Is String Theory the Ultimate Theory of Everything?
The discussion revolves around the validity and future of string theory and M theory as potential theories of everything. Participants explore whether these theories should continue to be researched, given the lack of experimental evidence and claims of falsification by certain experiments.
  • Some participants assert that string theory is currently a hypothesis without experimental evidence, suggesting that it could explain many phenomena if it accurately describes reality.
  • Others argue that the search for a theory of everything should continue, emphasizing the importance of knowledge and exploration.
  • A participant mentions that two experiments have allegedly falsified string theory, prompting requests for citations to support this claim.
  • Concerns are raised about the reliability of sources provided to back up claims against string theory, with calls for proper citations from established scientific literature.
  • Some participants highlight that the lack of evidence for supersymmetry and micro black holes does not necessarily disprove string theory, as it may still be valid at energies beyond current experimental capabilities.
  • There is a philosophical dimension to the discussion, with references to Feynman's views on the search for a theory of everything being more about exploration than definitive answers.
  • One participant humorously notes that string theory seems unable to explain our universe, suggesting a paradox in its application.
  • Concerns are expressed that focusing too much on string theory may hinder the exploration of alternative theories of everything.
  • Another participant counters that no single area of study should preclude the exploration of others, suggesting that multiple avenues of research can coexist.
Participants do not reach a consensus on the validity of string theory or the necessity of its continued research. Multiple competing views remain regarding its status as a theory of everything and the implications of experimental results.
Some claims about the falsification of string theory depend on interpretations of experimental results, which may not conclusively validate or invalidate the theory. The discussion also reflects varying standards for acceptable sources and citations in scientific discourse.
Hossam Halim
Hello,
Is string theory or M theory wrong ? Isn't it the theory of everything ? Should we continue our research to reach the true theory of everything ? If so, why physicists still research on string theory ?!
Hossam Halim said:
Hello,
String theory at this point is not right OR wrong, it is simply a hypothesis that has no experimental evidence but which would explain a lot of stuff very nicely if it DOES turn out to describe reality.
Why would you want to abandon the search for a theory of everything? Do you not care about knowledge?
I meant we should search for the theory of everything with different thinking and to leave string theory as there are 2 experiments falsify it
Which two experiments falsify string theory?
As George requested, you MUST back up such a statement with citations otherwise it is just an unsubstantiated personal theory.
Google this : ( string theory fails test )
Sorry, but this is insufficient.
When you are trying to back up your argument, you must provide proper citation. Asking people to search for the source to support your point should not be done. Google search will turn up both valid and dubious sources. Which one did you use?
Please provide clear, valid references as soon as possible, or this thread will be closed.
Zz.
All of these are of the following nature:
- Had they been found, they would have added support to (but not confirmed) string theory
- Not finding them does not even remotely disprove string theory
All of the sources you provide are of dubious reliability, or strongly biased.
Hossam Halim said:
Please re-read the PF Rules that you had agreed to. Pay attention to the type of sources that we consider as valid.
Not knowing your background, I will assume that you are not familiar with how things are done in science. Valid sources require a DIRECT citation of either well-established standard text/references, or a publication in our accepted peer-reviewed journals. Personal websites and blogs (even by Woit) do not constitute as valid sources. If you used this, then you are using 2nd, 3rd, or even 4th hand news.
This may be an "ordinary" forum, we are try to adhere to the higher standards on the quality of discussion. This means that references and sources must be of the same standard. This hopefully will prevent discussions at the level of tabloid journalism where dubious sources and any and all garbage are in. It also forces YOU to pay attention to where you are getting your information, and hopefully, educate you on how science is practiced.
Zz.
Hossam Halim said:
Hello,
As already pointed out, string or M theory are just theories - they haven't been disproved or confirmed, because they exist far away from our experimental reaches, and their phenomenological results haven't been found yet (however that's a very difficult way to "disprove" the theory, more oftenly, you are just going to disprove one model out of the theory or something like that).
I'd quote Feynman for the "theory of everything" thing, because asking whether we should search or not for a "theory of everything" is more a philosophical question... we are just exploring nature, if there happens to be a "theory of everything" so be it, if there doesn't so be it- we are just seeking for our own answers.
