from their respective vantage points, x=0 and x'=0) are "different". "Different" in what sense? If an event is characterized by an x and a t coordinate, the x coordinate is different but the t coordinate is not.
So far I did not spot here, either, anything related to time that is observer dependent.
4-velocity seems to be a key concept in your argument. Do you mean that, for example, the 4-velocity of a particle traveling between the two events would be different in each frame? But let us open up this concept.
In SR it means 4 observer-dependent coordinates (coordinate time and the 3 spatial coordinates) divided by proper time measured from the frame at rest with the particle, which is an invariant concept. In SR coordinate time and proper time are different, except in the frame of the particle in question.
But in Galilean relativity, time is absolute, so coordinate time is always the same as proper time. Hence the first coordinate is always 1 in any frame. In turn, the three spatial coordinates are observer-dependent, but they are not related to time. Thus the concept is just 3-velocity to which you have added a value related to time, which is invariantly 1. And you conclude that this way you have found a "time-basis vector"?
Honestly, this looks to me contrived: you have artificially mixed, under an ad hoc concept (Galilean 4-velocity), absolute time separation between two events with the relative spatial distance between them, but through this forced cohabitation of one with the other you are not managing to make time observer-dependent in any sense.
What prevents it? Why do you need a time-basis vector for this? Do you rather mean that if I draw my vertical line perpendicular to my X axis, then yours must be inclined? Sure, but this has nothing to do with the time axis. You don't need to attribute this different inclination to any observer dependency in terms of time. You just have to admit that the different evolution over time of the origins of the frames reflects their progressive spatial separation.
See this image which I posted before, now improved on the basis of our discussion on eigenvectors, where the vertical (absolute time) and horizontal (absolute length) orange axes reflect the common scale arising from eigenvalue = 1.
PeterDonis said:
Yes, but that curvature is not derived from a spacetime metric, since there is no spacetime metric in Galilean spacetime. The curvature is derived from a connection, but that connection has nothing to do with any spacetime metric (since there isn't one).
The connection can be derived from degenerate space and time metrics, of which the "inverses" are related by projective relations. Metric compatibility however doesn't fix the connection completely; the ambiguity is a two-form K. See e.g.
https://arxiv.org/abs/1011.1145
In that paper it is shown how NC theory is derived from the Bargmann algebra, and how the connection is uniquely solved for in terms of the Vielbeine (gauge fields of translations) and gauge field of the central extension.
@robphy
Since you know more than me and have been patient enough to keep objecting me, I have made more effort to converge to you.
I understand that you are telling me that one Galilean frame sees that the other’s time-basis vector is dilated, despite measuring the same time, because it measures that same time along more spatial distance. So would that be the “observer-dependency“ that you note “related to time”?
Is that in line with defining the Galilean transformation as a shear mapping, as sometimes it is said?
I guess one can derive a Newtonian theory of gravitation by making the Galilei symmetry local, as one can derive Einstein-Cartan theory by making the Poincare group local starting from general relativity.
Yes, but you need the Bargmann algebra, i.e. the central extension. That extension is crucial. Ultimately, the gauge field of that generator will give (after gauge-fixing your coordinates) the Newton potential. Curiously, a nonrelativistic point particle then couples to this gauge field just as a relativistic point particle couples to the electromagnetic 4-vector A_mu. See also
https://arxiv.org/abs/1206.5176
Or, if your Dutch is reasonable,
https://www.google.com/url?sa=t&sou...4QFnoECAwQAQ&usg=AOvVaw3VwJnCJF78arsiOAAfiisA
I see. So from this point of view there's some classical argument that the true Galilei symmetry is the central extension Bargmann algebra. That's anyway the case for quantum theory.
Although my name suggests otherwise, I don't speak any Dutch. I guess, however, maybe it's possible to have an idea what the paper is about ;-)).
I'd thought so. I once was in the Scientology department of New York out of curiosity, and said I was Dutch, at which the poor fellow offered me a German ("Deutsch") translation of Diagenesis :P
But yes, indeed. Central extensions are often associated with quantisation. But the fact that the Lagrangian of a non-rel. point particle transforms into a total derivative under boosts necessitates an adjustment of the corresponding Noether charge to be conserved. In the Poisson brackets this introduces an extension in the Poisson bracket
\{Q_B, \ Q_P \} \sim M
motivating the central extension (P stands for spatial translations, B stands for boosts).
From #70 (reiterating #58, which is reiterating #54)
"from the 'tick-0 on Bob's worldline'-event to the 'tick-1 on Bob's worldline'-event ".
