Mentor
- 37,547
- 14,426
arivero said:Let me to point out also Resonaances entry "the loose-cuts analysis was not approved in time by the collaboration"
Don't take the LEE twice. This statement would be a proper description if ATLAS would have the excess at 750 GeV and CMS at 1 TeV. I don't think it would have triggered so many theory papers then. The masses are not exactly the same (how could they?), but very close and the yield comparison depends on your favorite theory model as the selection is different. CMS 8+13 TeV quotes 750 GeV, ATLAS quotes 750 GeV, CMS 13 TeV quotes 760 GeV, it looks like all values are rounded to multiples of 10.Vanadium 50 said:The significances are very low. One and two sigma are nowhere near five.
The narrow width gives a fine fit for ATLAS, so does a slightly larger width for CMS. That difference is way less significant than the excesses.Vanadium 50 said:ATLAS and CMS see rather different widths.
There is a slight excess, not significant on its own but compatible with gg production.Vanadium 50 said:The 8 TeV data does not confirm the 13 TeV data.
The interpretation depends on your favorite theory model.Vanadium 50 said:CMS doesn't see the signal in all parts of their detector.
To figure out what it is (if it is real): sure. To get highly confident that something is there: I don't think so. If the ~3.5 local significance is the expected strength of an actual signal, twice that data with the same conditions will give an expected local significance of ~4.9 sigma. But you can do better. You can check the various theory papers to improve the selection, you can improve the background suppression and estimation and so on. Pileup will increase a bit, but that should be manageable.Vanadium 50 said:Finally, even if it's real, you won't settle things with twice as much data. You need ten times as much data.
I assume there is some experimental reason, but I was also thinking that if the resonance pole is at M - i Γ with Γ = M then its square is in (M^2 - Γ^2) - 2 i M Γ the pure imaginary line, and that could be theoretically relevant. Also, perhaps the indeterminacy principle in energy-time has some say here, as Γ is inverse lifetime.mfb said:
Can you tell me what R-D gravitons refers to?arivero said:Please note also that I started the thread in the Lounge in order to allow for wide discussion. Of course, with more that 750 papers in the arxiv, almost everybody can quote its favorite model from some arxiv paper :-) I am particularly surprised that R-D gravitons are considered as a major possibility
Sorry, RS, Randall-Sumdrunbbbl67 said:Can you tell me what R-D gravitons refers to?
Okay, thanks, looking that up now.arivero said:Sorry, RS, Randall-Sumdrun