I don't think physicists at the moment do research on string theory (Glashow's viewpoint?). That's something mathematicians or string theorists do. Physicists are trying to find phenomenological results out of it.
Here you go:
https://www.youtube.com/watch?v=Eyynpf8x74I
Would it really explain at least something?
There is an old joke, that according to string theory our universe is exceptional: It is the only one which string theory is unable to explain.
The main problem with string theory is that the focus of research capabilities on string theory leaves no place for any other, independent search for a theory of everything.
I was going to post a joke about String Theory, but there were too many of them. :smile:
Judging by your indirect references, the two results you're referring to are:
1) The LHC failed to find evidence for Supersymmetry. This only means that the mass of any supersymmetric partners would be beyond the reach of the LHC, about 1 TeV. There were good reasons for hoping that Supersymmetry would show up at relatively low energies, but even though it did not, it's still a reasonable possibility at higher energy.
2) The LHC failed to find micro black holes. This would have been evidence for large extra dimensions, a somewhat far out idea.
String Theory does not really have anything to say about physics at LHC energies, so these two results neither confirm or invalidate it.
Now that's just silly. No one area of study precludes any other area of study.
Although Supersymmetry is a very nice theory, it's even more elusive than string theory...
Because we always expect to find it at some scales, yet it always avoids our detection hahaha.., At least you know that for strings the energies are unreachable and you only search for evidences of it, however for susy you know very much less (even the mass of Higgs is within the limits of MSSM+radiative corrections (<130GeV).
Nevertheless, don't forget some historical facts. When people first proposed the top quark, they were expecting to find it at ~50-70GeV (sorry I don't remember the exact energy). Of course, it finally appeared at ~170-175 GeV.
Of course there are searches outside string theory... However, during several eras in physics, there are some reasons why people like a theory more than others- because it seems more consistent/predictive. That was one of the reasons QCD dropped away string theory for some decades. But again it's a matter of personal view (some people like string theorists, some others don't consider them to be physicists- as I stated above Glashow belongs to the 2nd group).
Also the person who will come and tell you that he has the theory that describes everything, either his theory is wrong or he won't be a physicist hahahaha (joke)
Now that's just naive.
I said that tongue in cheek, but Lee Smolin has argued (in his book The Trouble with Physics, among other places) that the stronghold of string theory has has stifled research in other theories of quantum gravity, through funding and tenure.
Bill_K said:
I was going to post a joke about String Theory, but there were too many of them. :smile:Judging by your indirect references, the two results you're referring to are:
What are the limits on the mass of supersymmetric partners?
I mean, in the future we might have a faster particle accelerator, and they may argue the same argument as you do now, that we need a faster accelrator.
If they don't have some falsifiable limits on the bounds of the masses, then it's not even a theory.
It may even postulate that the energies are infinite, in which case you can never really know if the theory is right or wrong.
String theory makes very definite predictions about physics at the Planck energy. That is still like zero compared to infinite energy. However, it might as well be infinite compared to current technology.
What is the interval of required energies?
I understand that 1 Tev is in the lower end.
Hossam Halim said:
Hello,
Although string theory has taken many twists and turns and many physicists have concerns about the amount of research effort put into it, which could be directed towards other theories of quantum gravity, I think this has been over exaggerated in popular writings, recently.
It's popular to note that string theory has been in development for decades and hasn't yet been confirmed by experiment, but it's also important to note that it hasn't been excluded by experiment either. In fact, to disprove it at low energies, where almost all observational data is gathered, would involve disproving QFT itself, which would be much more problematic.
Amongst other things, string theory has given us the AdS/CFT correspondence, which although it is still conjecture, is widely accepted in theoretical physics and has found uses in our understanding QFT and black holes.
Is string theory a ToE? I'd say probably not because it doesn't tell us how the vacuum of our universe is selected, but it's certainly a useful mathematical description, which could form a subset of, or a limiting case of, a ToE.