I repeat this because it is a natural thing to do... and to have.
But for some reason, you ignore it.
it seems you think I made artificial made this up or forced it to be so.
I am going to argue that the structure is already there, as part of the position-vs-time diagram.
As soon as you write down the Galilean transformations in matrix form,
you are working with Galilean vectors, with time and space components.
That's what the Galilean transformation does...
it maps a Galilean 4-velocity to another Galilean 4-velocity.
But you seem unhappy with that.
So, let me not use the word 4-velocity, since I think it is a distraction at this stage.
let's use instead "unit tangent vector" and think of it as a unit displacement .
So, a Galilean boost transformation maps a unit tangent vector (of an inertial worldline)
to another unit tangent vector.
That's what this diagram shows---making the tilted tangent vector vertical.
(No need to mention or invoke 4-velocity.)
(The fact that the horizontal lines (hyperplanes) are unchanged is irrelevant
to the transformation making the tilted tangent vector vertical.)
As I said, I don't feel "unhappy" with it. In fact I use this formalism with spacetime vectors in Galilean relativity myself, because it's convenient to deal with the Galilei group, but contrary to the spacetime models of relativity there's no further physically relevant structure than the fiber-bundle structure. Time is simply absolute, i.e., a oriented ##\mathbb{R}^1##, along which affine euclidean ##\mathbb{E}^3## manifolds are pinned.
For me, in my Spacetime Trig approach,
I can prove many kinematical results in special relativity
by direct analogy with Euclidean geometry via
a one-parameter family of Cayley-Klein geometries
from E=+1 for Minkowski to E=-1 Euclidean, where E=0 is Galilean spacetime geometry,
which is the topic of the eigenchris video linked in the OP.
My participation in this thread is my response to the OP,
which questions the usefulness of the Galilean spacetime.
I think the value of the approach is that many of the surprising results of SR (special relativity)
can be shown to have a "Galilean limit" precisely,
and seems to suggest the Galilean-spacetime version
and Euclidean-geometric version of the special relativistic result.
This suggests that the result might not be as "How could that be?"-surprising
if one was already
aware of the Euclidean and Galilean versions...
or one might be able to use Euclidean and (if illuminated) Galilean versions to obtain the SR-result.
It's not just about such analogies in a few situations,
as seen in scattered throughout the literature
as if one chose (possibly because one already knows the answer for this situation)
which term would be subjected to the limit.
Rather, it's a unified approach that dictates which terms are subjected,
due to a parameter in the Cayley-Klein approach (at the level of its projective-geometric foundations).
But, yes, in Galilean geometry in isolation
may be appear uninteresting and not useful.
Sorry if I sound sometimes too radical, it is just that I am struggling with the ideas!
Let us check if I can follow you.
Say event A is when Bob and Alice meet ( t = 0), event B when Bob's wristwatch ticks 1s and event C when Alices' wristwatch also ticks 1s.
A-B is different from A-C.
The description of each set of events is different in each frame:
- In his coordinate system, Bob will paint his T axis as a vertical line (his wordline) and segment A-B as overlapping/tangent to such line, but he will paint Alice's T axis as a diagonal line and segment B-C as overlapping to that diagonal line.
- In her own coordinate system, will do the opposite: she will paint her T axis as a vertical line, the segment A-C also vertical, but Bob's T axis and segment A-B as diagonal.
- The projection from event C to Bob's axis is overlapping with the projection from B to Alice's axes, meaning that they both agree on simultaneity and that the time lapses A-B and A-C are 1 s.
But why are the two pairs of events different? Because the wristwatches are moving wrt to each other.
And why does each frame make a different description of each pair? Because each frame deems itself motionless and attributes that progressive spatial separation to the other frame. So the thing that can be inferred here is that two Galilean frames have different rulers but not that they have different clocks, different time units, time basis vectors, or even time axes...
I understand that it may be difficult to accept that there are no different time basis vectors if there are different time axes, with different inclinations. That is why at a given moment, instead of the above-mentioned description where each frame paints its own T axis, I proposed this drawing, where the T axis is common.
I don't know how you see this. I think that it is consistent with the very helpful guidance that you've given me in understanding the eigenvector of the Galilean transformation. Can the eigenvector, i.e. common instrument that all frames share (the rod with infinite sound speed), also be the "common clock"? You may say: "but that rod only works for fixing absolute length or ensuring absolute simultaneity, it is not a clock, which is another instrument at rest with each frame!". Well, just imagine that the rod is, due to some mechanism, oscillating up and down, and it is everywhere, thus providing all vehicles with a common time. In SR that would not work, because the driving force keeping the rod in motion would have limited propagation speed, but this would not be a problem under Galilean relativity thanks to the admission of an infinite speed.
But there may be something that I am missing, since as usual, however, when you bring in the Galilean 4-velocity, I get lost.
I think that I understand the SR 4-velocity as something different from the ST displacement: it is the rate of change of ST displacement wrt to proper time.
In the Galilean context, based on your comment above...
robphy said:
A "time basis vector" (...)
is needed (..) to describe
...I thought that the time basis that you invoke is simply the "ST" displacement vector A-B or B-C.
Same puzzlement for SR: why do you identify the SR time basis with 4-velocity instead of simply with clock unit readings, either at the origin or with any other clock, as they are supposed to be synced as per the frame's standard?
It's too difficult for me to manage multiple issues in each post.
So, I will work on a piece at a time
They have identically constructed clocks (synchronized once in the past).
And, for any given event, when Alice and Bob use their clocks,
the assign time coordinates which, in the Galilean case, agree.
Since each clock has its own worldline (locating where and where each clock has been),
they each have a unit tangent vector.
(I will describe everything using tangent vectors because
the word "4-velocity" is introducing a distraction, and
is thus an easy target to complain about.
So, I'm sticking with unit tangent vectors, which should be clear and uncontroversial.)
It is useful to find a quantity to describe how different these two tangent vectors are---
something to describe the separation between their directions.
In Euclidean geometry, we use "relative angle" and we use "relative slope"=tan(relative angle).
In Minkowski geometry, we use "relative rapidity" and we use "relative velocity"="relative slope on the diagram"=tanh(relative rapidity).
It turns out (in the literature I referenced earlier, and in my poster) in the Galilean geometry,
we use the relative Galilean-rapidity, and we can calculate a "relative slope",
which is proportional to the rapidity (as opposed to a nonlinear relation because of tan or tanh).
Thus, the "relative spatial velocity" between the moving clocks can be obtained
using the two tangent vectors.
This relative velocity determines the "v" in the Galilean boost to transform from Alice's frame to Bob's frame.
That seems like a useful physically-interesting quantity.
Allowing each frame to draw their own position-vs-time diagram (in Galilean and Special Relativity)
is akin to allowing each orientation of graph paper to have its own x- and y-axes in Euclidean geometry.
So, I am merely following (as far as I can) what worked well for Euclidean geometry
and in retrospect will see that will also work well for Special Relativity.
That Euclidean geometry grants me the freedom to do geometry in any orientation
is akin to the Principle of Relativity granting me the freedom to study physics in any inertial reference frame.
However, your alternative proposal deviates from this freedom
and, to quote an earlier post of yours directed at the "Galilean 4-velocity"
Your alternative proposal distinguishes one T-axis, which is not in the spirit of the Principle of Relativity.
Further, this alternative proposal won't carry over into Special Relativity.
So, this becomes further "common-sense baggage" that you'll have to unload.
Your interpretation of the eigenvector of the Galilean transformation isn't my interpretation.
As we have seen, there are no eigenvectors of the Galilean boost with nonzero t-components.
So, the "common clock" (interpreted as a worldline with a
tangent vector with a nonzero t-component)
can't have a tangent vector that is an eigenvector of the Galilean boost.
Same for me! The priority is to check if I understand this point of yours, so let us make it clear before anything else.
When I say "this point", I mean the link that you establish between the unit tangent vector, relative velocity btw the two frames (and their clocks) and the time basis vector.
I suppose there is a typo and you meant "when and where each clock has been". As to what the unit tangent vector is, I have no problem. I think that I more or less described it in my previous post:
You also want to make an analogy with Euclidean and Minkoswskian geometry, where you introduce the generalized concepts of angle and tangent of this angle, which for me is perfect in itself. A different thing is how to interpret this analogy, but we are not there yet. Let me use this picture from your poster, somehow manipulated, as a reference:
The analogy is spotting that there is an "angle" in the three geometries: the distance between the final point of Bob's unit tangent vector (event B in my notation) and the final point of Alice's (event C) = a circle-like angle (Euclidean), a degenerate circle or straight line-like angle (Galilean) and a hyperbolic angle (Minkowskian).
In all cases, the tangent of the "angle" is the slope" o ratio between the relevant values: a purely spatial ratio = x/y (in the Euclidean case) or a spacetime ratio = x/t. i.e. a velocity (in the Galilean and Minkowskian cases).
Please confirm if I reflected it well.