The limits for mass particles don't come from Supersymmetry I guess, they come from the models of Supersymmetry. So models can of course be wrong-
I remembered the value- when the top quark was proposed (right after the discovery of bottom), the models we made proposed that it should have a mass of roughly 17GeV... they didn't find it there, so they said it must be around 30, 40, 50GeV the most... The top quark appeared at 170GeV, and from that we get some lesson. Firstly, the nature will show itself up as it is and not as we want it to be. And secondly, we don't know why the top quark must be so heavy.
Well, since supergravity is the extension of string theory at lower energies, and since sugra gives us the susy breaking mechanism that allows [itex]E_{vacuum}[/itex] to take zero (or almost zero-as we measure it today-) value, isn't that a possible answer to how it's chosen?
Wait a minute, how do they know that it's a top quark before detecting it?
I mean presumably it has some properties that were detected and thus they concluded that it's a top quark. What properties are they looking for in supersymmetry that were'nt detected yet?
I mean this enterprise of research can last for decades (unless people who fund this research will be fed up with no experimental results).
This reminds me of the bet:
http://longbets.org/12/
Just less than 6 more years to go.
Some I guess didn't expect such a big divergence to the quarks' masses... And since they found the bottom at ~4GeV, they wouldn't expect the next one to be at 170GeV. And models probably were built to give them this result too.. of course they failed, but also we knew there should be the 6th quark after finding the 5th... That's how it works...
We weren't bored of quarks or leptons,and chose to bring about their superpartners to have more fun... SuSy fixes some problems which are pretty strong, as the gauge hierarchy problem (of course next to SuSy there are more candidates)
At the moment?
They are looking at LHC for enough missing energy (that will be LSP leaving the detectors).
http://physics.aps.org/synopsis-for/10.1103/PhysRevLett.112.201802
Or cosmological searches, for WIMPs maybe...
The Planck energy is 10,000 trillion Tev.
Ok, then why do theorists keep working on it?
I see now why Kaku awaits for a pure mathematical solution for this theory, it's pure mathematics.
Theorists work on open problems that interest them. The following are some of the open problems in high energy physics:
- SM does not extend consistently to very high energies
- there are a large number of fundamental constants in SM
- at high enough energies, gravity cannot be ignored in particle interactions
In cosmology, a few are:
- the precise character and scale of deviations from isotropy and homogeneity
- the apparent value of the cosmological constant (or acceleration of expansion).
[I hate the term dark energy]
- dark matter, or the problem dynamics of galaxies and clusters + gravitational lensing
observations
Theorists who work on string theory are following their informed hunch that it provides a framework in which progress on all of these can be made. Theorists who work on other approaches are following different hunches, including the hunch that solutions to some of these problems are independent of each other (or can be treated as such). [The grandiose name TOE has been given to a hypothetical unified theory that solves this particular collection of problems, along with some closely related ones].
Any theorist who thinks string theory remains the most promising approach, should obviously continue to work on it.
I think that from PAllen's high energy physics bullets, the last one is the most important for string theory as a mathematical theory (I'm making this distinction because we cannot look at it in a direct experiment...). String theory contains gravity because it contains SUGRA. SuGra is nice because just by dealing with a local supersymmetric theory (on the superspace), you get the gravity because of this relation:
[itex][ε(x) Q, \bar{Q} \bar{ε}(x)]= 2 i ε(x) \sigma^{\mu} \bar{ε}(x) P_{\mu}[/itex]
(maybe I put an extra "i"?)
which tells you that the generators of a local (the ε depends on the spacetime point) supersymmetry transformation create a spacetime translation which depends on the point you've chosen (because the RHS depends on x)- this is the theory of gravity.
So String Theory(theories)>SuGra, can explain gravity without the problems arising from the Standard Model, or without Loop Quantum Gravity approaches which don't care about the perturbative renormalizability (=it's not a fundamental requirement) of the quantum gravity theory. (super)String theory however surpasses this problem (of course it has its own- like the tachyonic modes), and also it contributes to the unification of the forces.
observations
Well, one question that arises is if there is an upper bound on the energy in the universe?
If there is no upper bound, then theories in physics will never end just like theories in maths.
  • · Replies 26 ·
  • · Replies 33 ·
10K
  • · Replies 47 ·
10K