If so, what I don't understand, as noted in previous posts, is where you place the time basis vector:
- My first interpretation is that you equate it with the "spacetime displacement vector" A-B (Bob) or A-C (Alice), which is relative: in Galilean case, only due to relative distance; in Minkowskian case, in more respects.
- Then you add the concept of "velocity", which is the tangent of the "angle" between the two displacements To be noted: this velocity, which is...
.... ie., the relative velocity between the two watches and between the frames, is invariant, both in the Galilean and in the Minkowskian geometries (for different reasons in each case), so it is a different thing.
Surely, the two concepts are related and they are both useful, but they are different. And then one has to decide what to call the "time basis vector", whether one thing or the other. In my naive understanding, the time basis vector should be the unit of the time axis and this in turn the output of a clock, with which precisely you calculate the velocity of things, either of the other frame or of projectiles moving wrt both frames, as a ratio between distance traversed and time elapsed...
On another note, strictly speaking, your literal wording is always equating time basis with "4-velocity", but we had agreed to leave aside this other concept "for the time being". I let you choose whether to bring it into the discussion or not.
Yes, in your rotated-axes convention (following space-running-horizontally, time-running upwards).
In my poster, I keep the time-axis horizontal (as in PHY 101 texts) and refer to the spatial-direction as y
in order to make comparisons with Euclidean geometry and intro (Galilean) physics easier.
(However, it could be argued that familiar "angle" as arc-length-on-unit-circle
isn't as natural as construction as the associated "sector area"-intercepted in unit circle.)
I would agree with this, provided that this is
the unit tangent-vector to the worldline for any clock (whatever its motion and in whatever case (SR or Galilean)).
Even if a symmetry exists (like absolute time)​
that suggests that
each observer can give-up his or her clock​
(as if surrendering a democratic right [the principle of relativity])​
in favor a universal (autocratic absolute timekeeper) Big Ben to tick for the universe,
the unit tangent vectors to various worldlines can and should​
still function as [possibly viewed by some as redundant and useless] time-basis vectors.
(In surrendering, the ability to understand relativity in hindered...​
"do you mean we each can really keep our own time with our own watches?" )​
I am keeping the focus on the unit tangent vector, but that is what the geometrical analogy dictates.
In special relativity, one can interpret that unit tangent vector as the so-called 4-velocity (geometrically, a dimensionless quantity [since it's a unit-vector], despite its name and despite its historical introduction),
where the ratio of its sides [in (1+1)-spacetime] is the dimensionless version of the more-familiar "spatial velocity" v appearing in the boost. But these aspects appear to provide a distraction from the main issue.
So, I have and will continue to avoid it... because I can support my viewpoint that time-axes are associated with the unit tangent-vector of every clock worldline.
But the Galilean space-time plane is not a Euclidean affine space (neither is the Minkowski space-time-diagram plane)!
Yes, and that's good...
since these have different metrics, different structures that support or don't support a causal structure.
But the point of analogies
is that you can use
what is common [ about being an affine space (a vector space who has forgotten its origin) ]
and then point out
what is different [ depending on your metric or quadratic form ].
  • Two given lines intersecting in the plane do so at the same point in all three cases (Euc, Gal, Mink).
  • Two lines that are parallel in Euclidean geometry
    are also parallel in Minkowski spacetime and Galilean spacetime geometries.
    • A vector perpendicular to those lines depends on the metric.
    • How far apart the lines are depends on the metric.
  • The operation ##\vec A+ \vec B= \vec C## gives the same resulting vector in all three cases.
    • However, the "magnitude of ##\vec C##" depends on the metric.
And metric dependence is directly traceable to where the E-parameter (##\epsilon^2## in my poster)
appears. So the storyline I use goes something like this
  • In Euclidean space, a circle
    (points equidistant from a reference point using odometers that can travel in any direction)
    has the form ##t^2+y^2=R^2## (where the spatial ##t##-axis is parallel to the straight-line odometer path and the space ##y##-axis is perpendicular to the path
    (where perpendicular is parallel to the tangent to the circle)
    and ##R## is the odometer reading).
  • In a PHY 101 position-vs-time graph, a Galilean circle
    (the set of events from a reference event that occur "1 second later" according to wristwatches that were at that event and can travel inertially with any velocity),
    as revealed by experiments done at terrestrial speeds and extrapolated to arbitrarily large speeds,
    has the form ##t^2+(0y^2)=R^2##
    (where time ##t##-axis is parallel to the inertial wristwatch worldline and the spatial ##y##-axis is perpendicular to that worldline
    and ##R## is the wristwatch reading).
  • In a Minkowski position-vs-time graph (a spacetime diagram), a Minkowski circle
    as revealed by experiments done at terrestrial speeds and high-energy particle speeds,
    has the form ##t^2-y^2=R^2##
  • So, a Galilean might have said "a generalize circle has the form
    ##t^2+(k) y^2=0##, where ##k=1## for Euclidean and ##k=0## for Galilean.
    And there are many similarities (and differences) between the equations
    and the geometrical constructions.
  • But then (newsflash)
    experimental data (from unstable high-speed particles that should have decayed)
    says that for position-vs-time graphs is seems that ##k\neq 0## , in fact ##k<0##!
    For some convenient choice of units, a curve-fit gives a value of ##k=-1## ,
    which implies there are asymptotic speeds for wristwatches that are finite.
    This ##k## is ##(-E)## in my past discussions in this thread ( and ##-\epsilon^2## in my poster).
    (Again this is along the lines of
    If Maxwell had worked between Ampère and Faraday: An historical fable with a pedagogical moral
    https://aapt.scitation.org/doi/10.1119/1.12239 .)
So, it is a good thing that
a very good thing.
is that you can use
and then point out
But from a didactic point of view there are good and bad analogies. Claiming to have a Euclidean plane although the very point of the diagram is that it's not a Euclidean plane is a bad analogy. That's why I find Minkowski diagrams in principle not a good didactic tool, but I have to teach them, because my high-schhool-teacher students need to understand them to explain them to their highschool students. Unfortunately Minkowski diagrams are still considered as good didactical tools, and you have to spend a lot of time to hammer into the students the fact that they must not read them as a Euclidean plane, and that what's unit ticmarks on two Lorentzian reference frames don't look like the Euclidean unit ticmarks in a Cartesian coordinate system.
Fortunately nobody came up with the idea to use "Galilei diagrams" in Newtonian mechanics, i.e., there you don't need to introduce the also pretty complicated fiber-bundle geometry to visualize the Galilei-boost transformation between inertial frames, because fortunately nobody uses them.
A PHY 101 position-vs-time graph is a Galilean spacetime diagram.
No one has really used the metric structure explicitly,
although we have all used it implicitly.
It seems we have learned how to use PHY 101 diagrams
without reading them as Euclidean planes,
because we have done a lot of practice with them.
(However, I have seen occasional student answers
using the Pythagorean theorem on a PHY 101 position-vs-time graph.)
Like any tool, one has to be taught how to use it... and how not to use it.
In addition, the typical user does not need to know all of the underlying mechanisms
to make use of it.
I know how to read a watch without knowing how it all works.
We don't have to get into the various structures in Euclidean geometry for relatively-simple problems.
Do we say,
to study a block on an incline, we can use SO(2) symmetry to construct a coordinate system parallel and perpendicular to the plane. So, let's first understand what SO(2) is.
Likewise, we don't have to get into many details underlying the Galilean diagram to use it.
However, we might want to drop hints to prepare them for special relativity.
Again, in isolation, the Galilean diagram doesn't seem worth it.
But it may be helpful to interpret what is going on special relativity.
No, it's a graph, showing the function ##x=x(t)##, but it's never used as a Galilean spacetime diagram. Nobody with a clear mind would draw the time coordinate of another inertial observer moving with the constant velocity ##v## against the first one, then construct unit ticmarks at this new ##t'## axis, and they don't have the same Euclidean distance as the unit ticmarks on the original ##t## axis although this complicated construction just takes care of the fact that ##t'=t## and ##x'=x-v t##.
And that's the problem! You are always inclined to look at spacetime diagrams as if they were Euclidean planes, because we are used to do Euclidean geometry by drawing on a sheet of paper.
Ok, to what purpose? I've no clue, where such an idea has a useful application in Newtonian mechanics.
Indeed, and introducing spacetime diagrams you have to force yourself and your students to not to read it as if it were a geometric construction in a Euclidean plane ;-)), i.e., you have to use considerable time to explain how NOT to use it.
to make use of it.
Do we say,
No, there you can use Euclidean geometry, where it is applicable, i.e., in the 3D space of an inertial observer in Newtonian mechanics ;-).
We just don't need such diagrams for anything. In my opinion also Minkowski diagrams are not really needed, since where they can be used the calculations using Lorentz transformations and the Minkowski-space "metric" is much more straight forward and thus less probable to lead to misconceptions.
Of course, it also depends on each individual person. Maybe some people find Minkowski diagrams helpful. For me they are a pain, because they confuse me always when I want to explain them ;-)).
